Wow man I did not check in for a while here, this is really something. Great job you guys are doing, fantastic work from your FIL![]()
Thanks! I am planning on doing some detail work in some areas. Now that the majority of the work is complete, I will start going into the finer details.
I want to paint the gas line as it is just raw metal currently. I was thinking of painting it red however I do not want it to look cheesy/tacky. Maybe I will just paint it a nice black and throw on a "GAS" label for a nice touch. Any feedback?
Our exposed gas line at work is painted the same as the walls. Simple labels every so often explain which is which.
Great work on the garage!
Yes, something along those lines however without the accents. I was thinking of one solid color. Does anyone know where I can get "gas line" labels ?
I like the detail in the trailer setup. Did you have a picture of the front yard complete or did I miss it.
Sent from my SM-T805W using Tapatalk
It has been a while since I have updated my thread. Doesn't mean the work has stopped. Here is what I have been working on:
Removed the traditional overhead garage door opener and went for a Liftmaster 8500. Added the MYQ feature for online/smart phone monitoring. Works well and sure adds a level of security.
If you remember earlier from last spring, I had completed some landscaping in the front yard. I installed exterior lighting on a photocell - when it starts to get dark, it turns on/off. I put a light in front of a "feature rock". I finally got around to making the house numbers out of aluminum on the CNC machine. I have to wait until it gets warmer to mount the numbers however here is the result.
Once we start to get some consistent weather above 10 deg C, I will get on mounting them. More photos to come!
I do a lot of driving for work and have always hated having a coat/suit hanger clanging around on the side windows. For some reason it is super hard to locate a good quality headrest mounted coat hanger. Even ordered one from Amazon however it was a *************. SO, I made this.
Finished it up with some paint and a few coats of stain/varnish. I am happy with how it turned out. Might need a few adjustments however it does the trick.
Nice choice with the Liftmaster, nothing but good things i've heard. I've coached several local friends into the purchase. Now just have to get one myself lol...
I'm impressed with your work and am gaining ideas for my upcoming build. Thank you.
Also interested in the headrest coat hanger should you decide to do a run. Depending on the minimum number you might want to get it started, I could be interested in multiple.
