Jables
Cincinnati, Ohio
The Mid Torque is worth picking up and will be useful with the Stubby impacts
I went with the 1/2" mid torque. Home Depot is having a sale. $199 for the wrench, 2.0ah battery, charger and case. Snagged a 5ah battery for $55 on another site.
I'd hold out, it's only another 2 months until they're out. Get a nice drill and impact driver in the mean time, the impact driver is fully capable of serving as an impact wrench till you get the dedicated one.
Looking at the impact drivers and not totally sure if I want to go m12 or m18. What do you recommend?
ocloc24
Oooh that's a tough one.. I have both lmao. They are both absolutely awesome. Personally I'd say I like the new m12(released about 2-3months ago) the best, it is insanely compact, barely bigger than your hand, and it has some serious power for its size(110ft/lbs). It is so tiny it feels like an extension of your hand. See photo
On the other hand, the M18 is an absolute beast, and still very compact. The first time I used my M18 impact driver I had a cheap bit in it and was driving some screws on mode 3(high torque). When I got done and took the bit out it was as twisted up like crazy. Also, as much as I love the M12 Fuel drill, the M18 drill is def far superior. So I'd say your best bet is to go M18 for drill and impact driver, unless you're trying to save as much money as possible and don't really care about the extra power.
One other thing to think about.. they did just release an updated drill and impact driver(M18).. July release also. But it isn't much power difference between current and new model. I'd go M18 if I could only do one personally. Then you'll have M18 and M12 batteries, giving you more options down the road.
Tduby
Da U.P.
I looked some but I don’t see price or time frame on the backpack shop vac anyone else read or see something.
tonync
Concord, NC
OK, My Dewalt 18V batteries are dying. I figured just buy a new kit. the Dewalt 20v kit is on sale for $99 and i found the Milwaukee M18 with the drill/driver and impact kit for $149.99 I called and was told it was not a refurb but new from my local Ace. I use this for home repairs so they seem to last me a few years before the the batteries die. I realize this is a Milwaukee thread however I figured you guys will give me the right info
DFB
Southern VT/Western Mass
Milwaukee warranty 3 year on XC battery packs, 2 yr on compacts, 5 yr on tools.
chrisnazzy
Arizona
In 2010, I bought an M18 drill/impact kit that came with (2) 1.5ah compact batteries. I've purchased a dozen other M18 tools since then and upgraded to Fuel drill and impact but those compact batteries and those brushed tools still work flawlessly. I doubt you will need to worry about replacing batteries in a couple years if you switch to Milwaukee.
DFB
So who seen that other thread where someone had issues with the 18v Milwaukee drill/driver clutch setting on exceptionally small screws. :headscrat
I never gave it a thought much as I don't normally find myself driving home such small fasteners with a power tool like an 18v cordless though my old Makita certainly had a certain finesse to it. Things like setting door strike plates and bolt retaining plates and door hinges have to go pretty easy or you will strip out the screw or split the jamb frame anyhow.
I think most people just drive deck screws with them anyhow :lol:
Caused me to run a few bench test with both brushed and Fuel in both platforms M18 and M12 in soft pine. All non impact tools M12 Fuel 2 speed screwdriver hands down seemed to have the lightest of settings and worked fine even on my smallest wood screws. The Gen 1 Fuel and brushed 2607 drill were both ok with a #8 inch screw setting it flush on a minimum setting #1 but any smaller than that 3/4" #6 didn't offer enough resistance to kick out the clutch.
Still the old Makita for the overall size of it has an amazingly light #1 clutch setting Gave me a new outlook on an old tool :D
rmsg0040
Toronto
Thank you sir. I would appreciate that.
Here is a small video from 0-115psi, presta valve adapter is cheap plastic, it looks like it will wear out in no time, better buy a brass one. Trying to do with 2 phones but I would say its about 40 seconds 0-115psi. Thanks
Gonna change my "Want List"...
I now want the NON FUEL 1/4" ratchet. I read a few posts here and decided to actually look at one. Went to the Milwaukee Dealer place and held both. Non Fuel is what I want... the head size is the reason.
I would agree ! The problem with the non-FUEL tools is that the price keeps dropping every week or two. By the end of the year, you should be able to buy a new or lightly used on on eBay cheap !
chrisnazzy
Arizona
Some battery store will rebuild and upgrade thos battery packs for a lot less that what it would cost to buy new ones.
Huh?
My 1.5ah compact battery packs are still working fine. Why would I need to rebuild them. My point was that even after 8 years of use in a home setting the packs still function.
DFB
All my Milwaukee Red Lithium batteries are still in service (and some are out warranty now). And all work just fine still. And I'm not aware of any noticeable differences in runtime or power with any of them.
I never bought a battery outside of those that came with kits and there was so many "free" battery offers in past I still have a few in the original packaging I haven't opened yet and put into service.
Still if I decide to sell an older tool I would look at the date codes and most likely pair it with the oldest battery if I want to make it a kit.
I looked into rebuilding my Makita battery packs several different times and didn't find it feasible. It would have cost more to fix one than buying 2 China knock offs from Amazon which I did and use now. They work just fine too actually better than the originals :lol:
Jables
Cincinnati, Ohio
One other thing to think about.. they did just release an updated drill and impact driver(M18).. July release also. But it isn't much power difference between current and new model. I'd go M18 if I could only do one personally. Then you'll have M18 and M12 batteries, giving you more options down the road.View attachment 768094
The smaller size of the M12 is very appealing. I decided on the M18 2757. I know I'll get lots of use out of it and will find a "need" for some of the M12 stuff. :lol_hitti Already got lot's of plans for the 3/8 stubby impact. Let the waiting begin!
sweet victory
USA
I have a project involving removing the paint & caulking from my siding and redoing. Perfect excuse for buying a Milwaukee caulk gun, right?
kctyphoon
Jersey/Staten Island
I gave up on finding my 3.5" folding hardline knife.. the non folding I bought is gonna get me a free trip to a holding cell if I carry it - so I threw in the towel and ordered another folding hardline..
My m12 Bluetooth speaker walked outta my work van along with a battery, so I replaced them with another m12 speaker, and 2 Powerextra, extra batteries I swore I wouldn't buy again..
Tduby
Da U.P.
I have been eyeing that up I have bad arthritis in my wrist and hand (I guess mom was right about playing with it to much) and I they look awesome but the expense is killing me $100+ for a caulk gun.
mobiledynamics
Gotham City
Caulk blade on a multi works great on removal. I used the Bosch blade. There are 2 shapes if I recall. The one that looks like a cone with a rounded eased end.
Depends on the length of the joint. I debated between the 18 and 12. I went with the 12 as it was lighter and did everything I need.
I like it when doing large joints like control joints.
For windows and such, I still prefer a manual gun . Easier to finesse
DFB
I see the ACME sale today too. What I found oddly interesting was the Gen 1 Fuel 2603 drill AND the Gen 1 2654 3/8" impact wrench CT kit offered as a combo package and along with the worklight ($249)
Chris_the_wrench
Chinook Pass
Howdy all,
Quick question for those of you with the string trimmer. As most of you know HomeDepot has the trimmer/blower/9.0 battery on sale for $299. I've been very happy with every Milwaukee power tool I've purchased, and consider them to be all pro level tools. Is the trimmer on the same level of quality? I have a small organic farm and we use string trimmers for most of the weed control around fruit trees and wine grape vines. We are in the need for a new trimmer and thinking of making the jump to Milwaukee for that also. The blower is of no real use to us, but I'd probably keep it for the occasional use.
I've tried the Ego line of the electric trimmer, and wow that thing had a ton of torque. It was heavy after 45 minutes, and 'almost' too powerful. I already have a good amount of M18 battery packs so I like the idea of staying in that one power system.
Do you think the Milwaukee trimmer can handle 1-1.5 hours of work(with battery swaps) 4-5 days a week for 4-5 months a year? How does the bump advance work? Replenishing line, any issues?
Thanks
Chris
PelicanPines
Been needing higher amp M12 batteries lately... (my nebulizer project)...
Ordered 2 x 6.0amphour M12 batteries for $58 each... it's a 3rd party Amazon seller... fingers crossed...
Watched a youtube on the new M12 3" cutoff tool... it has a reverse to alter the direction of the sparks... I have added that to my "Want List"
Crazyjake8493
Upstate NY
Howdy all,
Thanks
Chris
I think it would work well in your situation. I've only had mine about a month now, and only home use, but I feel it's high quality for a battery powered trimmer. Even though I'm well invested in the M12 and M18 lineups, I checked out the Ryobi trimmer first and compared it to the Milwaukee. The Ryobi was lighter but had more plastic, and felt more like a toy. The Milwaukee feels like a real tool. Solid and sturdy like a gas trimmer.
I sold my Husqvarna gas trimmer and blower to buy the M18 deal and I couldn't be happier. Just as much power as the curved shaft gas trimmer I had. With the 9.0 battery, I have enough to handle about 45 minutes of trimming and then pop it in the blower to clear the driveway and sidewalks and still have one bar left. Or I can go a bit over an hour in just the trimmer and put one of my 5.0 batteries in the blower if needed.
I haven't had any issues with bump feeding line, and although I haven't had to re-wind string yet, I don't foresee having any issues there.
I only use mine for 1 hour about twice per week, but I see no reason why you couldn't use it 4-5 days per week. With two 9.0 batteries you'd be all set for sure, but even one 9.0 and a couple 5.0 is a good setup as well, especially if you already have the batteries.
Jamie V
Atco, NJ
Chris_the_wrench; said:
Howdy all,
Thanks
Chris
Chris, if you don’t need the blower you can get the same deal with the hedge trimmer instead.
https://www.homedepot.com/p/301547330
I love my string trimmer and it lasts a pretty long time with the 9.0 battery. I’m not sure if it will last the whole 1.5 hrs of use (depends how heavy you use it in that time) but a second battery will put you well into your goals.
tonync
Concord, NC
AcmeTools has $150 for 2728 Gen 1 Fuel blower w/ 5ah battery & charger.
I keep trying to find it baretool for $100.
http://www.acmetools.com/shop/tools...pJobID=1281607967&spReportId=MTI4MTYwNzk2NwS2
thanks for the heads up they also have a $20 discount on any purchase over $100, so I got the blower package for $129.00, really didn't need the blower since I have a work 20v that has been great, but basically a free tool with the battery and charger purchase, which I need since I am just starting out in the Milwaukee stuff, and transitioning away from Dewalt and Makita.
takai
Melbourne
Drank more of the red kool aid recently, all of this arrived today:
i.php
NitroGarage
Cleveland, OH
i.php
What's the consensus on the rotary tool? Buy that before spending double on a full dremel kit? I doubt it's something you could port cylinder heads with but would be nice to have for a quick cutoff tool or use with a sanding drum for deburring or sharpening, maybe light polishing?
ocloc24
The M12 rotary tool is probably the best rotary tool you can buy, its hands down the best cordless rotary tool. I use mine all the time on stuff that I probably shouldn't and its still going strong after almost 2 years. I bought a 2nd one just for my girlfriend(her nails and the dogs nails).
a52-830
north of boston, massachusetts
i was just using mine last week. everything a dremel offers, with no cord, and no separate charging.
of course you can get the job done for less, but that isn't the point, is it?
