dacan23
RI
Finally got a long desired upgrade. Traded a bunch of things for the OK model. At least this tool won't be outdated with a new model anytime soon. Boot fits it better than non OK model, sadly the 2767 case needs slight modification to fit.
2manytools
Mt Pleasant, MI
Are you talking about the hard-case? I know on the previous 2763 model, if you took the boot off, it would scrunch up and fit in the case. I don't have a case for my 2767, so not sure if there is enough room still.
jd_1138
NE Ohio
dacan23
RI
Yeah the 2767 hard case, the right model does not fit in with boot, no model hard case does with a boot on. You can see the impression of what to mod in the case to fit the OK model it.
You know how on the 2767 the boot has a bigger notch than whats in front of the trigger, thats because the OK model needs the bigger notch.
2manytools
Mt Pleasant, MI
I only have the 2863 & boot, so guess I never would have known. I thought all OK models were only different in the internal electronics. I wonder what required different molding there?
While look at the pics on HD, I notice they raised the price of the 2767 $30 to $250, and $20 on the 2863 to $300. It looks like a few other retailers have followed in that, but most haven't. I'm a little surprised as the 2767 was $200 w/ free 5ah lat month at HD. :confused:
Vette10R
MN
They've been out for over a year, along with the 6.0 XC packs. And yeah the price is crazy high. I can pick up 6.0s on ebay for the price of a 3.0 pack. I'd like to have one or two for my heated gear but not at those prices.
I don't notice any extra power between the 4.0 and 6.0, you'll just get longer run time. Is it worth it is only a question you can answer. If you have plenty of 4.0s already then I wouldn't bother. But if you need more batteries then I would get the 6.0s.
My current battery is just an XC which I think is considered a 3.0 according to their website.
I'm wondering if upgrading to the 4.0 or 6.0 is better for longevity of battery life and if it's worth the extra money to 6.0 vs 4.0?
2manytools
Mt Pleasant, MI
Overall lifespan should be the same, the only benefit is run time. If you want a 6.0, look at the HD special buy of the day, where you get a 6.0 & a compact 3, which is a really good deal. The compact 3's never/rarely go on sale
Vette10R
MN
Is the compact 3 comparable to the XC I have right now as far as run time?
2manytools
Mt Pleasant, MI
Run time yes, potential power no. You will want to use a XC battery in higher demand tools, like the hackzall, circular saw, or higher torque drilling.
The most talked about use of the compact 3.0 is heated gear, as you get the benefit of longer run time, but not battery size. A lot of the heated gear might have the room for a XC battery, but not as comfortable wearing (or at least sitting w/ my jacket).
The XC has 2 sets of cells compared to 1 in the compact batteries, so the higher demand tool can potentially draw more power from an XC pack. Splitting the power draw from two sets, will keep the battery running cooler in demanding situations.
Vette10R
MN
Thanks for the explanation I appreciate it! Since I dont use heated gear I dont think ill benefit from the compact3. I might be better off getting an XC4.0?
MikeF2316
Thornhill, ON
Yes... Astro... I have not put a lot of mileage on them yet... but they feel as solid as my other Impacts... I only own 1/2" impacts... The nanos are brand new in my box... only used 2 so far with the M12 Stubby... worked like a charm.
My Astro sockets came in today. I think someone had a question about engraving sizes as well as the etching. You can see that the etching is uniform, whereas the engraving (actually stamping) is not.
And to stay on topic, I used the 2554 stubby to change to snow tires on the Infiniti today. The "4th Mode for Precision Fastening" comes on too early. I ended up putting the lugs on my old fashioned way - a green (50 ft-lb) torque stick and feathered trigger until tight, followed by a torque wrench.
I couldn't try out the new sockets, the lug nuts are 21 mm, this set only goes to 19.
PelicanPines
21mm is my most used impact socket... total reason I went with the 1/2" stubby and nanos...
I have dedicated lug nut sockets so my mind wouldn't allow picking a nano for that.
Etching wearing off is a long term worry but I'm too happy with them as it is.
dacan23
RI
Doubt Milwaukee will ever make one of these.
https://www.makita.co.nz/products/model/DVP180
It would be such a low volume seller. I dont even have a vac pump, thought about buying one once again earlier this year when I changed the compressor on one of my cars. Just willingly got raped for a $180 recharge.
Wish there were specs on that Makita, how much bar can it pull over what distance.
PelicanPines
I needed one in the spring... couldn't find the funds... Now i'm so not gonna go "green" Makita too...
If Milwaukee made that... I'd buy it in a heartbeat.
MikeF2316
Thornhill, ON
I would imagine I will only use the nanos when I need their shortness. Their walls are a little thinner than my others so they will be used in that case too.
Now with a 7mm socket and a 250 ft-lb impact, I can make sure those pesky European hose clamps are properly tight! :lol_hitti
PelicanPines
LMAO... I break those hose clamp nuts with my "manual nut driver" and my left hand...
It's like 1/4" impacts... uhm.. for what? Really... not a rhetorical question...
dacan23
RI
LOL, I use the old 1/4 M12 ratchet on hose clamp nuts... its weaker than my left hand...
Bigblue&Goldie
I just jumped into the cordless toll game for the first time in about 15yrs. I liked the build quality and batteries from Makita, but ultimately Milwuakee puts out better tools geared towards mechanics. This will just be for home use, so I decided on the M12 line.
-Reconditioned M12 Fuel 3/8" impact (Bare Tool) #2454-80
-LED Work Light (Bare Tool) #49-24-0146
-M12 REDLITHIUM XC3.0 Battery (2-Pack) #48-11-2412
-12V Wireless Jobsite Speaker Kit with Battery and Charger #2592-21
All for $292 shipped from CPO.
Down the road I'll probably pick up an M12 Stubby 1/2" impact.
DFB
Southern VT/Western Mass
2manytools
Mt Pleasant, MI
It's baaack for Holidays!
Ace is the Place...as they say :lol:
The 2494-22 combo just $99 :D
Great small setup for the home/handyman. And good $100 less than a fuel combo
2 of my very first M12 tools, the drill/driver is plenty adequate for small projects and the impact driver is simply bullet proof
(I have 2 of those) :lol_hitti
https://acehardware.shoplocal.com/A.../ByBrand/?StoreID=2433631&BrandID=-2099999897
I would suggest going to HD, and use either Ace coupon available there that weekend on that kit. Ace for sure won't take the coupon for it (programmed into the computers), but shouldn't have an issue using it at HD.
The Fuel is going to be on sale for $169 at HD, and often when it is at $200 it comes with a free tool. The extra $100 isn't so bad when you consider you get better tools, much better batteries, and another tool.
DFB
I thought their mailers didn't get much love around here or did they improve them?
It's only bare tool...one time Kits went for $249
I have say AGAIN I have the 16 ga. angle nailer and it works fine. Ya if u play around bouncing a piece of wood on table or floor it bounces and more often than not won't set right, but push it against something solid like framing and it sets just fine most all the time, knots or hitting other nails withstanding. I was using 2 1/2" galvi fasteners and its one solid connection,
You might bust the sheetrock trying to pull one back out if your not careful! :lol_hitti
DFB
I don't buy jack from HD if I can help it
but thanks for the input
Its a good deal for those that want it
2manytools
Mt Pleasant, MI
Not the love their other tools get. The Ryobi's are actually highly praised, partially due to how well they perform for the money. For how much I'd use one, I'd probably go that route.
sweet victory
USA
My 3/8" Stubby came in this afternoon. Here it is compared to the M18 compact 3/8".
9fkSmNFfuJjR9Lfe2xonJt1vwmkXhMsnwq9NoxMc23zT5GZr9npUAFDmvq-C-HtlXKesakrlAiU0nq1N6djp01ev2J3LLlkXP50kS-W91m20SMCA9pCUfBvK6dpuYutPzKmhoFEdUoIFeGy7UnlTy-mUgQDcGlecYnMs303nMQ05ENUURGxKKbpeTYBqF4Pupdsdbels9-YUsRsWI2k5B0cF0GGP_A6Cqlh7wn_7KWCxjPDkuV---XMuJVIX2dUSHEWvCNND96yDHktrzN00-cUrGB3q55hfIjJYb55uMueM4aLKFEwH7NkUy_jLjjwKKg_jarBnj-uvyjFURAgyOOcm1Whl0N9te8R55W2WVbJFXNUTTNjdA8LFW2-4pgH_HALPeM9oi3iOhtg_Nwv0HE62RLwRgr2qxHoJUzGHV6KnzdG186t0mwHHbHpgLe_Bw648piKPDgEzUu3Ppe4zBzEq5Pp0mYFY954nIrGer15k5BXxBHE29juglzIcnk4SihTbblOtVLRXmj0t9cPvruL6rwvFuPjQeLo8_aZwGCwP1CJrZIulDqrXMFM2suYlQCDaC1ovycAXro7U17e4csWwle73vW7Muc3Um23QtYCZDmPjrQzWJeewFfh8ck71cV_8b1XAomf26ruhisnYIM4ixhEGn148aLs1iu9gi3DXUYiqaZulyhhmbgH0q5ar7L0KDRWcXBI=w1718-h1146-no
CWBSHsEq294TizpyA05cfYqF4tW1wPy8pw5vZfnXqheQ_cz2nEKJ-eZhImuNmAcQVlqJ2PTQZuqcF80V8ruU-QDdHTf_8JoXca2e_10-0Bg6aITWNbk_EajWlXA-HrBF_YebWUUZq3ABdUr81rUS6e49sNp7x88OTbhWQd0b_ou2nYfmMoPClKiyvLUHCWL3lDKhCwmLTTcF7enomD32HxEatrWmxDc9sIaBXBILib95Rbw0BUGUhOIKG4bTkiNLyFFX0fU0J4pMgixfCSHQBxtrwDt38CsvzmavBWyGWrHko6xEUH6YqlEaMnueTGwisx1DQS678Pdxo0GU4XA2qb6bK6JlkH2T6RSZMvEP9Ururaln9V1G5kJc7Wxdm6ywymDfgfMjnvXKGjgUilmnptNys1O829V9-r53mHZaEpxqKA7-bX4-4jUHv9GFB7BWtayZAMAT93_Z-x7RnuyVfDMrl7axHHh1SHm4mvrZX9ssIZ4VCh8CfZOaUQMCOtvntdR3qNKxgNV3B_5APQSH_FG_nPBpTG6CSCYq_EpCea_NwHixiiX_P-R--uO8vjHk3gUutb8yzX4NNcuUUtsaEb4Ysizxt08ChU8Gb1jtxL0MX6MVCeLWI_LJ47PQe79YfmyV_6GITGbdc_cX4KhOnlb4G7WQajx2wqI2GanVKyc1ZA45J53fZZtl1QyyejISEIbo0c5kjOU=w1718-h1146-no
dsimatt
Yeah it's tough to justify the cost right now, I have some projects in the future but probably will go the air route.
dsimatt
Dude I edited my other post and laid out MY opinion after using it.
2manytools said it good...they don't have the love other tools get! :drool:
Sorry I missed that, thanks for the info on them. I keep checking them out at HD but they are sure proud of them.
Crazyjake8493
Upstate NY
I'm in the same boat. I already have quality air nailers, and I really don't want to spend hundreds of dollars getting all of them in battery-powered too. I'm thinking about getting either the Ryobi cordless compressor or the little 1 gallon Senco compressor, and continue using my air nailers.
If you want to go cordless, I've heard good things about the Ryobi nailers. Hitachi's cordless nailers are top of the line, but they cost at least as much as the Milwaukee nailers.
DFB
I have to say and it doesn't matter which brand they all are much bigger than similar ga. air tools but the Milwaukee IMO is a bit more narrow and the whole design is different. I looked long and hard at the Ryobi and RTR spoke highly about in an OLD video. I just like the Milwaukee better fit form and function and I really wasn't willing to step outside that line. Plus the guys from OZ used them extensively doing remodeling in several videos after they first come out and they performed well. As did Concord Carpenter.
They also gave subjective opinions on the tools
Interesting about RTR (and let me say first I was ALWAYS sold solid on his impact wrench test results) I have to consider that one opinion with the Ryobi and how people just bought that hook line and sinker but when he shows how HF breaker bar stands up to the big boy brands in testing it's like no one believes it! Que sara sara :lol:
But I think what really cinched it for me though was when AvE took one of those Ryobi guns apart..
Even funnier was when he couldn't get it back together right
The 18 ga seems to have the most issues I wont hesitate to say maybe stay away from that but enough peeps on THIS forum have the 16's and the 15 ga. nailers with no complaints that I know of.
My sugesstion Keep your eyes peeled for the kit on reduction special :beer:
DFB
I'm really really wanting Milwaukee to do a cordless twin battery small tank style compressor similar to the Ridgid unit :thumbup:
