DFB
Southern VT/Western Mass
All right one more related SDS question today...I see the "installation sleeves kits " for SDS drills to use while for the TAPCON concrete screw. And looking around the web some, a minimum of at least 4 choices out there, including the Milwaukee brand.
Now I have snapped enough tapcons while driving them in over my time to want to avoid it at all possible, proper hole depth and size is critical of course and do I know some people use impact drivers to drive them now rather than just a drilldriver
So I guess my question is when you run this sleeve attachment over your installed bit are you going to keep in the rotary impact mode or switch over to drill only.
All they really show in the quick sound bite video is sliding on the sleeve and next driving the fastener :dunno:
ThatSickRip
Ive used them on my hammer drill for Tapcons in the garage and basement.
Use the bit
Vacuum out the dust
Put on sleeve
Use drill on drill setting
Havent had any issues this way. When I was just drilling holes, not cleaning the dust and then using an impact to drive the Tapcons, I broke more than I care to admit :lol_hitti
Bighead38
Rockland County NY
Bag is starting to fail.
dacan23
RI
Common problem cause people only zip them half open and constantly tugging on the front etc. My buddy recently replaced his that tore in the same spot with the packout version and complains how its too big and bulky on the bottom end. They still sell a few non packout versions.
Bighead38
Rockland County NY
Yes back pack version. Bag never gets moved around much anymore. Even when it did the Only way it ever gets moved is by the top handle, gets put down and opened up.
toolmutt
Texas
That's from being too full. Stresses that seam when you zip it up. Only solution is...(since this is Garage Journal)...more bags!:lol_hitti
BMack37
Based on the design, I don't think you'd have that issue with the Veto. Veto is more expensive but if the Milwaukee doesn't hold up as long, you're spending more having to replace it.
The Packout also look like it would hold up better to overfilling but I've seen less of those overfilled.
Bighead38
Rockland County NY
Upgrading from bags. It’s almost too heavy to carry.
Lol packout is on the way don’t worry. I really hope the radio is good.
PelicanPines
Exactly what I did. Mrs Pines got a free bag with something. My M12 hammer drill, spare battery, 3 bit boxes and my M12 hex driver all reside in that free bag now. My backpack has stopped screaming when zipped.
It's funny how having two bags has improved things. It appears jobs either require JUST the free bag with the M12's in it with the bit boxes... or the job requires both bags...
RKA
I can’t bring myself to walk around with my wife’s free baby blue Lancôme bag tucked under my elbow. Maybe when I need a third bag! But good for you! :thumbup:
mc4life27
But regardless if the bag is over stuffed all the time even the ceros will tear. They even say not to over stuff them on every item there is a little *
Bolster
Mexifornia
Am I the only sewing dude on the forum? That seam needs to be triple stitched if it's prone to pulling out -- is it?
My thinking is, if you design a bag to carry tools, then ya need to beef it up until it can handle what people will inevitably carry in it. The fabric itself (ballistic nyloon) can handle a lot of abuse. You guys go ahead and blame the user; I'm pointing my finger at the design on this one. Have your Chinese sewing wizards beef up those seams, Milwaukee. Need another row or two of stitchery, and possibly a foldover hem on the edge of the fabric (or a hot cut) so it doesn't fray and let loose.
Bighead38
Rockland County NY
I know I have a lot of weight in the bag but it’s designed to carry tools. I don’t even carry the bag around it just sits in the garage and gets carried ten feet to the wall most of the time. I feel the same as you especially hearing others have the same problem.
DFB
Now THIS type of design was what I had first envisioned from Milwaukee when they decided to do a M12 cut off tool.
https://toolcraze.net/metabo-powerm...WsJXnNKy6ax_3UH3LNaF-AkD-RQbVC9YpiApJHWnPH-RM
I do have the 2552 myself and have to admit the accessory package that came with the Milwaukee unit base plate attachment and dust collector chute is a extremely nice feature
Kind of surprised the Milwaukee cutoff tool wasn't even mentioned over in a current sheetrock thread along with the many other power tools being suggested for certain cuts considering the vac attachment :thumbup:
Q. Being I'm not all that familiar with a lot of grinding. Does the metal working industry even market a depressed center 3" wheel? :headscrat
Billy Jack
Pittsburgh Suburbs
Well, I guess it's time to subscribe to this thread, as I just jumped into the Milwaukee cordless rabbit hole. I currently have both Bosch and Dewalt cordless stuff, but Milwaukee just made the most sense, considering the wide range of tools available for future expansion of my cordless arsenal.
I recently purchased the combo kit on sale at HD, with a 3/8" M12 ratchet and a hi-torque M18 1/2" Impact Wrench for $199.
My question concerns battery life; The M18 impact came with a 3.0AH battery. I'm just a weekender, not a pro wrench. A tire rotation or brake job would mean 4 wheel removals and re-installs, with wheel nut torque requirements of 105 ft/lbs. max.
Would that battery get me through a night's work, or should I supplement it with something larger? I'm sure that as my collection increases, more batteries will appear, but am I OK now for a night's work between charges?
I started many years ago with a 9.6v Makita drill, then to 14.4 and 18 volt Dewalts. As the power increased, so did the weight and bulk of the tool. I find myself using my 12v Bosch drill the most, 'cause it's just so light and compact. I'd like to keep my impact and ratchet just as small and light as possible, while still having adequate muscle for the job.
Bill
DFB
Bill
You will be just fine...I R & R'd all the lugs on my pickup truck with a mid torque and 2.0 and still had decent charge left
Check it out here :lol_hitti
https://www.garagejournal.com/forum/showthread.php?p=7145244&highlight=mid+torque#post7145244
Since you mention the 3.0XC battery and High Torque/ratchet pkg that would the 2663 impact wrench
RKA
Billy Jack, use it and you'll feel silly even asking the question! (that wasn't made to make you feel bad about asking, just to reaffirm what DFB says - once you use it you won't give it a second thought). I have a 3.0 HO battery on my mid torque and I don't remember charging it all year. It's probably removed over two dozen tires.
Jamie V
Atco, NJ
Bill
Did you get the M18 Fuel High Torque impact or the brushed non fuel one?
Bighead38
Rockland County NY
I agree. I keep the 3.0 in the mid torque. It’s the perfect size for me.
Tbird22
Looking into a rotary hammer. Aside from motor location, what is the difference between d handle and l handle? What are the pros and cons of each and why is the d handle less expensive?
Billy Jack
Pittsburgh Suburbs
I got the non-fuel combo. I primarily wanted the 3/8 ratchet and the fuel version was much bulkier. At $199 for both ratchet and impact, I couldn't pass it up, even if old tech. The dual 12v/18v charger was another plus.
Thanks all for the info.
When I see all the variations in battery AH ratings, I was just concerned that the 3.0 was enough. Milwaukee's bigger batteries are quite pricey.
All 4 of the family fleet cars are set for winter with tires, brakes, fresh oil etc., so I have no pending jobs yet. I'm looking forward to not dragging an air hose or extension cord (have both in 1/2" impacts) around jack stands and other obstacles in the garage.
Bill
DFB
Normally the "L" shaped handles offer the option a one handed use its a more compact form. The longer "D" handle tool would possibly be more difficult to use especially on a ladder or high lift platform reaching out for horizontal and overhead drilling. Though for boring or chipping in a downward direction is probably the cats *** :D
Not knowing what two models you are comparing is difficult to say why pricing may be less on model than another. The Rotary hammers do come in a wide range models either PLUS or MAX and generally based on bit sizing.
https://milwaukeetool.com/Search#q=rotary hammers
DFB
Well my 2416 FUEL SDS got delivered to me tonight :D
And also my Motorcycle Shop owner pal M12 grease gun package that I purchased for a Christmas gift :beer:
With the 4.0XC the SDS tool is sooo much lighter than my M18 FUEL hammer drill with an 4.0 XC. More than a full lb lighter. 4lb vs 5.1
So I opted to invest in the MX4 bits over the M2 though they cost twice as much the life on them is supposed to be fantastic according to reviews after cutting into rebar. Also picked up Milwaukee's OSHA compliant dust trap for use with vac or without vac. Was only $10. Could come in handy
Just on an off note I just realized that the zippers on FUEL bags have metal pulls vs nylon on similar bags packed with the brushed tools...go figure just another upgrade when purchasing FUEL products :pimpflash
M635_Guy
NC
I have to admit I like the look of the M18 circ saw - I have a Makita worm-drive that's way more than I really need. Might pop it on Craiglist and if I can get $75 for it I'll grab the Milwaukee...
1TMF
I got an M18 circular saw (brushed 6 1/2" version with the blade on the left) free with a kit and I was planning on selling it because it wasn't a brushless Fuel...until I used it once on a whim. Now I love the thing, most recently used it to rebuild my entire deck. It didn't skip a beat. Even if you're a ******** DIY'er, I'd say the brushed version is completely adequate.
kctyphoon
Jersey/Staten Island
Guess whos back...
With a No Days off Milwaukee hoodie and Milwaukee balaclava..
This thing is not what I thought it would be. The material is very strange.
To save my life I can’t find my other two heated hoodies, only the version that came with the 3in1 jacket.. I’m beginning to think I left them in a vechile at my previous employer.
BMack37
kctyphoon
A few people making 3D printable stuff:
https://www.jakeofall.com/packoutparts/thin-bins
1fmU2kz4jgKKKfTl9kAsOyXyujluQffCNkEZLvXpdvjLa-8suFv8Z6LieVlvoZpeoyi0GISPKNa5p51QBpWo8X7OJszJbIxzda8oT63EEE9J3KRer58=w1280
13cI4hm_X5Nxb3YZ014Q5v5-p8Y4jRj6R3OQPYw5iH1hwk15wMgRXXf0nrMoPduuHsCeht1piv1hR1GRSekkwN0mhSHpAPAovNshy_g0SIxjpSFrK_0=w1280
There's a third I follow on IG but I don't have their site saved. Then kaizen makes custom foam and printed feet and locks that adapts something else to work without packout.
That guy should make a power strip that attaches between those cord mounts.. or better still, a strip of holsters that will hold some drills & impacts ..
A cup holder that can attach like that seems like common sense..
