shakenfake
Shlumpt, TX
My M18/M12 basic battery charger just died the other day. Doesn’t charge in either slot. Stuck with using my M12 charger only right now and hopefully my M18s don’t die lol
darkzero
SoCal
Around here so many people sell them locally for cheap. I wanted a second one to keep at work & didn't want to spend the time meeting up with someone. Can get them cheap on Amazon & ebay from people selling them from broken up sets.
I bought mine from Amazon because Prime, free & easy returns if there was a problem. I got mine new for $23 shipped but the same listing right now has "used" ones for as low as $16 shipped.
Shaners256
Milwaukee
So my MX breaker arrived in the mail, broken. I didn't have time to open the box up and get it all assembled/tested for a while so now its up to me. I called Milwaukee about it but since I bought it off ebay they won't warranty it. I kinda expected that. What I didn't expect is there is no parts diagram or replacement parts for it. The lady I spoke with told me that its because it is a onekey tool and all the onekey stuff has to be fixed by the authorized repair center.
Now I've checked out the tool and I believe I can repair it by putting a dowel pin into the switch that broke off in transport and it will work as long as its the right length. I haven't verified this yet. I need to plop a battery in the breaker and try pressing the switch in live but when I tried it without a battery using an allen key, the switch make the cachunk-a-chunk sound when it moved in and out. I believe the part that broke off in transport is just a piece that sticks out and the rest of the mechanism is fine. I'll find out later this week.
Milwaukee knows this is a weak spot and ships a protective plastic cap on top of the switch. I'm surprised they don't have a spare part available for it, specially since the handle is plastic. If someone lost control of the breaker while it was running and the handle hits wrong, its going to break the handle and PROBABLY break the part of the switch that sticks out at the same time too.
If the switch is bad, challenge accepted. I doubt I would need to replace the whole onekey assembly to make it work like she claims. I've got a soldering iron and I kind of know how to use it. If using a dowel pin to fix it doesn't work, expect to see photos of the inside of an MX breaker next week.
What is the manufacture date on the serial number? There shouldn't be any reason to deny warranty due to Ebay unless it's out of warranty date.
Rusty67
LA, CA
That is exactly what I told both people I talked to but they were both dicks about it and said that Milwaukee won't cover the tool at all unless purchased from an authorized reseller. I tried using the eService portal first but for this tool it tells you to call in.
turtleman321
Harrisburg, PA
so just call back and tell them you bought it from an authorized seller. They dont need a receipt.
Rusty67
LA, CA
I'm thinking that is what I'll do if I can't just put a pin in there to fix it. I really don't want to deal with shipping this thing back to them if I don't have to.
Dh3256
Most warranties are for the original purchaser from an authorized outlet only, they don't cover resales or unauthorized sources like Ebay. Effectively everything sold on Ebay has no warranty.
Crazyjake8493
Upstate NY
Not true. There is always a warranty regardless of seller, but if it not from an authorized seller then you're going by the date in the serial number on the tool. Your warranty will start from manufacture date rather than the date of sale, but it will still be covered if it's within the warranty from the date of manufacture.
Dh3256
Sorry, the facts I posted are correct. If you read the warranty terms for nearly any warranty, they will clearly state the warranty is for the original purchaser only, from an authorized source. In the Milwaukee warranty it is the first line in the warranty "Every MILWAUKEE hand tool is warranted to the original purchaser from an authorized MILWAUKEE distributor "
How often they enforce that restriction may vary, but for nearly any warranty in the US the warranty applies ONLY for the original purchaser when purchased from an authorized seller. So nothing you buy as resold and essentially nothing bought on Ebay will ever have a warranty.
Rusty67
LA, CA
I don't believe this is completely true. If you buy from an authorized resellers eBay store, the warranty should still apply. If you buy from a non-authorized reseller on eBay, then sure.
Rusty67
LA, CA
I've used mine a handful of times now and I like. My only complaint is I feel like the bag is a bit small. Feels like I needed to empty it more frequently. Then again, with how easy it is to start mowing again after putting the bag back on, it isn't really that big of a deal.
Crazyjake8493
Upstate NY
Still not true. Perhaps I wasn't clear enough.
The seller and however many owners the tool has had only applies if you are utilizing the purchase date for the warranty.
If the the tool is still within the warranty period based on the date in the serial number, then where the tool was purchased has no effect on the warranty claim. The tool may have been sitting in the store/warehouse for 6-12 months so you won't get the "full" warranty, but the warranty does still exist.
I know this to be true because I've warrantied two different tools for which I'd lost the receipts (one from eBay), yet they were still within the warranty based on the manufacture date.
This is not applicable for reconditioned or refurbished tools, as they have been etched at the time of remanufacture.
EDIT: This is a direct copy and paste from the warranty terms on Milwaukee's website -
"Warranty Registration is not necessary to obtain the applicable warranty on MILWAUKEE product. The manufacturing date of the product will be used to determine the warranty period if no proof of purchase is provided at the time warranty service is requested."
Dh3256
Agreed, if you can find an authorized seller on eBay the warranty should apply, and there probably are a few authorized sellers on eBay, but most sellers and resellers on eBay are not authorized.
Dh3256
Your statement is false, per the warranty terms and conditions. I thought that was clear from the Milwaukee warranty terms I linked that specifically state that, but perhaps not. Regardless, Milwaukee warranty applies ONLY TO THE ORIGINAL PURCHASER and when purchased from an authorized seller.
Also false, if not the original purchaser or the tool was not purchased from an authorized source, there is no warranty.
Their willingness to waive the warranty requirements as a customer service adjustment does not change anything, you simply got them to service tools that had no warranty. Success in cheating the system does not change the warranty terms.
This is a detail of their procedures, as a convenience they are not requiring proof of purchase for warranty of tools for the original purchaser from an authorized source. They are trusting customers not to cheat the system and take advantage of their liberal proof requirements.
You are probably not the only one taking advantage of their policies to get warranty service on tools that do not have a warranty. They expect some number of invalid warranty claims and factor that into their business model. If too many people cheat the system though, they will have to tighten their policies and be more strict, as most retailers with liberal return policies have had to do.
TLDR: Some people have been successful in getting Milwaukee to warranty repair or replace tools that had no warranty, but the Milwaukee tools warranty applies ONLY to the original purchaser of a tool purchased from an authorized source.
pbon
Coming up on mowing season here in the north east.
Milwaukee Mower. Yay or Nay?
I bought on sale for $699 with double charger and 2 of the 12ah batteries. I think it is worth that — which is $350 for the mower after subtracting $150 each for the batteries and $50 for the dual charger. I would not pay much more.
Dh3256
Not arguing that, I was just correcting a specific section of what he posted.
My post was correct, you just expanded what I said a bit. As my post said, "So nothing you buy as resold" will have a warranty, and since nearly all sellers on eBay are resellers essentially (but not literally everything) sold on eBay will not have a warranty.
I will try to be more specific in future posts and try to anticipate and avoid possibilities for misinterpretation of sentences.
Odd-job
Hopefully Milwaukee doesn't go the way of the warranty weasel companies. Based on the original purchaser language sounds like warrantying a gifted item could be painful. Milwaukee is pretty much all I buy my parents for father's day, mother's day, bdays, and anniversaries. I have a tough enough time dealing with their senior/temporary marital issues and they live across the country to deal with warranty snafus on some of the Milwaukee stuff I've bought them.
Odd-job
Yay for me, but not for the $1000+ MSRP. I have two small patches of grass and a decent amount leaves. It does a fine job cutting and really gets the clippings fine on high mulch mode. It has some nice features that I mentioned in my earlier post. I also realized I am an idiot and didn't have the walking speed setup right, the self propulsion can actually really move it. You can also engage it when the blade is off.
Rusty67
LA, CA
You seem to want to get into the nitty gritty of what is written and yet, you only posted part of your sentence. Don't forget about the second part of it, "and essentially nothing bought on Ebay will ever have a warranty." That is the part I was speaking to. Call it what you want, a correction, expansion or whatever. That statement was not factually correct so I added the conditional information to it to make it right. The goal shouldn't be to be right, the goal should be to find the correct information.
Dh3256
Not worth arguing about, but my statement was factually correct and it is true that "essentially nothing bought on Ebay will ever have a warranty.". Not to argue with you but just supporting the goal of sharing the correct information.
As you noted and my statement includes, if an authorized seller sold on eBay to an original purchaser, that purchaser would have a warranty.
I'm curious if you have been able to find any authorized sellers on eBay though, I have not found any currently.
Rusty67
LA, CA
Zoro, Factory Authorized Outlet and ACME tools off the top of my head. I've seen others in the past. I've even seen eBay sales that allow you to save extra from the authorized resellers in the past as the coupon is from eBay and it doesn't impact what the seller makes.
mobiledynamics
Gotham City
I'm more a Fenix in flashlights but I looked at the Milwaukee Pivoting. Mainly for the pivoting and magnetic base...
Magnetic base was a bit weak
Who else makes something like this bit is *better*. Mainly for doing surveys, magnetic base to add as a spotlight and actually using to to connect to something metal when snapping a pic,
Odd-job
What is the distance vs size of the object? Would a floody work?
Since this is the Milwaukee thread - the M18 Rover is pretty good, but not exactly pocket carry:
I love sticking it to the back of my utility trailer when I have to back up in the dark.
Dr.JohnnyFever
A big +1 to this! I bought one on a whim and I love the thing! Between the magnet and the clamp, it great for when I am up on a scissors lift. My wired LED work light doesn't get used anymore.
I also use it for stuff around the house - water heater closet, out-building that doesn't have electricity, etc.
mobiledynamics
Gotham City
I was thinking something more -pocket- sized - walking the site for use case. The magnetic base is where it was at for me.....I have *alot* of Fenix. Some go the whopping
Rusty67
LA, CA
I REALLY like this little guy:
My main complaints are that the charger is USB micro instead of USBC and I wish the magnet was a little bit stronger. The magnet is strong enough to hang vertically off of just about anything but trying to hang it horizontally in a wheel well has never worked for me. It also doesn't do well with round surfaces like tie rods, tends to roll off. Overall I do REALLY like it though.
carmantl
AND when (not if) the magnet falls out of the clip Milwaukee will call it abuse and NOT warranty. I'm done with Milwaukee **** flashlights!
Rusty67
LA, CA
I don't have any traditional Milwaukee flashlights but I've yet to have a problem with a single one of my lighting products. You'd have to break this thing pretty bad for the magnet to come out, its underneath the molded plastic clip. Maybe their traditional style flashlights are bad but can't say I've run into that with any of their other lighting products.
Odd-job
Check out the Olight Arkflex. Can't speak from personal experience though. Have an Ark sitting pretty in its box still from a Black Friday deal.
mikeinri
Ditto! I have two of these, use them all the time.
One of my primary uses is on top of a Trac Vac, for cleaning up leaves in the fall after work / dark. The magnet is great for holding it in place.
The only thing I don't love is that they run best (for my usage) with a 6AH battery, but those extend awkwardly from the housing, and make it tough to use the magnet.
Mike
