mikeinri
The 90° adapter has been in the original bag for years. Well, it paid it's rent this weekend. A drywall seam was behind the furnace and I didn't expect to get screws in the whole length.
The standard tool is pretty handy on its own. Working in the tight quarters made me appreciate it more.
What tool / kit is that?
Mike
mikeinri
Thanks. Looks like there's a deal at HD through Saturday (kit on sale with battery, charger and free tool).
I'm not overly impressed with the free tool offerings (already own M18 inflator, oscillating multi-tool and 3/8 ratchet).
Might try the blower?
Mike
SouthernIllinois
Added a M12 drill today.
All the yellow is slowly getting replaced and moved into the house for “honey-do” type stuff.
Rusty67
LA, CA
Its shocking how capable the M12 fuel drill is. I still use my M18 drill for a lot of stuff but the M12 has only failed when I was trying something I knew was beyond its capabilities. Its even put some hole saws through 2x4s that it shouldn't have been able to.
gamp945
I'm predicting that Milwaukee announces new TABLESS M12 batteries at the pipeline event on August 21st. Quote me if this comes true, or to make fun of me if it doesn't :p
danski0224
Near Naperville, IL
Happy to say that with the exception of a couple of batteries, I have not bought any new Milwaukee power tools in a while. Not sure if +/-$100.00 in hand tools counts for much (IMHO, it doesn't).
assassin10000
I did recently buy the newer angle grinder. I wanted the extra oomph for 3" accessories.
I am waiting on the new compact 3/8" m12 impact. Supposedly gonna be out next month but I wouldn't be surprised if it doesn't really become available until Nov.
ThatSickRip
I just picked up the M12 3/8" Gen2 stubby. I did the HD hack and got it for $120. Not sure if the mode changing method with the trigger is a good or bad thing. Will have to use it to make final opinion.
And its page 666 :oops:
Gangly
The Woodlands, Texas
You're gonna love the stubby! It's a favorite of mine and fits into tight spaces.
assassin10000
Is the Fuel high speed, extended reach ratchet (tool only), a good price at $164?
Not a bad price for the 2nd gen.
I personally like the insider better with the adapters. It has a bit more torque. The downside is a slightly larger head (which hasn't been an issue for me).
mngundog
MN, in the sticks, U.S.A.
How do I know if it's gen 2? This is it:
I like the idea of the insider, but not the price.
assassin10000
The high speed is the 2nd gen of the long reach ratchets.
The 1st gen long reach is not high speed and has a much larger head.
pwschuh
Mid-Atlantic
Milwaukee... we know you're listening. We need a leaf and twig vacuum with a replaceable metal impeller to shred the leaves and small twigs (3/8" or less diameter). Backpack design with hanging bag for the shred and handheld suction hose. Powered by two 18V like just like the dual-battery blower. Something for times when you need to pick up the Fall debris instead of blowing it around.
Rusty67
LA, CA
I'd consider buying one of those. The ash tree in my front yard gives a BUNCH of shade but it is also an absolute menace in fall and again in spring when everything sprouts.
pbon
Definitely, if it will give you $25 worth of happiness. Your heirs will toss it in the dumpster. I am leaving enough money behind for my heirs to rent a full size dumpster, into which they will toss most of my shop that has given me a lot of happiness over the years.
JimDon
Use the side handle it comes with. Also brace the drill against something if possible. If the bit jams, the drill motor will not stop or slow down so it can break your wrist if you are not prepared, also, workers have been killed by it when working on ladders— when it jammed, the motor knocked them off their footing, and then off the ladder. Jim
JimDon
If you locate a Milwaukee right angle adapter for it, you’ll have a two-speed right angle drill depending on which way you mount the adapter. I have both the 600 rpm model and the 800 rpm model drills. Guys complain about not being able to drill bed frames for projects cause of “mystery” metal they’re made from when drilling with their cordless drills. But it’s not the metal, but the heft and slower speed of the heavier drill. I use a big washer for a dam, then some cutting lube inside it and a big drill and I’ve never had a problem ever drilling bed frames or other mystery metal with their corded Milwaukees. Jim.
PS, enjoy your drill, you will never look at your cordless the same way, and yes I have a great Milwaukee cordless drill I use for other jobs.
Rusty67
LA, CA
I've used my friend's "Magnum Holeshooter" several times and I've had it almost twist my arm off. He did warn me in advance to be very careful. Luckily I'm conditioned to let **** go instead of grip on tighter when things go wrong or I could have gotten hurt once or twice.
Rusty67
LA, CA
Gangly, curious how you like the wrenches. I've got some SnapOn and some Mac wrenches and they are both great. Do you have any idea how these compare? I like my older USA made raised panel Craftsman wrenches but mostly because they are cheap and work. The SnapOn and Mac are far superior on the open end side of things though.
Gangly
I love the older Craftsman with the raised side panel. I got mine in the mid 90's and still use them to this day. I keep them in a roll and take them with me when I'm going to be off grid for awhile.
The Milwaukees are longer and thinner, but the box end is taller and can be seen in the below image, which gives it more surface area contact, meaning less stripped bolts.20250819_180612.jpg
Also, the open end has groves cut into the mating surface, and they work great. When I feel like I'm about to round off a bolt with the Craftsman, I generally reach for the Milwaukee and it bites into the fastener extremely well. Bolts that I always had to be really careful with, like rusted exhaust bolts, are no longer an issue if I have enough room to get a wrench on them, the open end of the Milwaukee really does bite that well.
As far as comfort goes, I still prefer the Craftsman, maybe because of the thickness or the familiarity in my hand. Also, the Milwaukees will get slippery when my hand gets sweaty, but I find that to be true with almost every chome tool.
Rusty67
LA, CA
Thanks for the in depth review on those wrenches, very helpful!
Also, guys I'm so excited right now....
I had no idea this was coming and I'm REALLY hoping it doesn't ****.
Rusty67
LA, CA
Is Milwaukee going to post the videos up? I remember a few years ago they posted most of it on youtube, Maybe they aren't doing that now that we are out of the covid era?
gamp945
darkzero
SoCal
Pipeline was very disappointing imo.
The new M12 ratchets look nice. I have no plans in getting one though as I'm still happy with my High Speed.
As for the hand held blower, that thing is ugly & is way over priced. I'll continue to stick with my Melilif Makita knock offs for now.
merkyworks
Texas
It's about time a reputable brand brought a mini blower to market. No-name Amazon brands have been eating the big tool companies' lunch. If you look at just the top selling models, Amazon is selling like 50K+ units per month:
To be fair Makita was first to market with the XSA01Z in 2023.
But yes I agree the other big name brands not comming out with a similar product sooner is stupid. Got tired of waiting and found the brand Mellif on amazon, its a direct copy of the Makita for significantly less and they come in yellow or red battery flavors, although red is hard to find lately.
mikeinri
I can't tell if that's a real product (or if your reactions to it are sarcasm), but for the life of me, I can't understand why anyone would want that with an 18-volt battery hanging off the bottom.
Big and heavy seem to diametrically oppose "precision." Even an M12 would seem like overkill.
Mike
