drokihazan
An air hammer is a tool I just never learned to use. I've tried them out with no success, then again they weren't the best ones out there. I've always done the job other ways. People swear by them for bushing removal but I stick to a sawzall if I have to go that route to get a bushing out. Not sure I've ever use one honestly. What do you guys use your air hammers for? I'm much more excited to get my hands on the M18 jump pack than one of these.
All kinds of stuff. Stuff where I might normally use an actual hammer, too. Like, knocking off a stuck (getting junked) rotor? I don't even hit it with a hammer if it's stuck, I just grab the Thor. I rounded an E14 driveshaft bolt last year and just got out the air hammer and chiselled the head right off the bolt, no problem. Sometimes it's nice to just whack the top of a bolt with it to get it to shake loose some icky goop so you can actually turn it. It's just, idk, a hammer that I can use in confined spaces and hits really hard, often harder than if I was swinging a hammer. I'm a big fan.
I also used to work in alloy development and used an air hammer with a chisel all the time to break up brittle raw materials (like Manganese and Chromium) into smaller chunks so I could weigh them out and put them in the smelting furnace. That was more fun than just cutting down chunks of malleable metals with the bandsaw.
mikey03
Who makes the best set of air hammer end pieces or whatever the bits are called? Maybe I’ll look for Black Friday sales before this comes out and have some of the bits ready since honestly I’m saving up for and excited for this battery hammer!
Rusty67
LA, CA
For rivets, wouldn't an air hammer be more likely to mar the surface you are working on than using a twist drill on the head?
Maybe I'm just using it wrong or something, I've never had success with them.
Not to be too skeptical but I'd wait to see what the TTC review looks like. It might be a wait for gen 2 purchase. Hopefully the gen 1 isn't a dud.
mikey03
yea honestly I’m not doing as much car work anymore so I can prob hold off for a gen 2
Crazyjake8493
Upstate NY
No way I'd spend $600 on a battery model, but I use a pneumatic air hammer a fair bit. Driving out bearings or pins, working on rooftop exhaust fans, breaking up stuck/rusted hitches. At home I use one 2-3 times a month. At work, probably 2-3 times per week.
Odd-job
There are some pretty cool air hammer accessories out there. I use the chisels a lot. More control and works better in confined spaces where its hard to swing a hammer.
Mayhew bolt breakers work pretty well to break free stubborn bolts.
Rusty67
LA, CA
Welp, my the hose on my 0880 vac finally broke today, but much like Madisynn with 2 Ns and a Y, its not where you'd think. Instead of breaking right next to where it goes into the body of the vac which has been deformed FOREVER or breaking right at the connection to the nozzle, it broke about 1-2" away from the connection to the nozzle. I thought that was a bit weird. I would have expected it to break somewhere it gets a lot of stress, not somewhere it has full flex range of motion. Anyways, I was able to cut it with a pair of diacs but I couldn't unscrew it from the nozzle because there wasn't enough integrity in the hose lefty to hold together while unscrewing it. I had to tear the coil apart and then yank it out by wrapping it around some plyers. After I cut the end with the diacs, the nozzle threaded right back on. I was wondering why I lost suction all of the sudden and then saw the break in the hose when I turned the vac off. I always knew the hose was gonna fail but I was SURE it was going to be where it goes into the vac hood since its been deformed there for so long.
Anyways, moral of the story is, if you vac hose cracks on you, now you just have a shorter vac hose. Fortunately I didn't lose much length.
mikeinri
Got a FREEBIE: An older M18 Sawzall (non-Fuel) kit, 2621-22, with two XC3.0 batteries, a dual voltage charger and plastic case, complete with 8 or 9 blades (6 are unused). FREE, from work cleanout!
Date code on the Sawzall (2621-20) is 1847, which should be the 47th week of 2018. Batteries appear to be the originals.
The Sawzall is dirty, but was rarely used. Home Depot still sells them (bare tool is currently $150).
Not sure how good these are, but it fills a gap in my M18 tools (of course, I'd prefer a Fuel version, but it was FREE!).
Mike
mikeinri
Also, I bought a M18 Packout Jobsite Fan, 0818-20 over the weekend. Info and initial review here:
Not sure that this is a great deal, but I needed a portable fan, and have M18 batteries available, so I took a chance on the M18 Packout Jobsite Fan, 0818-20. $129 ("was $149") at HD and other places...
Ran it for 2 hours (at the speed setting shown in the pics) on a full 5.0 battery today, still had 4 LEDs showing when done.
We used this at a youth baseball game (in mid-80s temps, in full sun, but under a popup tent), did a decent job moving air. It's pretty bulky considering it only has a 7-inch fan blade diameter, and it would be better if it could be easily hung upside down.
I'm hoping to be able to use it in the RV at night as well (hoping it's quiet enough). It has a 120-volt AC inlet, but I most often camp without connecting to utilities.
I took a peek at the larger M18 Fuel fan (0821-20), which at 18 inches is HUGE (for my purposes), and a bunch more money ($269). I might buy one with a 20% off (or better) deal.
Mike
Mike
Rusty67
LA, CA
Nice score on the free sawzall. It will probably actually do just fine, I just wouldn't run it with the 3.0 batteries. Probably want a 5.0 or larger for runtime. I have a Ryobi version that I used to cut some bushing cups on a control arm and those 3.0 batteries barely made it through 1.5 bushings sleeves each.
dsimatt
Mike
I was going to tell you I have that saw and that it handles everything I’ve asked of it, I looked and is the fuel version and was far from free. My experience using non fuel versions is they will work just fine.., I 2nd getting some bigger batteries thou. IMG_3423.jpegIMG_3424.jpeg
mikeinri
Thanks guys. I do have several 5.0 and 6.0 batteries from prior M18 purchases. I also thought that the 3.0 was probably not the best choice for a tool like this.
Mike
Odd-job
This subcompact kit followed me home from Home Depot last night for $150. Not exactly an impulse buy as I was eyeing them for a while or so I tell myself.
My 4th M12 impact... To be honest these will have to figure out their use case in the fleet. Always nice to have extras? Too lazy to swap bits? One to keep in the globe box? A smaller form factor always seems to help although I tend not to conceal carry my drills and impacts :)
darkzero
SoCal
This subcompact kit followed me home ... To be honest these will have to figure out their use case in the fleet.
I use mine daily at work for automotive related interior work. Been pretty happy with them. I wish the drill was faster though.
I got tired of the standard non-quick collet on the impact driver so I "fixed that".
Odd-job
Thanks for reposting @darkzero . I remember your original post and thinking what's the big deal?!? After playing with the stubby impact a little, I can see it really be annoying. Switching bits requires two hands which isn't going to work well in a lot of situations. I tried to see if I can do it one handed, but simultaneously pulling up on the collet while pushing the bit in is unnecessarily challenging.
On another note does anyone know if Milwaukee have any collets available that work with the Japanese double ended bits? Like Makita does for the Japanese market? I get sad when I have to take a grinder to the Japanese bits.
Odd-job
any good alternatives for the Milwaukee 49-17-2765 M12™ Brushless Pruning Shears Holster? Seems hard to get the real thing.
Have been trying to use a janky nerf gun leg holster that is getting old. The wrist strap is pretty useless too.
Bonus points if it has a belt clip and can also be angled slightly for a right or even a left hander.
darkzero
SoCal
When I first got the Subcompact set I had no idea it didn't have a quick collet. I haven't had an impact driver with a standard collet in well over 10 yrs.
It didn't bother me much at first, for many months actually. But at work I use it so much I got tired of dropping bits & extensions from forgetting to actually locking them in properly. I guess I'm just so used to (and spoiled by) auto collets that I don't even think when putting a bit in, I just expect it to auto lock.
I have heard that some Milwaukees sold in Japan do have Japanese style collets but not all. And even if you were to find one, I have no idea if those replacement anvils can be easily sourced from Japan. Another solution would be to use a Japanese shank bit holder/extension but of course that would defeat the purpose of having a short impact driver.
EDIT: The P/N for the M12 Subcompact impact driver overseas is M12 BLIDRC-0. Japanese models usually have JP at the end of the p/n. I was able to to find M12 BLIDRC-0 JP online (or so it seems) but I couldn't find a service parts manual for it.
EDIT2: Well whadayaknow. I came across this video. There is indeed a Japanese model for the M12 Subcompact Impact Driver that has the Japanese style collet.
(Starts around 7:30. If you watch it on YT's website it will auto translate the audio to english)
Odd-job
I'm not sure what Milwaukee was thinking on this. I haven't dealt with non quick collets in years along with Nicad batteries. Some things should have died in the nineties IMHO.
Thanks for finding this. In watching the video it looks like the Japanese also got the slow collet as well.
mikey03
The only impact drivers I ever owned are the last two gen fuel m12 ones I guess there full size? I didn’t know there was a sub compact impact driver? Only subcompact impact wrench.
i got no comparison so can you please tell me what other collets do different and pros and cons to consider if I switch?
Odd-job
I think the brushless (but non fuel) subcompact impact driver and drill came out roughly when the subcompact fuel 1/4 and 3/8 impacts came out. To be honest I am still on v2s of the drill and impact driver as I didn't see too much justification to upgrade to the v3's however the subcompacts smaller form factor was enough to make me jump. Milwaukee is coming out with so much stuff that its hard to collect them all :)
I'm not sure if there are any pros to the non quick collets. I thought the form factor would be smaller but it seems to be the same size as my m12 v2 and Surge with quick collets.
darkzero
SoCal
Agreed, why cordless tool manufactures still put standard non quick collets on impact drivers & screwdrivers makes no sense to me. They are already setup to do the machining, rather than a hole for the ball bearing it's a slot. But there is an additional part that is needed, a spring which would cost them pennies but I suppose the pennies add up & whatever they can do to save money is what matters to them.
Some tool brands like Makita still use standard non quick collets quite often these days. I suppose it depends on the model/tier..... speaking of which:
Yes that was expected & no surprise to me. Generally, quick hex collets are "sold/marketed" as a premium feature. So for Milwaukee pretty much all their Fuel models will have the quick collet. Before the "Brushless" line/models were introduced, Fuel meant you were getting their higher model brushless tools. But that is no longer the case as they now offer brushless models that aren't "Fuel". For the M18 (which came out first) & the M12 Subcompact drills & impact drivers that are brushless these are not Fuel. And these non Fuel brushless models are not considered top tier hence them cheaping out with the non quick collets. The M18 Subcompact Impact Driver also does not have a quick collet.
But if you really want to have the Japanese style collet, if you can source it & get it, send it to me & I'll machine it to fit your M12 Subcompact impact driver (unless you have access to a lathe). What you need to find is the anvil from a Japanese M12 Fuel 3rd gen impact driver. The Japanese model number is FID2-0X JP. You will also need the anvil spring for the conversion but I would only need the anvil for machining. I have also heard of people modifying the anvil to fit with a grinder if you want to try that route.
Odd-job
Ah didn't dawn on me that the brushless line would be cheaped out like that by Milwaukee, but shouldn't be surprised. Back in the day I had a brushed m12 impact that had a quick collet.
Appreciate the offer. I am going to see if I can get used to this subcompact as spec'ed with the American non quick collet. Admittedly I am more of a tool hoarder than a ******** tool user these days :(
Rusty67
LA, CA
Freaked me out the first time I used a quick collet because none of my Milwaukee gear has one. I pressed the release and the bit shot off into a low earth orbit and I was like WTF? I think it was a friend's DeWalt? Anyway, I 100% get the frustration with 1 handed operation. When I'm switching between bits it gets annoying to the point that I sometimes just grab a second impact so I don't have to switch. If Milwaukee ever releases a new Surge that is worth upgrading to, I will see about buying a new impact but until then I'm just gonna stick with what I got.
Also now I know there are Japanese specific shanks and collets, fun. If I ever go to Japan I'll make sure not to buy stuff from the tool store that is setup for Japanese collets, then I'd HAVE to upgrade my collet.....
mikey03
Oh so I just checked it looks like you got a 3450-20 and out a 3453-20 head on it. I already got a 3453-20 so I guess that means I already got the good head?
Roger.donaldston
I'm looking for a 2567-20 3/8 high speed ratchet. I think I like the form factor and specs better than the new ones. cheapest I've found is marked new on eBay for around $130 or Maxtool.com refurbished with a 1 year warranty for around $140. If I get the one on eBay, despite not being an authorized seller, will I still have the warranty based on the serial number? pros cons of each source? Thank you.
assassin10000
Mr. Subaru just posted a video of the new M18 "air" hammer. Looks like it hits pretty good according to him:
I'd like to see it knock some heavier duty bushings, sleeves, etc. loose.
Promising with that hub tho.
In other news, just ordered a 3rd drill. The m12 brushless subcompact 3/8".
OldCarGuy
My Milwaukee Tool Addiction struck again,, Twice no less.... Hitting the 50-tool milestone that officially cements my status as a die-hard Red Team collector!
I picked up the Milwaukee 2735-20 M18 LED flashlight. The 2735 overall delivers lower performance-to-cost metrics than competing market alternatives. Being heavily invested in Milwaukee,, purchasing a cheaper brand means managing extra battery & charger. Indeed this one light meet my needs... Takes more to knock it over with the heavy battery at the bottom. Puts out ample light that is directional.
Mounted with the rest of the gang...
Also I purchased the Milwaukee Quick-Loc Edger that fits on the power head my string trimmer. Both attachments deliver better performance than my existing gasoline and 120-volt equipment. No mixing gasoline, no stretching out hundreds of feet of cord, far less noise and weight.
Rusty67
LA, CA
I'm warranting a battery for the first time. The instructions say the battery needs to be in a sealed bag? Does anyone know what kind of bag? Can I use a ziplock or is there some special bag I need to use?
assassin10000
How'd you like that spot blower?
It's been a few years since I warrantied a battery but I think I just reused a prime bubble mailer for a bag. A thick Ziploc should be fine, as long as it doesn't need to be an anti-static bag.
Shaners256
Milwaukee
They ship from the factory in a heavy duty ziploc bag, so I'd think ziploc is fine.
OldCarGuy
Having a central compressed air system throughout my garages, maybe a small hand held wasn't needed. However the Milwaukee M18 0887 is a handy portable air source, that can be taken anywhere. Milwaukee nailed it in overall design and clearly an exceptional addition to my tool arsenal. And comes with interchangeable soft nozzles, plenty of power, yet a variable trigger control...
LXCam
That’s good too hear, I ordered two of them early this morning.
