It was a great knife that I used for a long time. If you look at the screws that hold the clip on you will notice different ones. Basically over the years they would loosen and eventually fall out and the hole would be worn. Tried to find tiny screws to replace them that would hold the clip tight. Then the body screws started doing the same thing. I finally retired it to the bench.
The simplicity is what makes this one in my opinion... Focused tools are typically the best.
That being said, I've always wanted to try a multi-tool as a daily carry. The problem is I don't want the bulk of carrying around a number of tools that I don't use. My ideal multi-tool would hold:
- A utility blade
- A 1/4" or 4mm bit driver
- small scissors
And that's it... The closest I have found is the Roxon Shear:
The Shear is a modular multi-tool, so I would remove the blade and insert the utility blade holder. And Roxon makes a bit driver, but it takes up 4 slots and there's only three available on the Shear. And overall, I think it's just too bulky for me...
Close though.
