carcentric
I wanted a 24' x 24' (2nd shop/garage) built when we moved here year before last, but the setback from the property line required that its depth be decreased to 22'. In the several months it took to get permits, I planned and replanned the siting, electrical, layout, etc. for hours on end. What I ended up with is at http://www.carcentric.com/shoplayout.gif - if it is too small to read, click the expansion box in the lower right corner.
Most everything turned out as I'd planned - I'll post pix of the details I'm proudest of in this thread later.
The only fly in the ointment so far is using my Hobart AirForce 250A plasma cutter. It's rated as requiring 20 amps (120 volt), and it used to work fine on my 20 amp circuit breaker in the shop's subpanel, but it's started tripping the breaker - at first after using it a while, but now as soon as you pull the trigger. The Hobart-authorized repair shop can't find anything wrong with it, and the geniuses at Hobart suggest I replace the 20 amp circuit breaker with a 30 amp one and install a new dedicated outlet with 10 guage wire (all wiring is currently behind taped, sanded, and painted drywall, so this is "a big deal").
I guess Robbie Burns was right, "The best-laid schemes o' mice an 'men
Gang aft agley . . . ."
