The Plomb Toolmobile That Wouldn't Die
Provincial
Near Salem, OR
Thursday night I saw an ad on Offerup for a Plomb Toolmobile for $60.00. I responded, and Friday morning the seller texted that he was available for me to come look at it. It was 30 miles away, and it was almost 11AM before I pulled in to his parking lot. I was expecting that someone else who lived closer would beat me to this "gem", but I was there first!
The photos in the ad made it look pretty good, but upon inspection, it was very beat up. After a close inspection, the seller and I agreed that $45.00 would be a fair price. We put it into the back of my rig and I got it home, but have had too much else going on to do more than unload it.
Since then, I've only had a few times I could take a few minutes to inspect it and develop a plan to deal with the issues it has. Last night I took some time to do some repairs and get it up on its casters and all the drawers to work.
For starters, every weak point on the Toolmobile/Pressteel cabinets had failed. Someone had used an Oxy/Acetylene torch to weld up failed spot welds, which burned the paint over some fairly large areas. Whoever it was, they were pretty good with laying a bead, and I decided to just leave the welds as is.
Many of the spot welds on the drawer rails had failed, and one of the rails was lying loose in a drawer. This was all on the right side (facing) of the unit, and it was the center drawer rail that was completely gone. The other broken spot welds were all in the rear of the cabinet. I drilled holes and plug welded them with my MIG.
Two of the casters were damaged, with one welded up because the ball thrust bearing had failed. The two locking casters were in better shape, but not by much. Both of the non-locking casters had bent the stems, one severely. I was able to straighten them enough to use for now, but I don't want to load any drawers until I can repair or replace all the casters. They are Colson brand, but Colson no longer makes a caster that will match the dimensions, much less the appearance.
The whole thing was very dirty and has some bad dents. The old description "rode hard and put away wet" seems appropriate. I think the guy that tried to repair this cabinet was an experienced welder, perhaps a body man or aircraft structural welder. I don't know if he gave up, lost interest, or passed away before he got it finished. The seller got it in an estate clean-out, so any of those alternatives is plausible.
The only real clean-up I have done is vacuum out the dust and cobwebs inside and clean the face of the lower bin door with soap and water. The bin door was nearly black when I started, and I did not attempt to clean off the remaining dark spots, fearing I might damage what remains of the paint.
The bottom drawer face is bent badly, and I will have to develop a plan on dealing with it. It opens and closes fine, as do the other two. The middle drawer is the best, and the top drawer is pretty good except someone rivetted in some home-made dividers made from galvanized steel sheet.
I'm including photos of the front and one side after I got it up on its "feet" so you can see what it is like. I'll post more photos in following entries.
thehorse13
Jefferson County, WV
I love it, and before anyone else has a chance to say it, you ****.
That bent drawer face can be easily dealt with if you lay it on a flat smooth surface and give it some massaging with a rubber mallet.
You still have the original Plomb logo and stripe on the box. If it were me, I'd do my best to cut and rub the remaining paint and do my best to preserve that original logo and stripe.
What a great find. I'm jealous!
Oregon rock crusher
West of Salem
Nice find Jock. That toolmobile looks pretty good. It's got plenty of character as is and with the lower cover an lock bar a very nice find. There's been a few toolmobiles shook out of that general area over the last few years. Ed.
P
Provincial
Near Salem, OR
Thanks for the encouragement everyone! I got lucky, but moved fast, too!
I have already decided to save the original finish. My wife, who doesn't much appreciate my collecting "junk", is really taken by the logos, and insists that they be saved. I see no practical way to do that without retaining the finish. The big question is how to address the areas burned by previous welding, and how to straighten things without damaging the finish. The Horse made a good suggestion on fixing the lower drawer, which I'll try and will report the results. I believe that the damage to the right front will have to stay.
I'll try to clean up the old paint when I get time. I'll be especially careful near the lettering and striping. I'm thinking perhaps using a wax coating to protect the metal where the paint is burned or missing.
I have found a set of casters that are slightly taller and have the same mounting stem. I'll probably buy them and store the originals, which will make it possible to load the box with tools.
I'll make a piece of Masonite to cover the top, and have a Huot box to put on top while I look for a Plomb top box.
Photos:
1: Casters
2: Bottom Drawer Damage 1
3: Bottom Drawer Damage 2
4: Bottom Drawer Damage 3
5: Bottom Drawer Damage 4
6: Left Front Paint Heat Damage
7: Top Left Corner Repair
P
Provincial
Near Salem, OR
Someone had tried to repair failed spot welds on the center drawer rail with an amber colored glue. No prep work, weak glue, and a major fail! See photo #5.
Notice all the O/A torch welding repairs. Pretty good welds, but lots of paint damage.
More photos.
1: Right Front Damage
2: Right Front Damage 2
3: Lower Corner Gusset Repair
4: Lower Drawer Weld Repair
5: Right Drawer Weld Glue
6: Right Drawer Weld
P
Provincial
Near Salem, OR
The top drawer is quite straight, and the paint is pretty good, too. Someone has rivetted in dividers made of galvanized steel sheet. I'm not enamored of them, and may remove them.
Rileysan
Milwaukie, Oregon
Congrats, Jock! I saw that hours too late and my thoughts immediately turned to you, as I know that Ed, Smoke, and BMW already own one. I've already had 3 through my hands (keeping only one) so am pleased to see you finally got one!
Brian
P
Provincial
Near Salem, OR
Thanks Brian. You know I'm a sucker for abused or neglected tools! This one has a story to tell, for those interested in such things.
P
Provincial
Near Salem, OR
Some more photos.
Right Side
Back
Right Top Corner
Left Top Corner
Even dirty and damaged, it is nice to look at! :rocker:
thehorse13
This really isn't as bad as I thought.
The metal work is easy on this one. There's nothing there that a careful guy with some time on his hands can't fix.
The welds are well done. The guy who did them knows his way around a welder.
The castor that's bent can be fixed on a cheap HF press. I'd do my best to preserve the originals. They too look like they can be cleaned, repaired and saved.
The paint damage from the heat is really the only large issue that you have. If you're going to clean and preserve what's left, I don't see the heat damage as a detractor.
Did I mention I'm jealous?!
