bowtiguy
Holy cones Batman! Now all you need is a ********** parking lot on a Sunday AM + a vette cart = instant auto-x!
............. nothing like have a 20' divider in the middle of your floor for a week.
........ In the end it could become a one ton capacity truck if I don't plan everything out, kind of stinks as I had not understood the state rules about a single axle truck.
Hi Strouty,I hate tag axles, the places I ago they can lift your drive axle off the ground and then you are screwed. I am going to start a list of what can be removed, then as I remove it, I will weigh it and subtract from my total. If I can get it so I can carry 6000 pounds on the truck, that should do it, the trailer can do the rest.
Sounds like you need a new lathe then... [emoji6]I haven’t mounted the seat yet, but I moved it back and drove the truck in the yard, totally better, almost a different truck.
I will have to layout the area tomorrow with cones.
The switch is a battery disconnect.
The lathe, oh the lathe.....
I got the four jaw chuck mounted, the bar did not slip, but the lathe didn’t have enough umph to thread it. I guess I need to learn how to turn threads on the lathe, we ended up threading them all by hand, then am sore.
Sniff test failure........
