Above 1200 Sq/FT The Salvage Garage
Strouty
Southern Maine
Rain, rain, much better than snow!
Today may be a mellow day or it may be a Quonset hut day, not sure yet, should know by mid morning. Either way I woke up feeling relieved, yesterday was another notch in my belt and a major task that was stressing me out checked off the list. I even got the tires inside at the SG, so it was a double win!
Strouty
Southern Maine
Thanks guys, it does feel like I got something done.
Probably would have taken an experienced mechanic less than half the time though. I can see the other trucks that they removed engines from, nothing was cut, at least not from the engine, it does look like they cut the inner fender out. I will have to take a closer look, should have done that first, but I wasn't thinking about that. :(
Maineiacmoose
Maine
Strouty Did you happen to make it to the auction up in limestone the old Loring AFB Hummer Depo moved shop and had a bunch of cool stuff.
Strouty
Southern Maine
The jack stands are made by AME and are good for 20 ton each, I bought them off and on when there were deals, they are heavy, but built well. I have two heights, those were the low ones, the high ones are close to twice as tall. They are about $250 each, I bought them from Amazon when they had them as warehouse returns and Zoro tools when I had a good coupon. I also have some OTC that are a pin style, they are decent, but I would never use them on anything but concrete, the AME ones will hold up well to uneven surfaces. When you are off kilter, it makes turning the thread portion hard with the load on it, ask me how I know. ;)
As for the the auction, I missed that one, probably a good thing though.
Today the guy that I delivered the engine to yesterday said my chains would be ready because he was putting the engine in storage for the winter. I stopped by around 10:30, the chains weren’t ready, he said if I helped him put the engine away, I could take the chains, no problem. Well it was, first the engine and trans didn’t fit as one piece (he was going to store them both and I would get the trans back later), once again, no problem, we can separate them. So by this time I am soaked, the trans is stuck on the clutch and won’t come apart, we finally get it apart, as he is backing out of the shop, he doesn’t raise the engine enough, the oil pan grabs on the pavement, slides the chains and on its side it goes. :( broke a few parts, luckily not on the turbo side, so now I am trying to hook up the chains and get it back on the forks, basically another clusterfack, his machine has no brakes so he is really jerky and it was actually a bit nerve racking. After a couple more close calls we got it in the storage container and I picked up the trans and left, only I forgot my chains. Went back and got them, then headed to meet up with my Cousin and a friend to do some basic plasma table training. I am still wet from the engine incident, so I feel like going home.
Strouty
Southern Maine
I wouldn’t mess with big trucks if I didn’t have a way to pick heavy things, kind of a catch 22 deal.
Much colder today, haven’t figured out my plan yet, the trans leaked oil all over the deck of the 550, I really need to plug the ports and clean up the mess, then I think I am off to the SG.
Strouty
Southern Maine
Less than three hours of daylight left and I feel like I am sinking. Haven’t gotten anything done yet, of course the tires plugged up the SG pretty well, looks like I need to move almost everything and I know I don’t have time today. The good thing is that I don’t have a ridiculous amount of things to deal with, just a dozen trailers, sounds worse than I think it is, but in order to put them all away, it looks like I will need to hire someone with a ramp truck for a couple hours to help me move a few things. I think it will be money well spent, just need to figure out the logistics. I have a few more trailers to bring to the SG from the Hill, don’t want to do that until I get things cleaned up better, would be too much, even for me.
I think I can keep the FL106 cab section inside and still have three burbs as well, I could probably fit four, but I don’t think I could do any work on them, wouldn’t be enough space to open the doors. The Virginia burb is staying inside for sure, I would like to start tearing apart the newest white burb and the black North Dakota burb as well, then I can get rid of both chassis and the tubs can go outside. The OGMC and the Connecticut black burb (4.10) would be the next ones to process, or the Yukon, no matter what, I would like to have a couple dismantled before the end of the year.
pi_guy
N/A
One of the shops I worked out of had too many cars that clients owned and being stored not actively being raced. The solution was to get industrial shelving and taking wheels, noses and wings off was able to stack three cars where one would sit. Now bear in mind these were 1100 lb cars with driver.
But my point being look towards stacking your Suburbans.
Strouty
Southern Maine
I plan on stacking the bodies or tubs on top of the conex boxes out back. I can only do this with the ones that have all the glass and doors in tact, I figure I can store stuff inside as well. I do need to make up a cradle that supports them so the rockers don’t get messed up. I figure I will use the original frames, just cut them to the length that works, that way they bolt to a body mount. I can’t think of a better way or an easier one.
I can see that today was not a good day for the SG, wish I had started cleaning up the shop at the Hill instead. I am going to unload the transmission from the 550 and then head back to the Hill soon. I really need a full day of daylight to get things cleaned up, this weekend looks like it will be perfect weather for it. For tomorrow I will work on shuffling things around with Perk and Clark, I would love to get Clark back to the Hill by next week. Perk needs to be at the Hill tomorrow night so I can be working on the brake controller and tail lights. After that I can move the big tilt trailer around with a load.
The mess from the trans.
Two 1/2” pipe plugs and some spill fix solved that issue, still need to wash off the deck, but at least the oil isn’t going everywhere. Of course it was more like jelly than oil due to the cold. ;)
Strouty
Southern Maine
It is very slippery. :(
I don’t know how long it’s been, but the platform scales are still at the place that told me they could calibrate them. Apparently they can’t calibrate them and they are saying that they would have to ship them to the manufacturer and have them calibrated. I could have done that, can’t wait to see what kind of a bill they come up with. They said they would contact the manufacturer for me, I told them I just wanted the scales back and to let me know what the price for them to tell me what I already knew would be. If this was my company/job, I would say sorry we couldn’t help you and sorry it took so long, no charge, but......
Secondary drama, Dad has to finish setting up the online bank account for our new bank, he called me and told me “the sweet young girl said you have to do that online”. I then asked him if he even ready the email I sent, he admitted he just called. Now he is mad he has to call back, I asked him to just read the email to the person that answers. This is the one major hassle of not being a signer on the account, but I still don’t want the responsibility of being blamed for signing checks.
Strouty
Southern Maine
Well, guy called me back and told me no charge and he was sorry, so he was just like me in that respect. I am picking them up at 7 AM tomorrow. Just another thing to store for the winter! ;)
Strouty
Southern Maine
I am just rolling with it at this point. This weekend is supposed to be 50s again, right now it is in the upper 20s with a bit of wind.
I am thinking (well my running nose is) that tomorrow should be an inside day and try and not make things worse. I have plenty to do at the Hill shop.
One odd thing, a couple weeks ago the black North Dakota burb had ABS issues where the brakes were locking up badly. I pulled the main fuse and it didn’t change anything, the ABS light didn’t even come on? I have started and moved the truck a dozen times since then, tonight the ABS light comes on and the brakes aren’t locking up, so I may be able to drive it to the SG and then bring Perk back.
Strouty
Southern Maine
I wish I had that many burbs, especially from your neck of the woods.
The ABS was at any speed I tried, probably up to 15 MPH, it was similar to what happens when the brake drums get wet, but it was only one wheel and it dragged it pretty good when trying to stop.
Going to pick up the scales this morning, then I have to find a home for them. Apparently it is snowing right now, nothing the weather guessers had mentioned. :(
I may have a small window later this morning to early afternoon to get Perk, all depends on the road conditions, I suspect they will be OK, but we will see.
Strouty
Southern Maine
Stop it!
The scale place had a dusting of snow, but it is just cold at the Hill. I am at Dad’s place now, a bit early, going to try and get the new bank account setup for online access, I can’t seem to trust home to get it done, he doesn’t understand what I am trying to accomplish.
Strouty
Southern Maine
Got a call from the GF, house has no heat, furnace kicked off and wouldn’t restart, again. :(
Went through this last year, furnace guy threw the parts cannon at it, then told me it was the electrical circuit, electrician says it is the furnace, round and round we go. Today I couldn’t get the controller to reset, so I called the tech line, while I was on the phone, the controller went blank, tech says that isn’t good, controller is most likely the problem. So now I am off to source another controller.
Strouty
Southern Maine
Got another controller, hopefully this will solve the issue, problem is, this was intermittent, sometimes days, sometimes weeks apart for issues. Fingers crossed.
Strouty
Southern Maine
I distinctly remember saying that it wasn’t going to snow.
Strouty
Southern Maine
Leftover mess from the engine removal is now mostly picked up, have a couple pieces of steel inside that have some parts on them that need to be removed before going to scrap, then the radiator needs a bit more prepping and it can go to scrap too.
steaks&anvils
Colorado
bummer on the furnace, hopefully the new controller fixes it. Nothing worse than waking up to a stone cold house, been there done that a few times.
The yard looks good, looks very clutter free? remember, every piece of metal you scrap is progress.
We got a lot of snow here in the Denver area on monday night, 6-8in. Cold but sunny today, in the 50 degrees.
Strouty
Southern Maine
Happy six foot segregation day!
Snow is all gone, been raining for a bit, but it is in the mid 30s, so could be some ice. Looks like for the next week plus there will be temps in the 40s every day and a couple more bouts of rain. I can live with that! :)
I am marching on with the winter prep, I would have brought Perk back yesterday, except they were out pre treating and salting the roads and I don’t want any of that **** anywhere near any of my good trucks. Luckily the rain should wash a lot of it away, then tomorrow should be dry. I will probably wait until Sunday to bring Perk back now, just depends on what I get done. I need Perk to shuffle trailers at the SG, but I also would like to use Perk at the Hill to move some things around, hopefully I can get a bunch done today and have the shop space at the Hill pretty much cleaned up.
Strouty
Southern Maine
Thanks guys, I am running a bit behind on my schedule, haven't left the house yet, had to do a few things on the computer, ordered a couple goodies for my tool collection and some pieces and parts for general use. I am off to the Hill, want to get something done.
