86turbodsl
Pics or it didn't happen...
finally being honest about thingsThis morning I bought another sandblasting cabinet, I am not sure if it works, the previous owner made a mess of things, but I think it will ultimately be salvageable. I am picking that up tomorrow, not going to do any work on it though, just going to use it to take up floor space so I can be mad about it later.
I'm impressed! You managed to type that last sentence with a straight facei wrote out a big long response and none of it made sense, so my new answer is “because”.
Honestly I went to look at it thinking it was a pressure style cabinet, ended up being a recycling style that only uses 5 pounds of media at a time. The guy had it all hooked up wrong so it was making a mess and he didn’t know why, but after looking at it everything made sense. I figured I would give it a try and if it works, awesome, if it doesn’t then I can regroup and move forward. The benefit of this type of unit is that if you want to change media type it is quick and easy to do so, the baghouse that it has can be converted to a filter system without a lot of effort. I didn’t pay enough for it to get all freaked out, I think it will be worth the effort in the end. Had it been hours away, I wouldn’t have even been interested, but it was cheaper than what I paid for the foot pedal and nozzle that I used to try and upgrade the original unit. Besides all that, I needed another couple projects anyways.
Minimum 4 tires, bearings and brakes per trailer that's 72 little bits of misery added to your life!This press is fairly compact because it was made for one purpose, I would have to get some engineering help to remake it the way I would ultimately want it. The entire foot print is about 2’ by 5’ and about 6’ tall.
Also trailer update, newly thought up hook lift trailer, so 18.
I would have expected better shielding (something) at 200 tons.
Looks cool
When you said 200 ton press.... this is more what I was thinking of!!!
200 Ton Straight Side Press • Used Verson S2-200-60-48T Press (3299)
Verson Mechanical Press • Used 200 ton press for sale • Verson S2-200-60-48T Straight Side Press with 33" SDAU MAX. SHUT HEIGHT TO BED & BED AREA BED AREAwww.almamachinery.com
What parts of it are usable? Curious to hear more about it.We weren’t quite as extreme, 50 to 25 with wind.
Hydraulic press was not as described, guy didn’t know what he was talking about. I bought it, but for $100, felt dumb to drive four hours and not get something.
I will do a bit of messing around with it, but looks like there are a few parts worth saving, then the rest can go away.![]()
