Strouty after reading your thread from my last visit [~ day and a half], I was thinking that you need a binder with some dividers for your lists, grab a pocket size notepad and keep it on you for instant messaging to yourself. Take these IM notes with you and put in the binder when you get back to your truck, then transpose said notes while waiting throughout the day [line at scrap yard, dump, parts counter, DMV, commercials while watching the **** Tube, etc.] My secondary thought was a voice recorder, an "App" with the bluetooth to your phone (is that actually made/available?) for verbal note taking, possibly coupled with "Naturally Speaking" for transposition and then print and insert in your binder sections. Keep beating on those projects and I agree hit the problem children first, your prioritizing plan sounds like a winner! No the stars will not always align, but when they do it will be a lottery win to your motivation for sure. I would also put an indoor work space at the absolute top of your priority list. I have been working on that plan for a while now, I have been tackling the first obstacle in my pile of $#!+ ...I mean garage, but I have been piling up really long term/lasting projects and therefore my actual forward momentum on the garage hasn't really been visible, so I plan on modifying my basically same plan to make faster advancement, or will keep modifying until it does. For your pump problem on the 550 I like the "Pony" motor and pump plan why run a $15,000 motor for hours on end when a $500/1000 one will do the same job and can be made quieter and should be more fuel efficient as well. I am not aware of the PTO situation on the Ferds but I know that the Allison transmissions in GM's is missing the gear on the shaft below the PTO cover unless ordered with the PTO from just after the launch of the Allison (Peterson 4WOR did an article quite some time back that listed an approximate timeline as I recall). So beware you may need a transmission disassembly/reassembly, plus parts to instal a PTO on your ****** if the case will even allow it, since most of those are likely PTO free at this point, we know that the case will get/or has/had a price inspired make over.
Thanx Again for "Dragging" us along on your journey! Harry
