harley jim
That sounds like a plan, that Iron will sit there and wait on you, Chuck is ready to party!
What makes it a custom crew? I thought they had factory crew in that body style?I got two dock plates, a funky cart, and some more bins.
I also took delivery of the HD series the other day, it is rougher than I remembered, but since it is a rare custom made crew cab I think it will still be worth the effort. All the suburban parts are interchangeable except the rear rocker panels. The dump body will go on Bev, it dumps both to the rear and side, needs linkages freed up to side dump, but again it will be worth the effort.
Daaang that crane is handy. Now i want one... Thanks.I got Chuck and human supplies, now I am watching him for a bit. The loader was a bit of a pain to unload, I didn’t have enough boom to push it all the way off. The track crane had to lift the forks up off the ground, then it rolled easily. I tried to pull the trailer out from under it, but I didn’t have enough traction.![]()
GM didn't make a crew cab in the HD series, 15k GVW with 19.5 tires. They did make it in everything else, so these were fabricated, I wouldn't believe that it would be cheaper to cut and weld the cabs, but that is what they did.What makes it a custom crew? I thought they had factory crew in that body style?
Yes, knuckle boom can push and pull unlike a regular crane, I still have a winch and that kind of gives me the best of both worlds. Once the new hydraulic system gets installed, the thing will be great, right now it is a bit slow due to an improper PTO ratio. I have everything new to install on the 18 speed transmission.Daaang that crane is handy. Now i want one... Thanks.![]()
This X10.Just wait until Chuck figures out that he can stop climbing and just dig his way out. You’ll be spending every night filling holes in your yard by flashlight when you get home.
My thinking too. A PVC maze for him to explore, leading to his water bowl, a bedding area, and back to a litter box. With a few other twists and turns. Don’t forget some cutoff branches for him to chew on.He may like a tile or piece of pipe to crawl into for a little darkness
