A couple of side project updates...
When I'm working in the garage, I tend to lose track of time and don't do a very good job of keeping an eye on my phone. I'm sure more than a few of you can relate. Wife gets frustrated with me because dinner will be ready or she needs a hand with something, but she has no way of getting my attention other than coming outside. I tried to remedy this situation by getting a cheap wireless doorbell designed for deaf people, but the problem is that the range isn't all that great so half the time it doesn't go off. When it does work, the lights only flash for ~15 seconds, so if I don't happen to be looking towards the box, I don't always notice that she's trying to get my attention. When I was replacing the wiring for the exterior garage lights, I had an idea. There is a switch for the garage lights both in the garage and in the kitchen. When I was replacing the wiring for the new lights, I pulled an extra line and setup a "red alert" light. Now, whenever Wife needs me, all she has to do is hit a switch. No matter what I'm doing, I'll eventually notice the bright red light above the door. I know some may not be thrilled about something like this, but it works for us. Wife is respectful of my QST and doesn't abuse the light. I need to come up with some sort of fun sign to hang next to it... something like "Reactor Core Overheat Alarm".
View media item 101230
Next update is what I like to call "adventures in cleaning parts when you don't have a sandblaster". If you've been following along with some of my axe projects, you'll know I'm a big fan of using vinegar for rust removal. While it does work, you have to be careful to not let the parts sit too long as they will eventually rot away. Another rust removal alternative is to use an electrolysis tank. I won't go into to detail about how to set up your own unit as there are dozens of well written articles and videos on how to do it online, but I will show you my setup. I'm running a 3 amp 13.2 volt DC power supply I picked up on FB Marketplace for $20, the bucket is from Home Depot, the anodes are chunks of channel drop from my weld bench project, the electrical wire is just leftover from my lighting project, and the wire used to suspend the object in the tank is rebar wire. All in, I'm into this for maybe $30 after purchasing the washing soda.
View media item 101227
My first project? A bit of a torture test of the system - an old adjustable wrench my Dad found in a field on the farm. Who knows how old it is or how long its been sitting in the dirt.
View media item 101228
To my amazement, it only took a week to get it back to "functional" form.
View media item 101229
It does actually work - the jaw does go up and down and the worm gear does spin. Far from ever being as good as new, but functional. Each day I'd remove the loose chunks with a stiff brush, but otherwise the tank did all the work. Pretty amazing. The coolest thing about an electrolysis tank is that you can't overdue it. When there is no more rust, the reaction stops. When I went to check this morning, there were no more bubbles coming off the part, meaning there no more rust to be broken down. I've got an axe head running in the tank now that I'm confident in the process.
Finally, some tool purchases have arrived... unfortunately.
View media item 101231
There is a saying that comes to mind in this moment... "If you want to hear God laugh, tell him your plans". I no more than got new engine mount isolators in for the motorcycle when a trip back home revealed an issue with the Grand Cherokee. There is a not healthy noise coming from what I believe to be the transfer case. Trust me, I've done a ton of poking around and research and believe I have it narrowed down. So a slide hammer kit, bearing driver kit, brass drift punch set, seal puller, snap ring pliers, and retaining ring pliers were purchased to do the job. I spent nearly as much on tools as I did on the parts for a rebuild, but that's still only 1/3 of what a shop would charge me to do the job, and I get some new tools that I needed anyway out of the deal, so I guess its not all bad.
