Between 705 & 1200 SQ/FT The Texas Barn in PA
madison069
Monroeville, PA
I have that one as well....but will admit it has yet to be used ....what are you planning to fill it with?
I was thinking water first and place a second container filled with simple green or awesome from dollar store in the water.
This way I don’t waste solution and make it easier to drain and clean when I move.
In the harbor freight ultrasonic cleaner I’ve been using simple green with great results, but I do have a can of carburetor dip which I could place in the water as a secondary container.
madison069
Monroeville, PA
Was able to get the first coat of paint on the bench. The first coat didn’t cover 100% but I’m sure it will be better with the second coat.
I also got these end caps for the open ends of the tubes. I plan to put them on the bottom of the legs too so they are closed off.
I also installed the air line shut off valve since the bench will hinder easy access once I put the bench in place.
Even painted the black iron gray to blend in some.
Now to wait for the first coat to dry and then apply another coat.
madison069
Monroeville, PA
Early this morning, I was able to get a second coat on the whole frame and then I rolled a third coat on the front and any exposed area where the toolboxes won’t hide.
After waiting 4 hours I decided to install the black plastic caps in the tubing ends. Side and bottom.
Then I rolled it close to the corner and set it in place.
Couldn’t plan the bench length any better considering where the 220v plug is located.
I need to notch the bench top for the air line. I also need to notch the metal frame too. I’m still trying to decide if I want to notch the metal frame or not.
Here is the other steel table next to it. The steel table is a few inches short, but I can put some spacers under the legs to raise it up.
When a good deal comes across for a steel plate to put on the bench top, I’ll replace the MDF top, but fo now it will work just fine. I do need to put a back splash trim on the back of the bench top prevent stuff from rolling off back there.
That’s it for today. I need to give the toolboxes a good cleaning, but it’s just so cold.
RickP
Annapolis, MD
That table fits great in your shop.
Could you make the back splash extra thick to avoid having to notch the bench top?
That gray paint really looks good on the bench!
madison069
Monroeville, PA
Good progress Cody!
Thanks Marc! Considering the amount of time I get to puddle on it I do agree it’s good progress. Like everyone else I’m sure, I wish it was done overnight! 😂🤣
That bench looks like it was made for that very spot!
Lou
It does look like it was built for it. I did deviate from my original plans, but this should work just fine. It might actually work out better then the original plans!
The way the previous owner had cut the top board to the bench it wouldn’t look right. Could it work, yes. But one part of the L of the bench would have the top flush with the frame while the other part of the L bench would have a 1” lip overhang. So I think notching it would be better and then build the back splash around the valve. Hopefully in the future I will get to change out the top for something like a 1/4” steel plate.
madison069
Monroeville, PA
Did some cleanup at the garage and loaded up the toolboxes to get them cleaned at the other garage where it’s warm.
Toolboxes loaded up.
Stopped at the car wash to pressure washed the outside of them.
Here they are after letting the ice thawed off and blew it all off with air.
Now to go through each drawer and remove the stickers.
madison069
Monroeville, PA
Got them all cleaned and all of the labels off.
There was the cheap cabinet rubber linear in the drawers but I removed them.
The bottom drawer of one of them wouldn’t close and so I removed it and found these items in the bottom of the cabinet.
I got the us general toolbox cleaned but the bottom three drawer’s tracks are very sticky.
I need to pull those three out and clean the tracks. Then I’ll get my drawer linear material out and cut some down for as many drawers as I can.
madison069
Monroeville, PA
Here’s the tool box liner.
Measure to cut,
Now in the tool boxes
I’m 2 drawers short of the third of the gray tool boxes. None has been cut for the harbor freight toolbox.
I did find the original source of this liner.
But at $140 for another 20ft of this liner is just a little steep when I don’t think I’ll need that much. Heck, it took me 5 years to use this up cause as per the packing slip i bought it October 2020.
madison069
Monroeville, PA
Regarding notching the bench for the airline.....I'd bite the bullet and just move the airline up. I know, what a hassle, but I think you'd be happier that way.
my initial answer seemed harsh, and I don’t mean to be just answered quickly.
Honestly I wasn’t planning for a bench to be in this corner. The initial goal was to use this corner as a storage for shop vac, and any standup tool on rollers. But with the deal of this bench I decided to change my plans. Honestly it don’t bother me too much and I think with the goal of replacing the MDF with steel when possible just means I will just notch the MDF but leave the frame as is. I can extend the steel top to overhang the back of the bench when the time comes. In the mean time I’ll just put something on the back to fill the gap between the bench and wall so stuff don’t roll off back there. What’s nice though is the air shut off is easily accessible by just reaching over the bench. Do I wish the air line was more in the center of the back wall, yes. But the back wall is solid in the cinder block and so this spot was the closest I could install the air line to the garage floor area via the cinder block. Hope that makes sense of my justification and why I did what I did.
Jeff Ivers
Oklahoma
That is a heck of a deal you got on the bench and boxes. That is going to make a really nice workspace. With all the room you have, I would be tempted to pull the bench away from the wall just a bit more so that your bench top can run all the way to the edge of the frame. It is hard to tell the dimensions from the pics, but I would be tempted to rip down a 2x4 or 2x6 and attach it to the wall like a mini shelf and backstop to prevent roll-offs. You could size it and place it to overlap your benchtop by 1/4" and just run it up to the edges of the pipe.
madison069
Monroeville, PA
That’s another possibility. It won’t take up much room and like you said, I can just put a nice 2x dimensional lumber on the back for a backsplash.
bdbecker
Iowa
That's similar to what I did behind one of my tool chests in the last shop. I just used a 2x6 and some inexpensive shelf brackets. It ended up being a pretty handy space for storing my pry bars and battery chargers. Also gave me a good spot to stash my project axes.
OutlawDrifter
KS
Do I spy Wilde Tool prybars?!
If so, I have a similar set, and used to work just down the street from the factory.
madison069
Monroeville, PA
So with the upcoming weekend weather, I figured I’d better get the toolboxes back to the garage. If anyone says you can load a series 1 us general 42” toolbox into a truck bed by yourself, they are correct. But should you do it? I would give it some more thoughts on getting help. I loaded all 4 toolboxes in the truck but that red one was heavy.
None the less I got them back into the bench frame, with a little help from the floor jack I was able to get them in place without too much damage to the frame. Got a few chips but nothing bad and a little paint will fix it.
So here they are!
Now that it’s all back together, that missing drawer trim on the bottom right red toolbox is sticking out like a sore thumb. Where can I get just one of those drawer trim?
madison069
Monroeville, PA
That's going to be a nice setup Cody.
I was able to get parts for my 5+ year old 12" miter saw from Harbor Freight. I was able to order the whole shield assembly through the parts side of the website.
https://www.harborfreight.com/parts
Thanks! I found aluminum trim listed on a toolbox list but no pictures. They had 2 listed at the same price so I just bought both and they should be in about a week from now.
SilverJimmy
Prescott/Flagstaff, AZ
Cody, on the shelf on the right hand side you might consider building some boxes that fit underneath the shelf. If you build the boxes to just fit under the shelf and put wheels on the rear edge they would be easy to roll under the shelf even when loaded. The wheels I‘m thinking of would just barely come into play when you lift the front of the box 1 inch. I hope I’m being clear in my description. The benches I built for my first shop were made out of wood, 4x4 corner posts with 2x4 framing and plywood horizontal material. After I built the first one I realized that to maximize their utility I needed to raise the lower shelf by a couple inches so I could slide the milk crates I had underneath them. Worked great and eliminated a dead space that would have just become a **** show of ****! YRMV! Your shop is turning out great, glad you’re getting some Good Deals too!
madison069
Monroeville, PA
I think I know what you’re saying, basically boxes that slides under the silver toolboxes on the floor. Just two wheels on the back so you pick the front up to make it roll out from under. Not a bad idea!
Xti04
Cody that setup looks awesome. Makes me wish I had room for a built-in setup like that. I have tried on vain to find a couple vidmars or Listas so I could build out a fastener and small parts storage but they just dont seem to exist around here. If I could come across a few I would toss my current bench and build a setup like that with the boxes built in.
madison069
Monroeville, PA
Vidmars and Listas are stupid high around here right now. If I do come across within my budget I might switch myself.
madison069
Monroeville, PA
The work bench setup came out great. Nice find and nice work on it.
Work bench came out, quite envious!
Thanks! It’s been one of those items I’ve always wanted to build, but cost and time kept me from starting on one. Guess it pays sometimes to put off projects as a good deal can come along!
madison069
Monroeville, PA
First aluminum strip came in for the toolbox. Guess I should be surprised that it’s not the right one since there was no details or photos. But where does this trim go?
Also, $6 for the trim and free shipping. I don’t think any profit was made with this purchase just due to the box size!
Waiting for the other trim to come in and see if that part number would be the correct one.
madison069
Monroeville, PA
Doesn’t look like the snow is going to melt anytime soon, so I went ahead and snow blowed the front area of the garage. IMG_1692.jpeg
Then I went and picked up a flammable cabinet this morning. Once I get it cleaned up and painted, I’ll put it in the bunker for gas, propane and so on.
It was a little pricey at $200, but I figured it was worth it.
