The Tiny Tools Thread
tombell572
Sea Cliff, NY & Portland, OR
This is my set of Bedford BA (British Association) DOE wrenches covering sizes 0 BA, largest to 10 BA, smallest. I'm sure a number of you are aware of the BA screw thread system, now mostly obsolete. It was was intended for fasteners used in small instruments and models. I find them typically on my British motorcycles used for fasteners under 1/4" diameter and brass stud and nut wire terminals in the electrical system. Along with these I also have a set of BA 1/4" drive sockets and a GTD BA tap and die set.
Tom B.
dscheidt
Tom B.
BA was widely used in the electronics industry, English radios and such from before aboug 1960 are full of them, as were auto electrical systems. It's a fantastically weird system, in the way only the British could manage. It's all sensible and formulaic, and metric even. Except they converted to inches, and rounded, so stuff doesn't quite make sense.
JradM
Alberta
4" with a 6" head?
Kinda looks like it doesn't it? Proto just says "extra wide capacity", but only rates it as having 1/2" opening capacity.
It actually opens to about 18mm (~11/16") - so noticeably wider than the rating. A 6" Crescent wrench though, opens to 15/16".
I don't know how much I "needed" it. I just thought it was fun. Feels good though. The surface finish seems a warmer color than chrome - Nickle plated maybe?
steve855
PA
Been meaning to get a photo of this one, had it out last night to show my kids. My great-grandfather made it, he was a machinist at US Steel, Johnstown PA. The story is that this was a lunchtime/after hours project, probably sometime in the late 1930's. There's another one, I think my brother has it. Can't remember if it's bigger or smaller though.
Good for calling tiny meetings to order.
MiteyF
Mine can't quite beat that, but I picked up this head on ebay a while back and made a handle for it. I find it strangely handy sometimes.
These 2 little hand planes (and in particular the square) are also surprisingly useful. I bought the Veritas block plane mostly for models, but it even saw some use on a 24" cutting board I made for xmas last year. I picked up the Jorgensen for one project in particular, and it's proven to be a great $15 buy.
Needed a good way to flatten the inside of a cutout on some cherry, and this guy fit the bill perfectly.
This isn't really a tool, but I'm sure some here will appreciate it. These used to be used mostly (AFAIK) in model RC engines. When NGK discontinued them, other (mostly Chinese) manufacturers filled the void. These originals are very hard to come by nowadays. 1/4" threads and a 5/16" hex
O
Not the smallest wood plane, but I haven't had a small tool post in here in a while so it will have to suffice:
A Knapp 1" blade block plane. Just 3 3/16ths long. Aluminum:
orangeblood
Texas
FYI i bought one on ebay years ago that looks like yours. the seller said the head was as an exact copy of a paschal 1302.
Some small screwdrivers I’ve gathered lately
Is the circled one a dart tip? I found one very similar at an ES, quite proud of this beefy awl. Got home, and found the hole on the back end to install the feathered bits. Was a duh moment, but it’s still in the awl pile.
O
I think that is (assuming a flat driver tip) is for a gun sight; I'm trying to remember which one as I have one...
Found my notes: Smith and Wesson K22 target sight adjuster = $$$
  • Like
Reactions: RTM
jpickar
YUP that one is a smith & wesson post war sight tool. 9 row sight tool. Not worth as much as a pre war sight tool but still worth a hunk of change. Let me know if you are going to put it on ebay. I'll bid on it.
I just checked there are several on ebay for $140 to $150 for the nine row sight tool. If you put it up on auction it will go for a little less but it will go for what people are really paying for them. A great find!
tombell572
These have probably been posted by others earlier in the thread, but here are mine: a #78 Stanley bull nose rabbit plane, 4" base, # 100 squirrel tail block plane, 3 1/2" base and #101 block plane, 3 1/2" base.
Tom B.
30-30remchester
That circled driver is most likely an early screwdriver furnished with Smith & Wesson handguns. I have several but mine are blue.
