The Tip Of The Week
chief ben
Hot Springs, Arkansas
I was thinking, Something I do now and then, we should have a place to put
all the good idea's some of us come up with,
And after 20 years in the U.S. Navy I have a few,
And I know a lot of othere old Miltary Guys, And people that never was in the miltary have a lot of Good Idea's,
So let's Hear them.
And Here Is my First One, PILL BOTTLE Water Resistance
How to remember when you did the last maintenance on your tractor or Car Boat or lawn mower or what ever and what you did to it, I know a lot of you Guys have a good memory, But for me at 65 some things are starting to slip. Even when I write it down on something I forget where I wrote it down or where I put the Information, So I came up with this idea, A small Pill bottle and a tie tie strap I typed out the Info. On the computer and made it the size I wanted it to be and put it in the Bottle and strap it to the tractor, this is for my Ferguson TO-30
Now if I can remember where the tractor is i’ll have it made.
C
chief ben
TIP OF THE WEEK 2
This tip of the week is a little different than the pill bottle where you can’t remember something, this is more like when you can’t find something,
Like the Broom are dust pan when you want to clean something up are just want to clean shop floor, I have walked around in the shop for ten minutes or more looking for the
Fox tail, Broom, or dust pan, and some times I can’t find the trash can,
But Now If I Find One, I Find Them All.
Now if I can just remember to put them all back where they belong my problem is over.
So this is my solution to the problem.
NUTTSGT
Northern Central Ohio
Here's my idea, simple and cheap. Glove hanger/dryer.
We really never had a good way to dry our gloves at the fire house. After a few winter fires and gloves getting wet, you have to figure out a way to dry your gloves, inside and out. I thought about it and realized the gloves must be hanging by the finger to dry, so water can run out.
This is what I came up with, just a pair of spring clamps screwed to the front of the lockers. I bought them at HD for less than a buck a piece and put them on everybodys locker at the FD. I also made some hangers for drying our turnout gear too, that's for another post.
I also have one to hold my wood stove gloves at home.
camarotoolman
cocoa Fl.
I Keep my screws,nails, etc. in p[astic water bottles, easy to see contents, don't break like glass, don;t dump over like boxes, and very cheap.
Matt M PA
SE PA
Perhaps not a "great" tip...but one I figured out after finishing our detached garage and wanting it to stay clean.
(Since the garage is up, I've removed and restored the suspensions on 3 1956 Oldsmobile 88s. They were nasty, dripping the clumpy old grease, etc.)
Before I pulled the car into the garage, I spread that thick clear plastic like you'd use in the garden to cover the floor..then park the car on it. I think the stuff I bought was 8 feet wide. This plastic catches all the grease, rust, leaks, etc....and when the car is done you just roll it up and throw it out.
Stephenw
Utah
Shop Tips
An easy way to remember a measurment while doing layout work is to make a mark on your ruler with a Sharpie. The mark will usually wipe right off when done, but if it sets real well, alcohol will remove the ink.
Printer Mike
Eatonton, Georgia
I use a silver Sharpie for writing information(mileage, date) on oil filters, aircleaners, batteries, etc. The silver shows up well on dark colors.
kbs2244
Filter numbers are always a pain for me look up in the store.
The books have pages torn out, etc.
I tear off the end panel of the box the filter came in and keep it in the glove box.
Then the next I need one I just bring in the piece of cardboard and match the number.
e-tek
Saskatoon, SK
I've read a thousand of these tips pages and the one that I still use (and can remember) is this:
Use a spray-can cap to hold wires you want to solder together. Just cut a slit in opposite sides of the lid and slide the wires in, to meet in the middle. It has several advantages: light enough to hang from wires that are still connected, a good height to work at if on the bench, and the cap catches dripping solder!
nit2wn
Centreville,Al.
Close as I have for this one, I stole all of mine from you guys. Electrical conduit was my pipe choice as I over bought for a hot tub install.
Stephenw
Utah
PCO6
Newmarket, Ontario
That reminds me of something I have done for the last 50 years or so. BL50 from Michigan and I are the only two people I know that do this. When you take your socks off at night, pin them together with a safety pin and throw them in the laundry. You will NEVER have to sort socks again. You will NEVER lose a sock and you will NEVER have to go searching for them down a sleeve or a pant leg when you take your laundry out of the drier. I have been doing this since I was about 10 yrs old. My mother told me to do it ... so I did.
sberry
Brethren, Michigan
Not me,, I have never lft a nickle in a casino, had to have my loot for more important items,,, whiskey and women,,, ha
plym49
To remove a rusted fastener or stuck stud, heat well and touch a candle to the threads. Beeswax works best. The hot wax wicks inside and can withstand a higher temperature than penetrating oil.
Jeeprz!
An aircrew buddy of mine in the navy did the exact same thing for the same reason, he also used brass safety pins so they didnt rust in the wash and stain anything. He is the only person I have ever know or heard of that did that in almost 20 years before reading your post!
BigAl62
suburbs of Chicago
I have a towel bar on the end of my workbench to hold my fender covers and my 4 way lug wrench. Keeps them off the floor and out of the way.
Shadowdog500
Down the shore
Cut a hole in the end of an paint tray to direct fluids that drain over axles, etc into a drain pan.
Ive tried several things like antifreeze bottles with the side cut out but the paint tray seems to fit everywhere and can usually wedge or latch it onto something. Here it is after draining antifreeze out of my willys jeep.(getting it ready for plowing)
Chris
Shadowdog500
Down the shore
Here is another.
Use a muffin tin to store bolts and stuff for a project. Follow a pattern to store bolts when taking it apart then reverse the pattern when putting it back together so there is never any doubt what bolt goes where. The extra organization seems to sped things up as well.
I keep it in my rolling tool cart.
Chris
NUTTSGT
Chris
As I started reading your post Chris, I thought a paint tray would be perfect to sit oil filters in and allow them to drain too.
I have an oil barrel with a big funnel for mine but I know guys have talked about draining oil filters on here before.
sberry
Brethren, Michigan
Most have a gage in the pit for the well but its kind of pointless there, I have actually solved a couple problems I might have not been aware of had I not had this one at my wash sink.
Silver6.0
N.E. Michigan
I like the cord guard on your welding cart. Great idea.
Rigged
I have been doing this for years! This is the first time that I have seen someone else do that. I'm not a genius, damn!
I actually use a larger mouth one that I wrap around a wound up extension cord and attach to the 2x4 framing in my shed.
