Mr_fixit
when I saw it , it looked like the guy was about to get squished like a pancake up under the car. I saw fear in his eyes.
The machinery and engineering looked really complex! I'd say $1000 seems rather low for this. I'm also rather skeptical about it making to market, but we'll see.
First thing I thought of as well. You jam the ever in the up position you could be pressed up against a hot cat and held there or crushed.
No thanks ill stik with my lift.
Chris
Chris
I think I'd save the $1000 and bring everything I would need under the car on the first trip. Doesn't look like it would be too practical in a professional environment, aside from the fact that it would be showing weak, which would put a target on your back with management...
if it creates happier more comfortable workforce they should embrace it. No different than the thousands companies spend to have specialists monitoring the posture of people at a computer or the specialty ergonomic chairs they get.
If I were to build one for myself, I'd ditch all of the hydraulics and batteries, and just use a simple pneumatic cylinder.
Air is compressible like a spring, not good at all for holding you in the same spot or staying there, plus think of the fun if it were to stick in one position for any reason and then unstick.
I'd like to see how fast actually rises and lowers- the video was sped up. It looks to be not that fast, when I'm jamming at the shop, waiting even a few seconds for the creeper to lift up would make me pissed. El Passo.
They should have a saftey switch that engages when you lower yourself so it can't hoist you up while under the car if you accidently hit the switch or something falls on it. I also wonder if this would be adaptable for other uses such as in a factory doing assembly work that requires repetitive movements or maybe in a ships engine room (other ideas?) I think limiting this to autmotive is a mistake, horizons for it's use could be much wider
It seemed to roll around with ease and needed to use both levers to make it go up and down.
Yes you needed to move both levers at the same time or it would not move.I noticed that from the other video.
Since you try it out if that really how the levers works?
