The vintage Blackhawk Thread
thehorse13
Jefferson County, WV
Yes bought the lot for the speedball. Could not help myself. It was funny because listed as 3/8 drive. Made an offer on the "make offer" option and the seller accepted, so no getting out of it! Curse my tool addiction....
I got my paws on a complete 7/16th drive nugget set on Ebay the same way. The seller had them listed as 3/8ths drive and heavily worn. They were 7/16th and hardly ever used.
I guess the seller put a 3/8ths ratchet in the back of the sockets and decided they were worn out. lol
Nice grab!
Some set pics for those suffering the blackhawk affliction.....
CRTDI
Oooooh....an early 7/16" drive set with the ever so elusive Speed-Ball handle....Nice! :thumbup:
Now the guy listed the toolbox the set came in so my ocd tool disorder made me buy it....
CRTDI
Wedg-Head wrench set.
Catfishdan
Central coast, California
I don't see much Blackhawk around here, but I picked up these two 8 point sockets at an estate sale today. Triple band with the lock-on thing. One is a 13/16, the other is a 7/16.
Box arrived for 37ish nugget set. Looks like a drawer on bottom, even has handle, but does not pull out. Tray slides in. Lock cylinder is gone, as are decals. Small box. Threw in my 30s hexo wrenches for pics.
Oops, here they are
7/8 qd set, no plug for ratchet. This thing is heavy. Largest socket is 2 3/8. Amazingly still has decal. I have some 7/8 square stock to make a plug with.
Hephaestus29
Indianapolis
I just bought this Blackhawk Vintage Floor Jack.
It’s definitely a candidate for a restoration or a
resto-mod. if parts can’t be found.
It currently does NOT work. It has a couple
of breaks in a couple of the cast pieces from
just glancing at it, and the cylinder needs
work also.
r_olson_06
SD
Some nice sets. I only have 1 7/8 piece and it's a Blackhawk step down ratchet plug.
Looking for the following Plomb Pebbles Wrenches 3060, 3061, 3070
BUGTHUG
Kansas
work also.
not being nosey but what did you pay for it? I have one that needs a little work, but its mainly for looks.
I have had those for a while and now they have a box. I particularly like those anti knuckle buster wrenches. Only have 2 so far. They are scarce. The 7/16 stuff is very early, no date codes. Never saw a whole set pre date code before so had to have it. The hexo wrenches are an oddity, but fit the time frame. As alloy artifacts describes them, they were first thought to be husky made, but later found to be a blackhawk economy brand.
Crtdi, been collecting the 20s heavy duty stuff for awhile, and anything 7/8 drive is rare. I am lucky to find one or two pieces a year, much less a set. 3/4 and 5/8 much more common.
twertsy
Reedville, VA
What sizes are the single offsets? I have some Blue Point and MTF versions that I'd love to compare with the Blackhawks....
I have a 3/4 and a 25/32. 25/32 is stamped closeout and the shank is flattened a bit, which makes me think it's the newer of the two. 3/4 has seen some hard use , one end showing some hammer marks and evidence of grinding... has remains of cad finish where as the other is plain steel.
twertsy
Reedville, VA
Yes, the top one is much newer. I'd say '50s.
The lower one I'm quite sure would be '42. I'm looking for 20's versions.
Check that: The lower one could be older...........
I'm pretty sure it is. I don't have a record of them making a single offset after 1935, and even if they did but they weren't in the catalogs, the model number would almost certainly be 156XX. They went to that series by 1937 for all their DBE (Long double offset, Short double offset, and Long "Angl-Head") wrenches and their "Half and Half" (their name for combination) wrenches.
twertsy
Reedville, VA
I agree Greg. The top one is actually interesting, definitely late '40s - '50s and I didn't think they made those that late.
I just thought the flattened shank was odd. Plain steel made me think wartime, maybe leftover older stuff stamped and sold later. Would explain closeout stamp..
Blackhawk ok tools? Bought this off ebay mostly because could not figure out what it was....Looks like later production of earlier tools?
