That is an actual blackhawk version, circa 1941. Your others look like later new britain versions.
What do you mean by "came with", Roy? Is the arrowhead socket fixed on the end somehow (i.e., either press fit or welded)? Or is it detachable? The Blackhawk offset wrenches (just like that, with a loop handle) ran from Model No. 1114 (7/16") to 1128 (7/8"). And the Q.D. offset for detachable sockets had a hammerhead end, like a sliding tee that doesn't slide.I think this is a Blackhawk offset handle. Has a part number of 110 which seems to fall in line with the labeling system of Blackhawk. Also came with an arrowhead socket.
Sorry yes the socket came with but is detachable. Too bad the rest of the set wasn't there.What do you mean by "came with", Roy? Is the arrowhead socket fixed on the end somehow (i.e., either press fit or welded)? Or is it detachable? The Blackhawk offset wrenches (just like that, with a loop handle) ran from Model No. 1114 (7/16") to 1128 (7/8"). And the Q.D. offset for detachable sockets had a hammerhead end, like a sliding tee that doesn't slide.
EDIT: Whoa! whoa! whoa! I think you may have found something very cool there. The Q.D. offset for detachable sockets was Model No. 110! But again, it was basically a bar with a fixed hammerhead end with a 90* drive stud. I traded my last Q.D. set to Todd, but I will look for pics on my hard drive. Essentially, what I think you have found is a a very early 1st generation Q.D. 110. A transitional design, between the fixed offset socket wrenches, that looked exactly like what you have but with the different size sockets welded on the end, and the Q.D. 110 we are used to seeing (the bar with the hammerhead 90* drive stud). Very cool! It would have to be like 1918 or 1919. I have NEVER seen one in a catalog. You version of the offset handle is NOT in the 1919 catalog or the 1926 catalog.
I hope you can follow that. I'm going out to dinner but I will post catalog excerpts and pics to go along with what I am saying above later.
Nice to have another blackhawk collector on the forum. Here is a 38cb set I have been adding to.
Very nice!Nice to have another blackhawk collector on the forum. Here is a 38cb set I have been adding to.
Picked this up today from a yardsale, actually my wife picked it up for me.
I have never seen one in person before, but knew what it was from sticking out at the bottom of the picture in the ad. Most people probably had no idea what it was at the yardsale.
View media item 106027View media item 106028
Its in pretty good shape minus the missing handle. Not sure if I want to repaint it, ir leave it as is.
I'd clean this up and leave it alone. Finding a handle may prove to be a chore but you have a real deal bomb box now. Welcome to the club!
The few and sporadic rusty blemishes will bother you far less once you clean that up with some penetrating oil and 0000 steel wool. And the gloss on the outside will come right up with paste wax after that.
If it's cancerous corrosion, which it doesn't look to be from here, and you're worried about it spreading, you could remove the rust by taking some pieces of rag or paper towels moist with Evaporust and tape them over the rust spots with masking tape. Keep them wet, but not sopping/dripping wet and wipe off any drips. Do that for half a day. Note though that then you'll have bare steel spots. I would not recommend touching those up, because spots of a different shade of red will look much worse than blemishes.
EDIT: apologies if too intrusive/presumptuous.
You've done the hard work for me Lugz. I was going to recommend the same things but didn't have time earlier to go into detail.
OP, if you look around Ebay for long enough, the decals for this box do appear every so often. You may even get lucky at some point and source a handle off a demolished box. Those auctions do come around as well.
The guy had a speedball (39977) as well but I could bring myself to buy it.Great sets crtdi! Nice ratchet roy! I would hit you up for that one but I already have it.
