It was certainly a load, but I don't think it was truly maxed, do I recommend others do that especially on the highway, no. I was on gravel roads and only crossed paths with 2 vehicles on the drive home. I did keep an eye on the temperatures, coolant never got off the middle line, trans never got above 196°F, it is typically the same on highway drives unloaded.Damn that poor little truck was maxed.
Ive done wayyyyyyy worse. Sometimes you gotta do what ya gotta do. I had a 2008 chevy 1/2 that I would tow a bumper pull toy hauler with. Too much trailer not enough truck. I would watch my Trans temp get to 240 and stay there.... The auto manuel said that it was fine. I knew that I was taking yrs off that motor/trans life by doing that. It took me a while before we upgraded to a 3/4ton. Heck theres times where im wayyyyy over loaded with my diesel... An I also dont recommend it.It was certainly a load, but I don't think it was truly maxed, do I recommend others do that especially on the highway, no. I was on gravel roads and only crossed paths with 2 vehicles on the drive home. I did keep an eye on the temperatures, coolant never got off the middle line, trans never got above 196°F, it is typically the same on highway drives unloaded.
JB
I've certainly seen that before too, heck most of the truck manufacturers show videos of them towing incredibly heavy things. I can't remember all of them, but the space shuttle, a train, jumbo jets, and one from Chevy Cheyenne many years ago towing 187 tons of logs:Ive done wayyyyyyy worse. Sometimes you gotta do what ya gotta do. I had a 2008 chevy 1/2 that I would tow a bumper pull toy hauler with. Too much trailer not enough truck. I would watch my Trans temp get to 240 and stay there.... The auto manuel said that it was fine. I knew that I was taking yrs off that motor/trans life by doing that. It took me a while before we upgraded to a 3/4ton. Heck theres times where im wayyyyy over loaded with my diesel... An I also dont recommend it.
JB, I'm a big fan of AN fittings but boy does the shopping cart get expensive when you need to buy options. Then again, my problem may be keeping the ones that don't work, for 'next time.'I'm at least an inch short, I do have some more fittings on order, once they arrive I'll give it another try, I'm getting excited though.
Bob,
JB, I think I have about $800 worth of AN fittings and braided hose on mine and most of them can't be seen. But at least they work and don't leak. Quality ain't cheap but worth the piece of mind.Bob,
I haven't added it up lately but am north of $1,000 just in AN fittings on the cobra, fuel lines, oil lines and now PCV. The ones I had to use on the oil side were around $45 for each fitting, the lines went from engine to pressure regulator, pressure regulator back to engine and one to the oil filter, then oil filter back to engine. As far as I know this is the last AN component I'll install so there is an end in sight. I have a little stash of extra fittings but not as many as you'd expect.
JB
I don't think I want to looks but believe I'm close to $2k, I have bought and driven entire cars for years for less than that, but they aren't as cool as AN fittings haha. You are very correct there, I tried to go with name brands any chance I could and that worked for a majority of them, but some odd sized fittings were required that I could only find "China" brands, so far so good.JB, I think I have about $800 worth of AN fittings and braided hose on mine and most of them can't be seen. But at least they work and don't leak. Quality ain't cheap but worth the piece of mind.
JB, I did most of mine a few pieces at a time and didn't keep track of how much I spent. Like Godzilla in the Cobra, the big block engine in a Corvette is a tight fit. Opened up some space for it by converting the power brakes from vacuum to hydraulic (hydroboost). It was going to be a simple job with very little bling, starting with a rebuilt hydroboost.I don't think I want to looks but believe I'm close to $2k, I have bought and driven entire cars for years for less than that, but they aren't as cool as AN fittings haha. You are very correct there, I tried to go with name brands any chance I could and that worked for a majority of them, but some odd sized fittings were required that I could only find "China" brands, so far so good.
JB
To be fair Bob, any one of us could have fallen down the same rabbit hole when upgrading to hydroboost.JB, I did most of mine a few pieces at a time and didn't keep track of how much I spent. Like Godzilla in the Cobra, the big block engine in a Corvette is a tight fit. Opened up some space for it by converting the power brakes from vacuum to hydraulic (hydroboost). It was going to be a simple job with very little bling, starting with a rebuilt hydroboost.
That quickly morphed into a paint and polish job, along with a bunch of special PTFE braided lines and fittings, including a filter. Snuck in some AN fittings for the PCV and evap stuff 'while I was at it'...
...and went a little nuts. All that free space meant I could replaced the stock rocker arms with aluminum rollers and replace the short valve covers with tall ones (I was dreaming of aluminum heads, roller cam and fuel injection). Seemed like a good time to put a PCV with a real AN connection and a pretty master cylinder...
Then I replaced the hydraulic cylinder assisted steering with a power rack & pinion, which required its own fancy AN fittings. Ended up adding a cooler and completely lost track of how many fittings were used. Did I mention billet hose separators instead of zip ties? Yeah, those showed up later. And yes, all the brake lines are stainless. The fugly control arms were also replaced when I converted to coilovers.
Are you using a spreadsheet to track? This is something I struggle withI do keep track of every part for each of the vehicles I do a lot of work on down to the smallest nut or bolt just in case I need one on a road trip years down the road.
Yes, that is the only way I could keep track, I wasn't great early on, but have tried to get better. The tough part is parts I buy locally which is usually pretty rare, but online is easy enough. I also try to keep electronic versions of manuals and installation instructions on hand as well as links to the product that end up breaking but at least get me in the right place.Are you using a spreadsheet to track? This is something I struggle with
@OutlawDrifter I thought they were 3/8" plates, but turns out they were only 1/4", I did remember (after the fact) that all I'd ever shot them with was .22 and 9mm. I'll have to get this situation remedied and get more better steel up there. He was so proud of himself for making the hole in it, I can't blame him though.It's amazing what a properly loaded projectile at speed can do!
Are those 3/8" or 1/4" thick plates?
He was taking it very seriously and didn't do anything to make us nervous, well other than the couple of times he completely missed the dirt pile, luckily the only thing behind it was trees and many miles of farm land.Great day for all it seems.
And love the proud hole owner.
Did you send it home as a memento
That is how life goes sometimes, the small tool kit I have in the car didn't have anything bigger than a 13mm socket and I needed a 15mm to move the belt tensioner, the 9/16" worked in a pinch but I had trouble doing both tension and belt at the same time.Pity about the small breakdown, but like you say…….. lucky help was nearby.
That Cobra is so part of your DNA.
Did I see mention of a new job there? Tell us more please![]()
Ooops did I let that slip...Did I see mention of a new job there? Tell us more please![]()
I guess I didn't realize I hadn't mentioned it here. I'll do better next time...Right?!...JB just casually drops a "ready for my first day at the new job" line and then doesn't elaborate.
Bob, I suspected you'd catch onto this one knowing how much you've shared of your past. I've done this same role for almost 12 years and suspect they will have a tough time finding someone internally to take over as it is now one of 2 engineering roles that has doubled in responsibility. I can barely keep up but can't make any forward progress, I suspect the learning curve will be too steep for my replacement. I'm also the company mechanical expert on the highest risk unit we have so that was a big selling point for my new company, but wasn't valued here, well at least not with money.JB, sometimes the paper shufflers above you have no clue how valuable you are. I took a transfer once and my new boss got a call from my old one: "Boy, if we had known how many projects he was handling by himself we wouldn't have let him go." They did get four headcount to replace me so all crocodile tears to me. Same thing is going to happen to your ex-bosses. Best of luck on the new job -- my after-IBM job had a 1,000 mile commute but work from home every other week made it OK. Maybe you can work out a deal to arrive Monday afternoons and leave Friday noon (making up the time on the days you're on site).
JB, it's probably not a good idea considering your chosen field but an EV sure sounds like a solution. No oil changes, way fewer brake jobs and one windmill behind the hay shed. A de-badged Lightning would not look out of place.I just don't really want to spend that much time on the road year round and adding 40,000 miles a year to my daily driver.
Honestly I think it could be overlooked because of my other fuel hog vehicles, but may be a bit tough to sell that to my peers on my first day. haha I have looked at a few hybrid options but I just can't get the math to work out as being that beneficial. The math gets much more cloudy when comparing a house there to commuting as the value of my time comes into the equation as well as the value of time with family during the evenings. That's not a fun equation.JB, it's probably not a good idea considering your chosen field but an EV sure sounds like a solution. No oil changes, way fewer brake jobs and one windmill behind the hay shed. A de-badged Lightning would not look out of place.
Thank you Outlaw, I believe (well have to believe) they will, at least the value my time with a higher dollar value so there is that.Best of luck in the new endeavor JB! Hopefully the new company will appreciate your added value!
Rick, thank you as well, there were too many signs that this was the right move to make at a pretty decent time in my life to make it. I certainly will miss the people here but suspect the new refinery will have plenty of great people as well. Now to just find the perfect house, 500 ft^2 of living space and 2,500 ft^2 of shop space.Definitely sounds like the right time for a move at work. It's too bad the new refinery is a little far "just down the road" but at least you can commute daily if you want. I'll bet the new job will suit you well, and I hope the dual house/apartment works okay. Good luck next week!
JB
