The workshop formerly known as "The Hole"
RVDan
North America
My 12x18 two storey workshop.
My Dad built it around thirty years ago. The original plan was it was a storage shed, with a root cellar below, and a playhouse for the kids above.
Those plans never really worked out. For a little while, it was actually a two storey storage shed, long enough to get the permits signed off as completed. Us kids were grown up and moved out long before the upstairs was ever safe for kids to play in. Actually I don't think it ever acheived safe status.
For twenty five years my Dad constantly changed it. It never hit a point of completion on any of his incarnations, and at the point when I bought the property from my Parents last May, it was a pathetic mess. A combination of woodworking shop and greenhouse was the plan, but mostly it was just a used lumber storage box. The floor was now two feet above the foundation and hanging cantilevered three feet outside of the foundation, but only over half of the foundation, a quarter of the space was stacked lumber from ground level to roof. The remaining quarter of the space was just an open void that was planned to be all glass greenhouse.
So here you can see the building in the background before I touched it. Luckily the trees cover a lot of the uglyness. You can see it looks like a chunk of roof is simply missing, and the vertical and horizontal lines that somewhat look like windows from a distance, is actually racks of used lumber.
A view of the end of the building, there is no sheeting, in fact on this end it was downright scary with regards to the support posts, but thats irrelevant, it was stacked with scrap lumber so tight nothing was going to come down
So as it sat, it was a completely unuseable building for me. It was simply nothiing but scrap lumber storage, and under the floor which was now two feet above the foundation was a crawlspace used for storage, and it was packed full.
My plan started with gutting it out. I thought I could keep the existing walls. After hauling out ten truck loads of lumber, and then attempting to tear out the plywood rack and workbench, I found that the workbench and plywood rack were structural components :dunno:
Final decision, keep the foundation and the roof, and build new in between. Bylaws say that my accessory building has to be under fifteen feet tall. A lot of measuring, head scratching, and drawing, and the building is fifteen feet tall, the bottom floor is sixteen inches below grade, and has an eight foot ceiling. The second floor has a low ceiling but its still comfortable enough with the floor to ridge beam height being 80" I get a space eight feet wide and eighteen feet long where the ceiling is higher than six feet. Oops thats a run-on sentence.
So it began. Supporting the roof was tricky. Actually it was beyond tricky, it sucked every which way you look at it. Sawzall and sledgehammer for demolition of the original building, and I only removed as much as I had to in order to keep the roof supported. I put posts in wherever I could whenever I could, moving them as I needed to.
Here it is at a point where the bottom floor walls are in and the floor joists are in. The roof is supported at this point by A-frame suports on the floor joists. Yeah the roof twisted a lot, it was heavy, and the overhangs used to be supported off the floor.
Working around a huge amount of scrap lumber still, Saturday is the only day I can get rid of scrap lumber, so its been a long process getting rid of 14 truck loads of scrap lumber so far.
Not a lot of pictures of the process, there are just some things you don't want to be reminded of sometimes. I almost feel bad about tearing out my Dads lifes work, but I'm sure that will pass when I finally get to roll my bike in and change the oil to get ready for the first ride of the season.
Today.
I started pouring the concrete floor Easter Sunday. When my Dad build it originally, the floor was 2x4 framed sitting on top of the footer, and about half of it was still the original, although rotted, I could have used it. The other half though was a mixed up combination of concrete slab in inexplicable shapes, and two foundation walls coming up six inches above floor level, plus some boxed in areas, again for enexplicable reasons. I considered just framing around things and building a wood floor at the highest level, but there was already twenty bags of cement and three yards of Navvy Jack in the yard.
After ripping out all the plywood and framing, I found a huge crater in the dirt underneath it. That solved my problem of the thousands of pounds of broken concrete in the yard from all the numerous other projects my Dad half built and then demolished. I couldn't bury it all in there, but I got rid of a good amount of it
I'm not real proud of the floor. Its got a high spot in the middle, its not real smooth, and since I couldn't do it all in one pour, it looks like a patchwork quilt. I'm happy its done.
A long way to go yet, but already the upstairs, even though there are no stairs yet, has become a storage area. Note the oil stain on my brand new plywood. I stepped on the bottle of air tool oil.
I picked up a 34" entry door for the ground level entry. The four foot wide opening will eventually get a small scale garage door. I have a 36" door for the upstairs entry, it will open outwards onto a landing, there are four steps inside the door opening to get upstairs. The door had to be lower than floor level due to the limited headroom, I couldn't have put a proper header over the door had I built it in higher.
The opening under the upstairs door opening will be a storage closet under the landing, accesible from inside. I figured that was wasted space anyway, might as well use it.
Obviously the bottom floor is 16" below the door opening, stairs are fine for people, what about getting bikes in and out? My motorcycle lift will act as an elevator :)
Next? I think finish the end walls on the top floor, then finish sheeting it, and tar paper while I try to figure out what to do for siding. Possibly cut the stair stringers and build the landing during the week too.
I'll update as things happen
Thedoc14
Melb, Australia
That was some serious lumber hording going on. Where you able to use any of it or had it rotted away.
By the looks of some of that it could of been used by recycled furniture makers?
Nick.
novaboy009
Pittsburgh, PA
A big bonfire would eat a lot of that wood in a hurry. Was your dad a mild hoarder? That's more scrap wood than any man would have use for in a lifetime. Maybe you can use some of it in the repairs?
jlckmj
SE Wiscosin
I don't know about up where you are at, but down here in Wi. the powder post beetles would have had a couple million holes in that pile of lumber. It looks like it is mostly old barn wood, and it was most likely not kiln dried.
That is (was a major project), my hat is off to you!
When I bought my farm house, I spent a month cleaning out the old machine shed of lumber the farmer had hoarded. I think he had saved every piece of lumber ever found. I found pieces of 2x2 that were only a few feet long with a dozen nails in them that he had saved for future use.
Jim
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That looks like some of the stuff my dad would do. I got into a mess last year when I had to redo the kitchen in their house in order to sell it. The concrete back porch was 2' thick at least and the kitchen was built on one of the original pours with 2x8 joist over it. So any water outside ran in on the concrete slab inside and rotted out the joist. That combined with termites for years pretty well ate the complete kitchen addition up. So I feel your pain. Then I had my dad's shed to contend with. Not as big as yours but built without treated lumber and sitting on bricks on the ground.
And yes, what you have is some serious wood hoarding that went on. 14 truckloads is a heck of a lot of wood. That's one advantage of living out in the country. A piece of paper, a lighter, and a twelve pack and that wood would have been gone!!!!
Be sure to keep us updated on the progress.
R
RVDan
North America
I've used some, all that plywood sheeting on the building for instance, but for the most part it was unusable short pieces, or too full of nail holes already to be used for anything structural.
Definitely a hoarder of some sort, he claims it was necessity from having no money, I've been struggling to figure it out. All the scrap aluminum he claims is worth money, but he has never sold any of it, I doubt he knows where to take it.
I could go on forever about the multiple useless things I've found, over 500 drawer slides, cabinet side only, no less than five artificial Christmas trees. More children's bicycles than there ever was children, there is three woodchippers in various states of disrepair, and at least as many rototillers. Over 2500 paving bricks that he brought home 30 years ago, he dug them out of a landfill, they were the rejects from a manufacturer.
Yeah I could go on forever, but that's a whole other thread. Think Bills grunge garage thread.
Zeke
I don't know what to say except you've got vision. Good work on not demo'ing the whole shebang. I suspect by the time you get finished, you will have the same amount of work that it would take to start over.
But, it wouldn't be your dad's.
I have an older garage (1934) that was once used for some wood projects. Nothing was left but an old bench and some shelves. Nevertheless, I have kept it all original to the way I found it.
I'm the second owner of the property in 82 years.
loveall13
Auburn, KY
Dan,
It's pretty awesome that you are cleaning up and reworking your childhood home to suit your needs.
Jeremy
Thedoc14
Melb, Australia
I guess if you knocked it down, the local council would hit you up for new permits etc, so well worth the heart ache to not deal with them.
I agree with the others above, where I am a couple of bags of marshmallows and the kids would be set....
R
RVDan
North America
If I was allowed to burn here in the city, things would be easer, unfortunately I'm not allowed.
The simple sollution of course is to bulldoze the whole property, fill a bunch of bins and have it all hauled away in one shot
but that costs a lot more money than most people think. Around $400 for the bin drop off and pick up, and around a hundred bucks a ton to have it dumped.
Took a day off yesterday. Tonight I'll do some stuff.
R
RVDan
North America
Not a lot of progress this week, just too tired after work to work on my own stuff, but did a little.
I decided my floor was so rough and uneven anyway, a week under water was enough. Poor planning, I filled it with water, and didn't have a plan to remove the water afterwards. I didn't want to ruin an RV water pump with al the sand, dirt, and gravel that I've managed to spill into it, siphoning didn't work because its below grade, I had nowhere below the water level to drain it to, so I ended up bailing it out by the bucketfull. Not a lot of fun, but I got it done.
Needed a work bench, and my bike lift has been taking up my cars parking space in the garage since I brought it home, so its now in its new permanent home in the workshop acting as a workbench
With a place to put the saws, I built some steps for the front door out of some scrap.
Forgot to take pictures of the door. Its hanging by the hinges but I'm missing a door jamb at the moment, I built my door opening at 36 1/4", but somehow, with all the twisting of the building, and using the door frame as a pulling point to bring the roof back into alignment, the opening became smaller, I had to pry one of the jackstuds out, tomorrow I'll run it through the tablesaw at work to make it fit back in.
Dug a couple holes for some cardboard concrete forms and filled them with concrete as a base for the support posts for the second floor landing.
Tomorrow I hope to make enough progress that it looks different.
R
RVDan
North America
yes there is a lot of junk that needs to go. Thats a slow process as I can afford it. 1-800-got-junk gave me an estimate of $4500. Thats not in my budget.
Its pretty problematic, I can take garbage to the dump, I can haul scrap wood to the sawdust carrier, I can sell scrap metal. The problem is all the complete stuff, like aluminum frame windows, old sliding glass doors. Can't dump metal at the garbage dump, can't sell the metal with glass installed. Broken concrete? I have no idea where to take that.
Then theres the **** that my parents left behind that they claim they are coming to get, as well as my Brothers car and multiple engines and transmissions that I may be stuck storing until he gets out of the military in two years.
Omphaloskeptic
Ultima Ratio, Wa.
Wow, you've got quite a project going on there! It sounds like you also have the persistence it will take to see the job done; good for you.
Tell your brother you are going to send his stuff to the scrapper and send him the cash; that will give him the incentive to either get it out of your hair or get rid of his headaches. It's your property now and is yours to do with as you wish. He can piss and moan but he'll get over it. Same deal with Mom and Pop; if they haven't got rid of 'stuff' in all the years they lived there, why should you let it burden your space any longer?
R
RVDan
North America
Thanks for the support.
Your plan sounds simple, but its not as simple as it sounds. My brother is in the military stationed on the other side of the country. If I decide to get rid of it, theres nothing he can do about it, he's stuck there. He gets leave in July, thats when he moves it or gets rid of it.
My parents live 400 km away now, and they have no money. They will come and get stuff when they can afford to. In the meantime I have a rule, if its in my way, I get rid of it. Seems like a good rule, but contrary to popular belief, getting rid of stuff is not free, and I have no money or the energy to load thousands and thousands of pounds of stuff into the truck and haul it to the dump for $108 a ton.
Bulldoze it, burn it, bin it, or haul it all away. Thats the advice I get every day. Every option is thousands of dollars that I don't have and I can't find anyone that wants to cut me a cheque to get it done.
Today, I slept till noon and then went to work for four hours. Got nothing done on my workshop except for one important thing
I bought a used wine cooler for use as a shop beer fridge :)
JimVonBaden
Northern Virginia
I would immagine you have a thing like CraigsList there. You might try posting in the Free section and have people come get what they want. It is a good way to get rid of some of the stuff anyhow. You definitely have at least wood worthy of firewood, and some of the metals people will salvage for free. Even if they only take 1/4, it is 1/4 you do not have to haul off.
I certainly know about moving junk, and it is a pain.
Jim :cool:
KPSquared
Wetaskiwin, Alberta, Canada
Advertise for sure. Free ads will attract all sorts of people. . .and they will pile it in their junk pile for years until their kids have to deal with it. You just have to appeal to the hoarders. . .
VWPORSCHEGT3
Gardnerville, NV
Brother I feel your pain on the lack of funds. People like us do what we can when we can. people ask me , "when are you going to build your detached garage" i stare at them blankly and retort "right now if you wanna pay for it"
Good on ya, keep it up man!
RobSmith
NSW Australia
I removed two ton of broken concrete by putting a bit of the pile in the garbage each week...I weighed the garbage each time to make sure the garbage truck could lift it. It took a while but it's all gone now and it didn't cost a thing. Metal window and door frames can be dissasembled then sold for scrap. Just put aside an hour or so a day to address the clean -up jobs and before you know it it'll be all done !
R
RVDan
North America
Free section, I don't know why I never thought of that.
Wood isn't really a problem anymore. It's only $10-$25 a truckload to get rid of, I'm 14 loads already, I estimate only 2-3 left. There is quite a bit that I'm keeping as well.
I like the concrete in the garbage idea, I'm not utilizing my curbside garbage pickup very well anyway.
Metal I sell. It's getting the glass out without breaking it that I'm finding difficult.
Did I mention the wood chips? Next to the bin of gravel is a monster pile of wood chips, that was my dads solution, run the scrap through the woodchipper and spread it around the yard. I'm not sure what kind of wood he considered scrap, considering the **** that he saved, I can't believe anything exists that he wouldn't build with. I think I can put the wood chips at the curb as yard waste, although its chipped lumber and not chipped trees, it started out as trees :)
NUTTSGT
Northern Central Ohio
I'm glad to see you started a thread about your place. You have made alot of progress from the time that you first posted here. Like I said before, one day at a time, just keep chipping away.
Shoottx
Plano Tx
If you live in a community that recycles, there are often compost drop off sites, and wood chips are ok for composting. They do tie up nitrogen in compost if there are too many wood ship in the mix. Since our area picks up tree and shrub for recycling as part of the garbage collection, I have put out as many as 12 bags of wood shavings from the saw and planer (yeah special bags) for collection with no complaints. Now just don't get the garbage cans to close together on pick up day or you get a nasty gram.
R
RVDan
North America
Not a lot has changed lately, general yard clutter cleanup mostly, somebody complained to the city.
Heres the door I put in last week
framed in the landing and put the posts in
Poured the footing for the bottom of the stairs, yeah I'm not sure what I was thinking, a couple patio stones would have been sufficient, but its done now.
Square2.0
Damn man, thats quite the project you got going there. I wish you the best of luck with it.
R
RVDan
North America
I'm not the kind of guy to blame the tool when a job doesn't go right, but at this moment I'm absolutely convinced that circular saws were invented to cause grief. My stair stringers are cut out now, what a nightmare trying to get the saw to cut straight.
It wasn't the saw motor, or the blade, it was that spring loaded blade guard. It moves fine when cutting straight across something, but trying to run that angle across the stair stringer it just didn't want to roll up. It would bind, grab, and force the saw sideways.
Maybe next time I buy a saw I won't get it at a pawn shop.
So stair stringers are done. Build and instal stairs tomorrow I hope.
KPSquared
I always move the guard out of the way before I start a cut. I never let the material do it for the exact reasons you stated.
Looking good. Hope the cleanup continues. . .looks like your working in the middle of a landfill!
R
RVDan
North America
Yeah that's how it feels, junk everywhere, uneven terrain, it's tough to prioritize when you're this far under and only have two hours a day to work on it.
Baby steps. Once the building is done it will get easier to process everything else
Red Leader
Denver, CO
Wow, those first pictures were kinda depressing the way it was pretty much heaving in on itself. My hat is off to you - that is an amazing transformation.
I don't think I could have done it. But it looks like you are doing it right and have the right vision.
Keep at it! We're rooting for you!
-RL
R
RVDan
North America
-RL
Thanks :beer:
Its been a long road, but now that its a structurally sound dry place to work things get easier.
R
RVDan
North America
Not a lot has changed on the building, spent a lot of time digging up the yard, I don't believe in burrying garbage, so I've dug up a truckload of old roofing shingles, broken glass, scrap metal, and lots of shredded plastic of all sorts.
Layed some bricks down at the entrance. They're not straight or even, but the ground isn't stable since its all been dug up to break out the extra concrete foundation walls that didn't belong, so in a year when the ground has compressed, I'll pull the bricks up and level it.
The wide door opening was waiting for a scaled down roll up garage door, but with no budget at the moment, $25 worth of materials built a quick door. I screwed something up in the hinge mounting so its an inconveniently self closing door at the moment, I'll fix that some other time, I need wider hinges, these ones just barely catch the edge of my frame since the sheeting is so thick.
The upstairs door is in. Frame needs to be closed up a bit, I build a 36x80 door frame, but I couldn't turn down a $40 34x78 door.
Shoottx
Plano Tx
Lots of progress there. Sometimes it doesn't feel like that but it is a ton nicer than the start.:beer:
