The yard / gardening hand tools - thread.
Do we really need two threads for this?
probably one of my oldest tools. hay fork with no discernable markings (unless you count the scorched end of the handle.)
Kelly Axe & Tool Works, Charleston, WV - sickle - presumably manufactured after the company's acquisition by American Axe & Tool Co. in 1930, when the name change from "Kelly Axe & Tool Co." took place.
neophyte
Pennsylvannia
Those look oddly familiar... I wonder what they copied?
I'm willing to bet the parts are interchangeable.
Felco pruners became the industry standard, and practically every brand trying to make “professional pruners” makes a more or less accurate copy of the Felco design.
Even Ars from Japan sort of copied the design, although with a different spring type and a possibly better release lever.
I think Corona with their dual link system might be an exception, although they also have what looks to be a partial copy of the Felco design, and Florian, with their ratchet design.
A decade or so ago I purchased a Felco bypass and ancil pruner, and have never been sorry about the $100+ they pair cost, due to how much nicer the pruners were to use.
Still, Felcos aren’t cheap.
Beerhippie
Far NE Oregon
Nope, Felcos ain't cheap--but I've been using my #7s for about forty years now--I'm on the third set of blades and anvils.
What is surprising is that they're about the same price as I paid in mid-'80s bucks!
N
Nobody-named-Olli
Fiskars UP(X) 82
Another indispensable tool in the garden are these Fiskars long reach pruners UP 82. Been using them for years, had to repair the internally run pull cord once because the branch I intended to cut didn’t look too big from where I was standing, but it turned out it was. … ;) Repair was easy enough/ no problem. The endoscope is definitely not needed, but I wanted to see what I was doing/ where the cord went.
The cutting head can be tilted to suit the needs, you can pull to cut either on the handle in the middle of the tool, or on the knob/ball on the very end of the handle. Loooong reach!
It’s a great tool.
The UP82 is superseded by the current UPX 82.
Kind regards,
Olli
Outahere
Idaho
I recently bought an ARS 180ZF telescopic extended reach pruner, to use on my trees and thorny shrubs. The total length can be adjusted from 4ft to 6.6ft. The rear handle rotates. ARS says cutting capacity is 20mm, but I think that is being very optimistic. I think 13mm is more realistic. Manufactured in Japan.
Disassembly for cleaning or repair looks easy.
Beerhippie
Far NE Oregon
I haven't used the telescoping models, but have two fixed-length from two different eras--about forty years apart. As far as maximum cutting goes, how strong are your hands? When I was younger, it was whatever I could fit inside the jaws. Not so much now, but that's me, not the tool.
Very well made and parts are still available for the one I bought in the mid-eighties.
Outahere
Idaho
..........As far as maximum cutting goes, how strong are your hands? When I was younger, it was whatever I could fit inside the jaws. Not so much now, but that's me, not the tool.....
I have a little bit of arthritis in my hands. and pain limits how hard I want to squeeze the handle. I read a few Amazon reviews about the ARS pruner, and there were some comments that 1/2" branches were the limit of cutting, even though 3/4" diameter branches can fit into the jaws. I haven't used the tool yet, so I don't know what the real limit is.
Outahere
Idaho
I bought these ARS needle nose pruners at Amazon for $13. Made in Vietnam using Japanese materials. The quality is good.
A few days after receiving the ARS pruners I saw that Felco sells a similar tool, but with some upgrades: chrome plating and polymer shock absorbing bumpers. At a price of only $21 ($18 at Amazon) I think it is safe to say they are not manufactured in Switzerland. A 2023 review at Amazon says they are manufactured in Taiwan.
Beerhippie
Far NE Oregon
A few days after receiving the ARS pruners I saw that Felco sells a similar tool, but with some upgrades: chrome plating and polymer shock absorbing bumpers. At a price of only $21 I think it is safe to say they are not manufactured in Switzerland.
Gotta love this picture:
"How'd you get that big cut on your hand?"
ChoriAngle
I’ve been mixing old-school yard tools with a bit of indoor green stuff, and it’s been a nice balance. For anyone who keeps a small greenhouse or rotates potted plants between indoors and outdoors, I’ve had good luck sourcing houseplants from a place that ships them healthy and quick, which makes the hand-tool upkeep on the delicate ones way easier.
Gmonkee
These two were my first buys coming to Mexico. The pulaski is hand forged locally probably 20 years ago. The shovel is mex made campesino gear. On both you buy the tool and find a handle. Over the years I would just find a suitable stick and replace as need be. The shovel now has steel.
It used to be longer.
These were sold in street markets and local hardware stores for about 5 dollars each for decades in Mexico. The poor man's option for tools.
Gmonkee
Over years of yard work I may have accumulated a few loppers and saws. Some were new, some rescued junk and others ones I wore out. I just never could toss any.
I paint them orange as things rust when left in the shed and if dropped in tree litter they are easy to see. Most of this is Truper branded.
In the middle that curved one is a traditional hand forged curved machete. That's a small one but each smithy makes them slightly different. Quality and size vary greatly.
I don't use those anymore as I got all the loppers and saws.
Gmonkee
The last two versions of the Truper pole saw. The one went out with USA made problems, the plastic handle. The other two are the much better with the hook and being longer. Take the pole off it's a hand saw.
They cost about 20 dollars or less and the hooked version is great. It retired four others to reserve duty.
We have a cluster of bamboo to get new poles from when in need. Long, short, curved or whatever bamboo provides.IMG_20260606_101722.jpg
Gmonkee
Two more.
No parts compatibility between the three. The Felco is thicker, all have comfortable handles and cut up plants. The black knockoffs have a loose cutter blade. They also omitted the rubber bump stop. Not sure it matters.
All the insert blades are very different on the three.
If I only have to keep one it's the Pretul, lower line of Truper. Because they are the least worn. Unfair comparison from the start because the other two had to be disassembled, cleaned and readjusted before any use. They were abused dearly before me.
Jim_No_Garage
Millington NJ
I was doing some cleanup at Dad's house and ran into something my hedge trimmer wouldn't cut. Dad has a pair of "Geared" loppers in the garage that cut some decent sized branches like butter.
I think they were older model Fiskars Power Gear loppers (older being 20 years old now probably). We are clearing out his house now so those are coming home with me! Thanks Dad!
No pic's - sorry
