nwav8tor
I'm trying to decide what thermostat to get to control my 75K ng garage heater. I found two Honeywell heat only thermostats (1 analog & 1 digital) that have temperature ranges fro 35-90F but they don't have a Fan-ON control switch. I also found a digital termostat that can control 1 heat & 1 cool system that does have a Fan-On switch (I'd just simply not use the cooling control terminal) but the lower temp limit is only 40F...
My question to those of you that aready have installed shop/garage heaters is what would you consider more beneficial, the 5 degree lower temp ability or the manual fan control?
Thanks,
Paul
Thanks,
Paul
