Dick in Wisconsin
Had a new natural gas forced air furnace installed last fall. Installer hooked it to our existing LUX programmable thermostat; thermostat is probably seven or eight years old.
Twice in the last two weeks I've noticed that the house is cold. I check the thermostat. Its set to 74*F, the temp is 68*F, and the furnace is not running (I have the blower set to run all the time).
So I go to the basement, blower is blowing (like it should), but no fire from the burner. I turn the switch off on the furnace and the blower shuts off. I wait a full 30 seconds. Turn the switch back on, blower comes on, burner doesn't light.
Then I go to the thermostat upstairs. Turn the three position switch from HEAT to OFF. Wait a full 30 seconds. Turn it back from OFF to HEAT. I hear the thermostat click.
Back down to the furnace in the basement and by the time I get to it, the burner is light, lots of fire where it should be, fan is running, furnace is heating.
I don't think the problem is with the furnace. I think the problem is with the thermostat.
Edit: Furnace is a Bryant 925TA48080E17.
What do the experts on the forum think?
