Thermostat Positon
fishspike57
Hudson WI
Putting in a Big Max. Shed is 36x48. Putting the heater in South West corner so it blows over vehicles. Best place for thermostat in the North East corner approx 46 feet away? Under the heater or in the middle on far side? Any opinion welcome. Looked in the manual and didn't see a recommendation? Might of missed it
Thanks
The Cobbler
out pf the path of the heater . I would think the same side as your heater well away from it
somewhere where you want it to be the desired temp
preferably not on an outside walls ( but that's not too important if you have good insulation)
ford33
Chicago, IL. USA
Put the t-stat where you will work most often. That's the temperature you want to maintain while working. If you put it on the far wall but stand near the heater, you will be too hot.
Also, be sure to install ceiling fans. They help a great deal in moving the hot air from the ceiling down to the floor and leveling the temperature of the enclosed space.
okoyoray
Backyard
The best place for your thermostat is towards the center of your home. However, make sure they are not in direct sunlight, above air vents, near the kitchen, near door/windows, or in the hallway
