Thermostat question
Cougar
Wisconsin A little south of the Frozen Tundra
Have a Trane thermostat Model BAYSENS019B, MFG. number 91K91.
Controlling a Trane RTU.
Was working fine then one day went blank.
It's getting power, battery is good.
At first thought it was a problem with the RTU, but swapped a thermostat from another unit and it works fine.
Can anyone tell me if this thermostat is shot or is there a fix.
Thanks
gmcgeo
there are only a couple things that could be wrong,
Dead battery. " you checked that"
loose wiring or wiring problem
tripped breaker, or blown fuse
tripped safety switch
or the furnace door is opened and not closing the door switch all the way.
if you changed out the head and it it works else ware i would say wiring issue or safety switch tripped
if none of the above the thermostat is toast, i have never repaired a thermostat but i don't see why it can not be done.
Sevenhills1952
Virginia
I looked it up, they're expensive! I see used ones on Ebay, etc.
Other than basic troubleshooting, check PCB over with magnification (bad solder connection?) about all you can do.
I would call Trane customer service, maybe they have repair service or replacement recommendation.
Sent from my SM-S205DL using Tapatalk
Milton Shaw
A lot of units the drain pan switch is wired to turn the thermostat off and has to be reset to turn everything back on. Thermostats do fail so keep checking it.
Sevenhills1952
Virginia
Clean those pins with alcohol and q-tip. Lightly brush with alcohol , blow dry with hair dryer on low. Check solder connections on pcb where those pins are. You may be able to salvage it. A soft bristle wire brush is good also for pins, be careful they're pretty delicate (surface mount components especially).
Sevenhills1952
Virginia
I tried looking closer...solder may be ok. Looks like bad pin to contact corrosion, moisture or arcing. If everything cleaned well pins and socket, use electronic contact spray, it may work.
Walkers
Cave Creek Az
Save yourself some frustration, put a new one on. Arc burns are bad for sensitive electronics like that. You may he able to spend several day solder in new components and save yourself $29, but it is not worth it.
