Thermostat Wiring
ESwartz
I'm in the process of running wiring for a heater and thermostat before I insulate my ceiling.
There is an existing hole with a 120V, 12-2 conductor going down to an outlet, can I put the thermostat wire through that same hole or should I drill a new hole strictly for the thermostat wire?
Thermostat wire I'm using is 18 ga.
Thanks
Mustang51js
Haskell nj
Usually speaker wire or cable you don't want to do that to. But t-stat there isn't anything for the power to interfere with
E
ESwartz
That's what I thought, interference, but I couldn't think of how it would cause interference with the thermostat.
Thanks again.
Milton Shaw
I would put it in a different stud cavity. With digital thermostats and digital controls on all units now. I would not take the chance on something as easy as moving it over one space before you sheetrock the walls. No cost about 2 minutes time now. Do it.
brewchief
This, on a garage heater it probably won't matter but a bit of separation won't hurt, I would run at least a 4 conductor wire as well, that will give you a common to power a digital stat and the ability to run the fan separately if your unit has that feature.
