Thimble for Wall Thicker Than 6"?
Graham08
Iron Station, NC
Does anyone know of a source of a wall thimble for B-gas vent pipe for installations where the wall is greater than 6"? Or, would it be acceptable to roll an extension and rivet it to one side of the existing thimble?
I'm venting an Enerco low-intensity radiant tube heater horizontally through my exterior shop wall, which is 2 x 6 construction. I got a jumbo vinyl block so I would have a smooth surface to seal the thimble to (and a clean looking install), but it brings the overall thickness I'm trying to pass through to around 7-1/4".
I have a slip roll, so making the extension would be cake, just don't know if it's kosher to modify an existing thimble.
Charles (in GA)
50 mi south of Atlanta
Most thimbles are, I think, good for an 8 inch block wall or similar. If it simply won't, as in the two pieces won't meet when you put them thru, and you have the capability to roll a tight fitting piece out of similar material, I'd go for it.
Charles
G
Graham08
Iron Station, NC
Thanks for the link. Looking at that, the problem may be that I'm using 4" vent (same as the heater tube). The 4" thimble expands to 7", while the 5" expands to 8".
