Thin 9/16 Open End Wrench?
karoc
Hemphill Tx
Besides grinding one down to make it thin, is there a place on net that sales thin wrenches? Any links or suggestions?
The Cobbler
I bought a set of metric & sae thin wrenches several years ago, they have not been used a lot but are handy when needed.
Prior to that I bought one on ebay for a saw that was missing the blade wrench . it was home made by someone on a plasma or water jet and hardened.
Rabid Badger
Another vote for Capri or Olsa. You'll see Duratech pop up if you look on Amazon, but they're made of plain carbon steel rather than proper CRV and are best avoided.
30-30remchester
I just picked up an old long tail Craftsman double open end 9/16 thin wrench last week at a yard sale.
neophyte
Pennsylvannia
How thin?
European open end wrenches are usually thinner than American wrenches.
Tappet wrenches are usually thinner than European open end wrenches.
US pattern Check Nut wrenches are usually thinner than tappet wrenches.
Then there are wrenches that are usually made from punched or laser cut sheet metal, that are very thin.
Slimline wrenches from Snap-On and similar truck brands may run similar to tappet wrenches, but I haven’t checked.
There are also thin end adjustable wrenches if there is enough clearance, that might cost the same as an individual thin specialty wrench.
The adjustable wrenches are made by Irega, Bahco, Top (Japan), and a few other companies, and may be rebranded by others like Channellock.
The thickness varies, as does the length.
username2
My apologies for the above post. The wrench I mentioned is not a 9/16 but a 7/16×17/32.
I was going to run to the OP to shout 'TAPPET WRENCH', but I was too late.
But, that is a cool looking wrench. I really like the logo. I'd put that in my little box of weird Plomb 1/4" stuff and 9/32" drive Snap-on...all made from alien technology I think. Being pure hobbyist, every now and again I'm tempted to go pure vintage in the garage.
30-30remchester
I as well enjoy the odd and purpose-built tools with cool logos. I haunt pawn shops, yard sales, and Re-Stores to find such tools. I just posted another what is it that I picked up at a pawn shop. I have acquired quite a few over the years.
tamaraw
What's the application?
TOP Kogyo makes some great adjustable wrenches and have a few with thin jaws, that might be an option if you don't want something application specific. Examples:
Otherwise, I would probably pick up a black oxide Proto and get grinding. It's a nice crossroads of quality+price and you won't have any chipped/flaking chrome to deal with.
Wright has an oxide combination wrench for a little less if you aren't in a hurry:
The Proto check nut wrench is JKE18 but looks like it might not be in production at the moment. You can get a Martin for a little more if you need that form factor:
neophyte
Pennsylvannia
The Proto Check Nut wrenches are the same as the Martin Check nut wrenches, just with a different brand name.
A 9/16 inch check nut wrench is listed as 5/32” thick on McMaster Carr’s website.
They list the wrenches as “Tight-Clearance Open End Wrenches”
Several US manufacturers used the same numbering system for certain wrench types including Check Nut wrenches, so the model number from Martin should bring up other wrenches of the same size from other manufacturers, although you have to be careful, dince there may be letter prefixes or suffixes since some wrench sizes used the same wrench blank forging.
K
karoc
Hemphill Tx
Thanks guys for all suggestion, I order tapped off Amazon as suggested. But I sure like those suggested by neophyte and tamaraw
ecotec
I’ve got a set from V8 Tools - I think they were about $30 and have been lifesavers.
I have sets like these in SAE and metric. I don’t remember the brand. I also have a bunch of SAE tappet wrenches and a Bahco thin jaw adjustable.
I have a Stahlwille Motor 10 set that is also pretty thin, but I have never actually used it.
drmarkr
Tucson
Metric ony?
I haven't seen an Imperial fastener on bicycle since Schwinn stop building in the US !
The 13 will work for the half and the 14 will work for the 9/16. They're pretty damn thin so they're not going to take a whole lot of torque though...
When I saw the title of this thread I immediately thought of my Park cone wrenches, lol.
So did I ! I only have the 15mm, in the "old" style.
Capri, Olsa, V-8 all make super-thin open-end wrenches. The trade-off is that they have GIGANTIC heads and generally aren't suitable for high-torque applications.
If you're after something more along the line of @30-30remchester 's Craftsman unit (post #8), you want a tappet wrench. While there may be variances in head thickness, most of the (now defunct) American tool makers made them with relatively the same dimensions. Indestro's numbers below. Pretty easy to find onesie-twosies on ebay. Indestro, Craftsman, Duro-Chrome, Bonney, S-K ... they all made them.
cannuck
Rural SK
I used to work with HV electrical stuff and thin wrenches up into the 3" range were essential, as many connectors used a pair of thing brass nuts to connect paddles to bushings, etc. So, I have pretty much same sizes in "lock nut wrenches" in both metric and US. I long ago bought these from what IIRC was a Taiwanese brand. Have seen similar from US, but at stunningly high costs. Most "normal" locknuts I can get with my Stahlwille combos.
Steve_P
Lots of threads on this, but it depends on what "thin" is to the OP. 1mm? 4mm?
The V8 thin wrenches I have are the absolute shittiest tools I own. I hesitate to call them a tool. Stamped from sheet steel, not forged, not broached.... Plating is absolutely horrific. They're just absolute garbage.
have Facom in Metric, I'm guessing most are ~3mm thick, Park in metric, probably 1mm thick, and Craftsman "tappet" wrenches in inch sizes.
If I was buying today, I'd go Capri, which look to be copies of Facom
Wrench97
Southeastern Pa
Tappet wrench or Thin wrench, if the nut/bolt head is that thin it's not made to have a lot of torque on it.
I have some very old Plumb tappet wrenches a few Snap On in SAE and a Matco "Thin Wrench" set in metric I mostly use for sway bar links and brake caliper slide pins.
Chipm
Georgia
I have a Craftsman set that is five or six years old. I don't even know if it is really Craftsman or is counterfeit, because I got it on eBay, but they work well. I use them several times a week to counterhold brake rotor pins.
