ScaldedDog
My new Eaton 5HP 80g compressor arrives next week, and I have some questions as I plan the wiring. Chief among them are if the thin "single slot" circuit breakers are OK to use for a 5hp compressor? I'm thinking of using this one:
https://www.homedepot.com/p/GE-Q-Line-50-Amp-1-in-Double-Pole-Circuit-Breaker-THQP250/100356520
As you can see from the photos, I need something that will fit in the space I have, or I'll have to use the spot on the upper left where the existing compressor is serviced with a wide 40a breaker. (The existing one is a "5hp" Craftsman that's wired to a dryer outlet. That compressor will be going away, but I'd like to keep the outlet useful.)
Second, my run from the panel is very short - less than 4ft - so I'm planning to use 10g THHN. Solid, stranded, or does it matter?
I'm installing a disconnect, even though not required that close to the panel, for my own convenience. Thinking of using this:
https://www.homedepot.com/p/Square-...kW-Non-Fuse-AC-Disconnect-QO200TRCP/202353314
And wiring up the compressor with this whip:
https://www.homedepot.com/p/Southwi...lic-PVC-Conduit-Cable-Whip-55189307/203373118
Do any of the experts who help us out so much on this forum see any issues with my plan?
Thanks!
Mark
Sent from my SM-G986U using Tapatalk
Thanks!
Mark
