Thinking you guys may enjoy this...
VegaS10
Fayetteville, NC
I lurk this fourm alot, and rarely post. If this is in the wrong section, mods please feel free to move it.
I'm copying and pasting this from my main forum, as alot of the guys there were asking tons of questions about getting into a auto tech program at their local community colleges.
I figured I'd take pics of where I attend to show them what's available.
Enjoy....
It's rounding off the end of the semester, and the shop is trashed. It's cool though, because it looks like a real shop. There's tons of activity, which is cool, and we're seeing alot of "teamwork" from the students.
Enough of my rambling, on with the pics.
Right now, I'm in the machining class, steering and suspension, and my 4th electrical class (they stress the **** out of electrical).
This is the insides of the machine shop:
Flat sander. It's not used much, but it's there.
Piston press. The machine on the right is a small press which pops the piston pins out. The machine on the left cooks the rods and heats them so the rod and easily pass through the piston.
This is a really awesome resurfacing machine. I've done about 5 heads so far (3 Hondas) and it's a really easy machine to use. Setting up can be a pain in the ***, but once done, it's a breeze. I've setup a couple of blocks, but haven't machined one yet.
The valve seater machine, this cuts valve seats in heads. Pretty easy to use once it's setup. I cut valves in my buddie's H22 head. We used oversized Ferra (spelled wrong) valves and new valve guides.
Flow bench. Truly badass. Our teacher for this class is the dept. chairman. He's got a huge interest in circle track racing and 350 chevy engines. We spent about a week watching him port and flow a Dart head. He showed us how to make huge improvements over stock, and he gained a considerable amount even from the Dart heads.
Here are some heads:
Some students boring a 350 block:
This is the lathe. One of our assignments is to make a brass drift. Our instructor assigns you a 1 inch thick, 12 inch long brass drift and has you cut it to a certain diamter, chamfer the ends, and knurl a handle on it. It's a very time consuming process, but in the end, it's a handmade tool you get to keep.
Inground Dyno.... Not really used until you get to the performance classes.
The BIG press. I used this to do alot of suspension bushings on Steve's ITR over the summer.
The alignment pit. Uses all Hunter products. Very cool and easy to use. If you have a lowered car, it may not happen...
The tire changer, Snap-On. It does 24s, not sure if it does any bigger.
The balancer. Hunter 9700. Does Roadforce and everything. I have mastered the hell out of this machine. Truly awesome.
Brake lathes for disc and drum. These are older than dirt. However, if you can work these, you can work any of them.
Simulators. These do Airbags, ABS, electrical, spark, etc. really cool.
On car brake lathe. This lets you cut the rotor while it's still on the car.
The parts washer. This thing is huge. It can easily fit a 350 and 2 heads with no problem. I've seen this thing remove sludge, tar, gook and all sorts of **** and when it's done, it looks amazing.
Chain hoists in the ceiling:
A block getting ready to get honed.
Flywheel resurfacer.
Random pics of students working hard to get thier engines back in their cars:
Overall, it's a great learning experience. There is TONS of hands on learning, and you can pretty much rebuild your whole car if you time it right. I've learned alot of new things, and gained a new appreciation of mechanincs. I will say though, they push electrical VERY hard, so if you plan on working in this field, you better be ready to learn wires...
LEVE
On the Willapa
It's interesting to see the demographics of those in the pictures. They're not the typical 19 to 22 year old students, are they?
Can I come and "audit" classes and still have fun with all the machines? That would be cool!
airbuff101
Top shelf equipment there!
You sound very enthusiastic, that's great.
Rob
mrholeshot
MEMBER EMERITUS
Looks very casual. Those older than dirt brake lathes are still the best. They still produce those machines and is copied by several Asian Brands. For a tech school I see a lot of saftey issues. The one that really alarms me is a small block chevy engine sitting on a work bench. The rest is just typical working shop but that would never fly in my shop. That could get someone seriously injured or killed.
diesel research
gulf coast, TEXAS
Let's hope this doesn't turn into a "safety violation scavenger hunt".
OSHA could find flaws with anyone of us, and 6 different guys will give 6 different answers as to what is acceptable and not acceptable. We learned what is not safe, most likely through experience. Unfortunate fact of life.
Looks like a "fun" indepth experience. Hope the continuing education doesn't stop for you.
As for age demographics, looks normal to me. Saw several in their later 40s/50s I had already worked the field 5 years, ranging from "pit crew" to engine overhaul to welding/fabrication before going to school......AMAZED to learn how much I did NOT know. Sure I could turn a bolt and replace the parts that I knew commonly failed, but learned a lot more.
Plus it made a great conversation starter/resume fodder for later job interviews. "so uh, I have to ask: why did you go to school if you already had the work experience?" me:"what can I say? Technology and technique is ever changing, I am always trying to expand my knowledge and keep up to date" Guess who always walked out of interviews with job offers? :D
