Thinwall sockets?
SkidooRider15
St. Paul, MN
Are thinwall sockets only in impact style? I did a search on here and found that people talk about the thinwall sockets being only impact. :headscrat I am just looking for a regular thinwall socket (5/16") or a set of thinwalls. I need a thinwall to take apart the needle seats on a snowmobile carb.
Thanks in advance guys!
ravenzfusion
I'd consider my craftsmans thin wall compared to all the other brands of sockets i have.
Dmoen
I have a Socket I had to chuck up in a lathe. Only use is for carbs on Tecumseh. Mainly jiffy model 30 ice augers.
Leoruiz
It would be very interesting to call their service dept and ask what they use for that task.
I bet they'll send you a couple for your time to inquire ! :thumbup:
I've gotten all kinds of stuff over the years from small tools to .pdf files that aren't on the net to actual mechanical drawings. Often with a sticker, t-shirt, ball cap.etc.
These companies spend a fortune in support for us rednecks. Just ask.
2oolhound
BC Canada
When it comes to chrome most manufacturers make their sockets as thin as they dare to withstand the force necessary to apply required torque for the size of fastener the socket may encounter. Cheap brands made of inferior alloys and hardening procedures will be thicker than the known brands. if you need thinner the lathe is the way to go but chucking it in a drill and running it against a file will work too. Steel will fail at a fault or stress riser in it's composition. In this case that is the deepest scratch the file made on the surface. If you need to apply heavy force with a thinned down tool you should smooth the surface with fine emery cloth to remove all scratch marks (stress risers). This is why a lathe is superior, it is concentric, not always what you achieve when hand filing. For carbs hand grinding should be fine.
Here's a shot of a socket that has been turned on a lathe and then polished to remove stress risers. It's next to another thin walled snap-on socket but it's now about 3/8 the thickness at the very tip and tapers to about 5/8 of the thickness 1/2 way up at the end of the broaching. It still withstands torquing 35 ft lbs.
rice rocket
Snap-On, cheap brand?
Let's just say their design goals were different. I bet the Snap-On was designed around withstand much much more torque than the Hazet. Maybe there's no rust over in Germany. ;)
2oolhound
BC Canada
Who said snap-on was a cheap brand? I think you mis-read my post. Actually my hazet and snap-on sockets are both thin walled compared to many others on the market as stated above. That's why I used them both in the above photo, they were near the same dimensions to begin with and the photo demonstrates how much thinning was done. I guess I should have made that more clear. I turned the hazet down because at the time (1972) it was the easiest whitworth socket to find at the time, purchased just down the street and around the corner. I would have the same expectations from my snap-on sockets, they are 1st rate also. I believe in turning down top brand tools as opposed to cheap ones when you want a tool you can re-use time and time again. If it'd be for one time use I'll try a cheap tool from my scrap bin but if it's something I want in my box I use good ones off the get go because I know they will take it if anything does.
I will only use the turned down tools where they need to be used due to clearance issues because let's face it, they've been weakened. If the stock tool doesn't fit I cross my fingers and try the custom one.
rice rocket
Ah okay, I thought when you said "has been turned down", I thought you meant from the factory.
Negen
Seatltle WA
I think he is saying that higher end brands can use thinner walls due to stronger steel. It is clear that he stated that the hazet was the one he him self turned to make even thinner for the need that he had.
Thanks 2oolhound that was a cool reply. Good info there.
Wamsutta
Amarillo, Texas
If you want thinwall chrome sockets, MACs are the thinnest. Make sure they have the letter R at the end of the part number.
