This free SO box even worth it ?
R
rword
Honestly, it doesn't look that bad--I would check the bottom pretty good. I've often come across old boxes with rusted out bottoms.
At that time, every tool company must've had a sticker like that. I've got a round Mac version inside the lid of my Craftsman top in the garage.
Unfortunately someone put handles on it too which kind of irks me lol IMG_1539.jpeg
Some other members of this forum look at that as a minor challenge.
There are several toolbox restoration threads where that was only a minor concern compared to the #$&# they dealt with. ( It definitely was not any of my work, just so we are clear).
Bottom rot would be a bigger concern to me.
You don't need to restore it to brand new, some like to let them keep their battle scars.
cody1325
Southwest Virginia
In my use, that wouldn't be so much of an issue--heck, even if I kept it in one place that handle would be useful--like to hold my grease rag. Occasionally, I have to lift my Craftsman machinist's box off the hobby bench to clean, and if it weren't for the handles--that wouldn't be happening.
bonneyman
Desert SW
Snag it and take a shot! I've done boxes that were pretty rough and turned them in to decent users.
Shiftless
East Bay SFO
As others have already said, look at the bottom and also the drawers. If they come close to decently sliding in and out, grab it. If half of them are missing or twisted up, grab it anyway and salvage the badge etc.
driftpin
Why wouldn't a box owner use either sandblasting or vinegar soaking to remove the rust? Or perhaps electrolysis? Much easier than sanding. "As Ron Popiel said, "set it and forget it!"
I have a few crown top Craftsman top-handle boxes, a Kennedy hip-roof box, and a Kennedy machinist's chest. They're all sitting because I have other projects to do before these get any attention. If it's gonna be for sale, realistically, how-much are you going to realize in the sale, vs your time/materials spent?
If you will use it, then what level of repairs or finish will it get? In my case, I probably should do some 80 grit scuff work, and fix any repairs (I have a multi-process 120/240V welder) and then paint it with some type of durable, serviceable paint. Then again, I'd make more $ by finishing one of my motorcycle projects.
Take pics if you do work on it, we all enjoy seeing the silk purse from the sow's ear. It might get us to begin to work on our own collection of old toolboxes.
1Bad55Chevy
Leave it as is just clean the slides.
I would give it a good rub down with this to make it look good.
R
rword
I’d like to try to fix the big dent but not sure how big of job that will be
Zrxrunner
Eastern Iowa
That's an awesome score, especially for the price! Lol. I agree...make sure everything is straight and drawers slide well n then just some polish n lube. Looks like an awesome road style box!
bonneyman
Desert SW
It'd be a bit of work but I'm sure you could pull it out and straighten it enough that paint (maybe a little putty) would make it almost unnoticeable. Or you could cut the mangled part out with a dremel and fashion a square tube insert to fill the hole.
If I could do this with the previously posted blue S-K box then I know you could repair your box. Not invisible but original strength and decent appearance.
Buckeye93
Anyone ever use Poppy’s Patina kit? Maybe that would be an option on this project? Curious what others may have experienced with that product
Shelbylex
Malco sheet metal clamp like this and a body hammer should do most of the straightening you need.
Is there a specific model you recommend, Zrxrunner? (I have at couple of socket boxes with bent sides) . Do you simply put the bent metal in and clamp down with good results or you use a body hammer first?
mervyn
Northeast Missouri
take It apart and clean it. coat it with linseed oil and use it. Also there will be some goodies under the bottom drawer. I guarantee it.
Found a long forgotten insurance check in the bottom of mine. From tge late 90's. Box belonged to a good friend that passed away.
Zrxrunner
Eastern Iowa
Malco brand just like that pic. They work wonders with bows in flat edge panels. Its hard to explain with a lot of metal working tricks without just trying. Im no expert, but took auto body course after high school and some of the best tricks were just getting creative and trying different things.
The Cobbler
as above poster says, hard to explain, but look at how it became deformed and try to reverse that . different sized pcs of metal , chisels etc can be your friend. by no means am I expert on banging out dents & twists, but with patience, a bit of ingenuity and trying to reverse the damage by how it deformed can go a long way .
whateg01
doo dah, kansas, usa
If you are going to beat on it, use a nylon hammer to avoid more stretching that you would need to undo. Or, if you are using a metal hammer and dolly, take care not to stretch it more.
Provincial
Near Salem, OR
When I work metal back into shape, I try to imagine how it got into the distorted shape and reverse that. I don't try to "force" the metal back into shape. I try to "coax" it back into shape.
CR888
You did a wonderful job. Congratulations 👏 I know it's only time & a little skills but what many would see as trash became treasure again.
