t4runner
This is why I don"t loan tools
What the hell!
How do you swallow a wrench that big.
I'm assuming the guy was alive, just out cold?
Anyone else see what looked like blood get smeared on the dude's lips when they pulled the far end out?
chroming came off the wrench from stomach fluids.. definitely not a quality wrench![]()
Just what the hell ?
Indeed! These comments are reason enough to not click the link.![]()
Too bad the closed end was not towards the top -- would've made it easier to yank out.
It's actually a laryngoscope used for Endotracheal intubation, I carry one on the ambulance and have used it quite a few times. The reason you were waiting for a tooth to go flying is because the "doctor" either doesn't know how to use it correctly or just doesn't care. You are taught to never, ever pry back like that because it will remove the front teeth in short order. At least in the U.S. the manikins you practice on before they let you loose on real people are built with a jaw clicker. If you are using the wrong technique and pry back on the teeth, they will click loudly letting you know that you just failed.Did you check out the doctors pry bar? Was waiting for a tooth to go flying!
