This week in laser cutting...
bsaint
Manchester, CT
I wanted to make a sign for the new shop to hang on the door. I cut out all the letters. These are the raw letters with a E with a sample finish (before painting.) They still needed to be deburred and cleaned up.
Note all the pierces. I ended up cutting it out of thicker material than expected. I should've used a lead in but they will still clean up nice.
Then I needed to make a bracket for hanging my desiccant dryer on the wall. Below is the flat pattern then hand formed in a vise. Ill weld up the corners of the gussets before I paint them up. So it'll only have two stringers on the whole piece.
Everything is all hand programmed, even though I have access to a post processor. Sometimes its nice to have complete control over the movements.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
It would be really cool if you would take the first letter "O" and split it at the top, then have a vinyl decal of a welding torch above it like it's being welded.
bsaint
Manchester, CT
More stuff this week. New parts for our revised 2-1/2 x 48" belt sander. Big redesign due to keeping manufacturing cost down (more assembly time but less expensive parts.)
New laser so the parameters weren't perfect but good enough to get these R&D parts cut.
Smart design with the splits for easier folding and the gusset will hold a lot of weight.
Smokenarrow
Kittanning PA
What kind of cutter are you using for that? I used to build the optic systems for Amada. Whatever system you are using it looks like it is working well.
bsaint
Manchester, CT
No its definitely not home built machine. Its Prima Platino 2040 with a 5kw CO2 laser. One of many different types of lasers in the shop. There are also two Prima Rapido Evo 2 5 axis machines, one is IPG fiber laser the other has the same 5kw resonator as the flat sheet cutter. There are 2 old 2D Mazaks and 5 3D Mazaks I don't use as I am not familiar with them.
bsaint
Manchester, CT
Yes you learn a lot of tricks working as a machine tool service in fab shops over the years. You end up analyzing a lot of sheet metal parts on your own time lol. Fire extinguisher housings, cabinet drawers, metal door jams, hvac vents, etc etc.
bullnerd
Jersey
Yeah, I didn't mean homebuilt, just wondering if you owned the company that owned the machine.
I work for Trumpf, so just wondering what brand.
laser3kw
northen IL
I ran a Trumpf L3030 - kick *** machine.
also impressed with Amada stuff.
never cared for the Mazak, they seemed to be maintenance problems and part hogs.
bsaint
Manchester, CT
Yea newer Mazaks I heard arent that great. I think when I buy a new laser, it will be fiber and an IPG. So since that rules out Trumpf it would be Salvagnini, Cincinnati or Prima. And I would lean towards a Cincy since its USA made and the other two are Italian.
bullnerd
Jersey
You must be at TUSP. I work in Farmington.
Yup, I wondered if I'd ever run into someone from Farmington.
I work in the UPM department. Currently machining the C-15 Coax mirrors.
So BSaint, this is your machine then?
Do you own your own laser cutting business?
bsaint
Manchester, CT
No I dont own the machine but buy time to use it myself. Its an ex customer of mine who knows Im not gonna crash it.
kazlx
Tustin, CA
I love my plasma, but laser systems are that much better. The edges are always damn near perfect.
