Thorsen 77mc Ratchet
Polo_Karl
Northern IL
Cleaning up a Thorsen 77mc 1/4 ratchet. Am I missing a part? Should there be a washer between the split ring and body? It seems to have a lot of play in and out of the head. Thanks!
DadsTools
Yep. They're actually no different than the mechanism found in those cheap round head Taiwan ratchets that came in so many budget sets. Some makes are a little better than others, but they all have the same kinds of issues. There is no washer. It's just the way they were made.
bonneyman
Desert SW
Good little ratchets. The Thorsen roundheads were about as tough as they come. The coiled flat retaining spring allows a bit of wiggle movement, but it should be a problem.
lauver
Belton, TX
That is a good little ratchet and fairly durable design. Most have a lot of end play in the ratchet core. I have had good luck making shims that fit between the ratchet core and the flat retainer spring. Aluminum beer cans are a good source for shim stock (about the right thickness and easy to cut).
You can cut the outer diameter with tin snips and the inner diameter with a circular punch. After cutting the outer & inner diameters, flatten it out with a soft mallet. A quick easy job ready for installation :thumbup:
