Thorsen open gear design question
OctoMan
Newport News, VA
I'm interested in the Thorsen 77 JC318 ratchet design. I have a Thorsen 1/4" ratchet that I use quite a bit although not an open type. I'm curious about the 3/8" ratchet with the open gear design. Thorsen made a 1/2" ratchet with the same design as well. Is there a reason behind it?
BirdMobile
I really like my 1/2" drive open Thorsen. It's simple and solid. However, it takes a bit more maintenance - lube doesn't stay put as well as in sealed head designs. I also avoid using it in areas where there are metal chips or a lot of dirt - for obvious reasons.
Davefr
OR
Thorsen made exposed gear ratchets in 1/4, 3/8 and 1/2".
I've used mine many times and they're a "go to" ratchet IMHO. The reason is that they're able to get into some very tight spots. (ie much more compact then traditional pear shaped ratchets).
I've never had a problem with the exposed gears. They're easy to clean and they don't need lubrication.
Hiball
Missery
That's is the Exact Opposite Reason that there are Exposed Gear Ratchets, The Wright models in particular where Military Issue to be used over in the Sandbox because even Sealed ratchets don't do well with fine particles.
BirdMobile
Interesting. I've often considered this - wondering if it might "clear" any debris out easier. Thanks for the confirmation - I'll be less hesitant using it in dirty environments now.
Packard V8
Spokane, WA
I've got a 1/2"dr Thorsen which has a horseshoe spring metal cover over the gears. Not water or sand protection, but it keeps the larger pieces out of the machinery.
Sort of like bearings which come in open, shielded and sealed versions.
jack vines
O
OctoMan
Newport News, VA
Thanks guys! There was mention in Alloy Artifacts about a military contract. It would make sense they're for confined spaces. Cool.
