Thought is was a Blackhawk, it's not?
BrokenSquad
Hello all,
After spending approximately 4 hours on Google and searching within here I feel like I'm chasing my own tail. I thought this jack was a Blackhawk SJ1/2 but the yoke, caster bracket, and valve body/base are different, in minor ways. I can see where there was a a sticker on it but it's long gone and just adhesive residue remains. No number are visible anywhere but I have yet to clean it. By the way, the jack plate is a rounded square, and I removed a small cover plate over the valve body/ports if that helps identify it. I appreciate any help in identifying it, thanks for you time.
BrokenSquad
That's the idea, identify it so I can rebuild it. I know the pump isn't working at all, going to clean and tear it down once off work. Was just hoping to lean forward on getting parts moving.
paulsomlo
Northern Colorado
If you can't id it, you'll need to tear into it and measure the seals. For that, you'll need calipers. Once you measure the seals, call Hydraulic Parts Supply in Sawyer KS, (620) 594-2247.
BrokenSquad
Thank you, I appreciate the info. This is now on my Saturday todo list.
