Smellypirate
It just so happens I had a low hour Devilbiss 445 pump and a 200 gallon Devilbiss tank, not from the same unit. I really didn't need a compressor this big, just seemed like something that needed to happen. The first rendering was with a test engine of 13 hp with a 4" sheave. I'm on the real motor now and is a 28 hp diesel and an 8.25" sheave. With both engines, I have severe belt slap. Went to a banded 3BX belt, made a spring loaded tensioner and even added three fixed idlers at one point. It gets closer to usable but I'm really just failing to cover up the issue. The slap is on both the coast and load side. I'm pretty good at alignment of sheaves and such, and this is the first time I haven't been able to solve a belt drive problem. It's almost like the pulses from the pump are at war with the pulses from the engine. Any ideas?
