Grant Gunderson
Got an opportunity to pickup a Sunnen LBA660 for essentially free. Not sure if it has any of the mandrels. How hard are these to come by?
I googled it to see what exactly it was and the video I watched he was honing a connecting rod. How much of a use do you have for it? How much engine work do you do? I can't think of what else I would ever use one for, and I do a lot of odd stuff and usually can come up with an excuse to grab a free piece of shop equipment even if I think there may be a small chance I might ever use it in the future. I love having shop stuff just in case and love deals but personally I think I would pass on something like this. I do a lot of work but don't do much engine building. Also no clue on mandrel availability but I'm guessing like most machining stuff they will be expensive unless you can find a deal on them also.It’s a honing machine. Commonly used on engines but also good anytime you need an accurate smooth finish on a hole.
Thanks but that link points back to this thread.-I've used a handful of Sunnen hones over the years, don't recall the models but also not likely to have been the one you're asking about. All of the pieces I honed were closed cylinders with a constant ID. From some brief reading it appears that there may be a problem with interchangeability of mandrels with different models. There also seems to be potential issues/concerns with split ID components like the big end of con rods, and with mandrels themselves. Not knowing what you're going to use this for perhaps this link will offer some insight.
https://www.garagejournal.com/forum/threads/thoughts-on-a-sunnen-lba660.546134/
-That's because I'm an idiot sometimes. Try this one.Thanks but that link points back to this thread.
