Tman said:
Sorry, not online much. Have the net here at work but am living in the camper at the new place while I finish it up. Havent got around to the cabinets yet
Tman; so your on here too! Digger Dave back at you!
Cabinet finishing. When it came time to install benches and cupboards in my shop; the thought of having to paint all of them drove me to look for "another way." (32 drawers and cabinets!)
First of all; all my fixed bench tops have steel (14 ga) tops that a friend sheared and folded for me. (6 inches up the wall and a double folded front edge) For the first while I left them plain and if any stains appeared, a "scotch brite pad" and some elbow grease would keep then fairly clean.
When we were getting North of 49's frame ready for powder coating, I had a "flash of inspiration" (doesn't happen very often!) why not powder coat the bench tops?? Well .. now all my bench tops are YELLOW! (with the exception of the welding table) The powder coat stands up darn good considering how much stuff gets slid around on it.
Next, my Snap-On tool box is red and I had considered doing all the cabinet doors RED as well, until I was wandering through one of our local building supply and discovered that they had "odds and ends" of ARBORITE in small size panels. (left over from a cabinet shop who sold the un-used pieces back to the building supply company)
In most cases the pieces were big enough to cover ALL the cabinet doors, (had to do a couple of wide doors with pieces side by side) AND drawer fronts.
One wall has the upper cabinet doors done with BLUE (light) and WHITE (alternating) the drawers below in YELLOW, and the cupboards below the drawers in DARK BROWN.
On the other wall, drawers RED and WHITE.
Now if you think all the "Rainbow" of colors is a bit much; really, it turned out pretty good!
The beauty of using the Arborite to cover all this stuff is,
(1) Fast to install.
(2) Consistant color. (even can cover previously painted surfaces)
(3) Easy to keep clean.
So ... when it comes time to do yours ... just a thought.
Dave
