checkthisout
- Joined
- Sep 5, 2008
- Messages
- 5,232
So I'm going to bend up the rest of the goosenecks and wire these up today.
View media item 56432
For a couple of them I'm going to rethread the ends and screw them into surface mount boxes. 2 will be mounted where I can't get behind the wall so that's the only option.
My question what should I do for the others? I want to drill a hole in the exterior wall and somehow fasten the conduit inside the building I'm unsure how to do it cheaply and simply. I could weld brackets which could then span between the studs but I don't really want to weld. The other option is simply conduit clamps pinching the pipe to a stud or blocking between the stud.
Any suggestions, ideas or pictures?
