dunstan
In my search for an old drill press I've found a guy selling some table-mounted Walker Turner's for $75 each. Unfortunately they don't come with a table to mount them on.
I was wondering if anyone had dealt with this format of DP before, and if they're worth having? I'm torn between snapping one of these up and trying to work out a mounting solution, or waiting for a bench-top press with a rack and pinion table to appear on CL (which seems unlikely).
The main reason I'm considering these is:
• They seem to be in good condition.
• I like the rack and pinion positioning of the head. It seems quite rare to find an old bench-top drill press with a rack and pinion table, and in my limited experience with drills I've always been frustrated when it comes to positioning the table by hand.
The downsides are:
• I'd have to find a mounting solution.
• I think it'd be trickier to add an extra set of slow speed pulleys because the main column would get in the way.
As for a mounting solution, I presume I could get a machine shop to fabricate a simple base for me, or maybe even buy a base and table from a bench-top version of the same drill.
Since I've never actually owned a drill press before, I'm hoping someone with more experience than me could comment on whether this seems like a good idea for a small home shop (wood and some metal), or whether it sounds more trouble that it's worth.
Thanks very much.
-- Dunstan
p.s. I like the look of this set up: http://www.garagejournal.com/forum/showpost.php?p=1795581&postcount=62
The downsides are:
Thanks very much.
-- Dunstan
