Thoughts on this slab
thejudges69
youngstown, ohio
I think we made an error in pouring my slab. It's a poured foundation, 8" slab 4500 psi rebar reinforced slab. When we poured it the slab didn't pour all the way down to rest on the foundation wall. I now have this void undery slab. It's a couple inches tall, and only across the 14' door openings. It recesses I'm about 2 inches. I'm wondering if this is an issue. My concern is coming in loaded will eventually crack the end of the slab. Under the slab is compacted limestone, from that's visible if you look into the voided area. This is tough to explain. I'm thinking if I clean out the loose material and fill this void with 4500 PSI quikrete that maybe a better fix. Thoughts?
Oh don't mind the pea gravel, that's temporary.. limestones going in there.
coldh2o
Ontario, Canada
I'm having a hard time understanding how this happened. It looks like you didn't have a form that extended down to the foundation, only the top half of the slab?
mcbane
California
A 2” gap at the edge of an 8” slab seems superficial. Maybe check with the person who calculated the need for 8”. The extra thickness may have nothing to do with wheel loads - could be necessary for other loads like pallet racking anchors.
T
thejudges69
youngstown, ohio
It was my call to go from 6-8". I wanted to make sure the slab would hold anything I brought in for weight..
mcbane
California
Then don’t sweat it. When you build up an exterior apron with compacted rock or concrete, that small void will be filled.
topp64
Des Moines, Iowa
So just to make sure I understand what you’re talking about here, you’ve got 2” of compacted limestone between the bottom of your slab and the top of your 8” wide foundation wall where the overhead door will be? If that is the case I would be more concerned with moisture in that 2” of limestone freezing and expanding in the winters. I would probably clean the rock out and use some patch like you mentioned. But instead of using basic quickcrete I suggest getting some type of V/O (vertical/overhead) patch material.
T
thejudges69
youngstown, ohio
Yes that's basically what the issue is. I don't do construction, so I'm not sure how to explain it better. But If I fill the void, wouldn't the freeze area move to the point of least resistance, so basically out away from the building into the driveway area?
topp64
Des Moines, Iowa
Typically you separate the exterior concrete, a driveway or an apron, from a floor with an expansion joint. You want to allow movement of the exterior slab, that’s subject to the expanding and contracting of its sub base from freezing and thawing, without damaging the floor that doesn’t move. If the floor is reinforced with rebar that has been drilled and epoxied into the foundation then eventually something has to give.
ConCretin
Central Maine
Since the slab is 8" thick I don't think I'd be particularly concerned as long as there is no way for the stone base to subside from under the slab and even then, the concrete could withstand quite a load. I don't see any difference with regard to frost or freezing whether you fill the void or not.
Jtrudel90
What is the difference having stone between the slab and the foundation wall (at the door openings) and having stone between the slab and the ground on the other 2xxx square feet. The rest of the slab is on compacted fill its not resting on the footing or stem wall. Your going to have a gravel/stone entrance going into the shop, its not like the stone is going to wash out from under the Pad.
joes169
WI
I sleep better at night knowing we pour every floor and stoop all the way down to the foundation. If not, what's the point of the foundation under the doorways if not to support the slab? We might do it differently here, though, as we utilize concrete ledges around the entire interior perimeter of the building, as well.
I'd dig some of the stone back (at least 4-5" deep), set up a 2x12 or the like the entire width of the door, and vibrate bag crete between the two.
T
thejudges69
youngstown, ohio
That's what I wanted and I think it was a miscommunication. The slab has been backfilled against. I don't think that it will ever be an issue. I'd thought about the bagged 4500 psi stuff but didn't get to it.
