Thread Cutting Oil
PoorUB
Fargo, ND
I have used all sorts of thread cutting oil, Tap Magic for one, some others I forget. The other day I was taping some holes and was out of cutting oil. I tried a couple regular oils that were handy, and then tried some 80w-90 gear lube and was mildly shocked as how well it worked. Since then I have tapped cast iron, steel and aluminum using the 80w-90 weight and was similarly impressed. I doubt I will spend money on a specific thread cutting oil and continue using gear lube..
Rinspeed
NY
For aluminum I miss the old Tap Magic that had Trichlor in it. Wasn't very good for you but it sure worked well. :)
alfadan
Augusta, ks
I tried it a couple times using hand taps and was happy how it worked. I thought the EP additives would work well and might be onto something.
BiggityBen
i rarely need to tap new threads into something, but when i'm just fixing threads it seems any old oil is fine. my old shop had whatever the CRC tap/drilling oil product is and i never cared for it at all. i will keep your suggestion in mind for future
LopezBart
Lopez Island, WA
For single pointing steel on the lathe or using a tap, it's hard to beat a pipe threading oil - Mitee, Ridgid, etc. I'm not fond of the smell of gear oil. For aluminum, tap magic, tap-matic, etc. seem to work best. For cast iron, either dry or a bit of kerosene seems best to me. I've never used a tapping lubricant on brass/bronze. Other stuff, I drag out Machinery's Handbook.
teagueo
Castrol Moly-Dee is stinky stuff, but works pretty well on tough materials.
seber
Deep East Tx.
The best I ever used is lard oil. But I'm going to try gear oil. Viscocity and lubricity would be similar.
Steve_P
There is a Project Farm test on this, I think with drilling? Tap Magic did very well. I still do use a lot of the Oatey though... 80W-90 just effing reeks, no way I'm using that for anything but the original purpose. My shop is in the basement of my house...
LopezBart
Lopez Island, WA
Note that 600W steam cylinder oil is about 5% lard oil... this oil is also safe for yellow metal bearings, so is often spec'd for rotary tables and the like.
midshipmen89
I've been having a great experience with Anchor Lube recently - local welding supply started carrying it, and it's doing great for drilling mild steel, stainless, aluminum, aluminum/magnesium alloy transmission case, and broken fasteners. Haven't tried it on tool steel yet.
P
PoorUB
Fargo, ND
I am aware of all the great cutting oils, I was just somewhat amazed how well 80w-90 worked, and pretty much all of us have a jug of it in the shop.
My thoughts are I may never buy cutting oil again, as I have a few bottles of 80w-90. With my luck the can of dedicated cutting oil gets knocked over and when I need it, it is leaked all over the drill press and then what do I use? I have had some that separated and got tossed. I have tried 10w-30 and 10w-40, I had 20w-50 around for a while, WD40, transmission fluid and other oils and none of them works as well as 80w-90 gear lube. I can not say that any thread cutting oil I have purchased was any better.
Wyoming09
Wyoming, MI
I've had really good luck with Union Butterfield. It seems to stay where you want it pretty well.
I don't do a lot of tapping so the one bottle is lasting quite a long time.
Jswain
Calgary, AB
If you want to try what you probably already have on hand. I've been using 50/50 used ATF & crisco shortening say 4tbsp each, then a couple tablespoons of melted wax in it and mix together.
I was going to try lard first but internet says the crisco shortening won't spoil as quick as the lard and it doesn't smell, and I had some in the cupboard already.
Goes on with a brush like a thick paste & stays on the drills & taps, as the drill heats up it melts in. Works really good and doesn't make a mess. I find it works just as good as rapid tap
