Thread Pitch Gauge
kramarj
Durand, IL
So I need to measure some threads which I believe are metric. I don't have a way to measure them, so I would like to buy a thread pitch gauge, but I have no idea what to buy. I would like the option to measure both metric and standard sized threads with it.
I found this one, am I right in thinking it measures both standard and metric?
Any help would be greatly appreciated.
thebeekeeper1
Illinois
Yes, that's what you need. "Threads per inch" is "American" and "pitch" is metric. They are easy to use. Most tap & die sets include one too.
hautpot
California
If you need to measure really small threads, be sure to buy a quality set from japan, america, england, genrmany.
K
kramarj
Durand, IL
Thanks for that, I didn't even consider a store like Menards to carry something like that. Looks like the local store even has them, I will probably just go that route. Thanks again.
The threads I need to measure are in the 1/2" range, so not small. I usually prefer to buy good tools, but this is the first time I have ever really had a need for it. Maybe someday down the road I will upgrade.
Thanks again for the replies, I really appreciate the feedback.
mikegt4
sw ohio
A good set of Thread Pitch Gauges is a good thing to have.
That being said, metric thread pitch on bolts, especially for M6 and up, is very easy to check with just a small metric ruler (such as a 6'' scale).
1 thread at each mm mark= 1mm pitch
4 threads in 5mm = 1.25mm pitch
2 threads in 3mm = 1.5mm pitch
1 thread in 2 mm = 2mm pitch
metric is MUCH easier than Imperial
ChevyEFI
Phoenix, AZ
I bought a HF tap & die set. It came with 2, a mostly metric thread pitch gauge and an SAE one. I haven't felt the need to upgrade yet, after several years with them. For larger, coarse stuff you're doing, a cheapie will work. $ 10 at Ace Hardware, for example.
larry_g
oregon
"metric is MUCH easier than Imperial"
Really? At least the SAE system is in whole numbers. And measuring for TPI you just count threads per inch, none of the funny divisions. ;)
lg
no neat sig line
mikegt4
sw ohio
lg
no neat sig line
REALLY!! you are counting 13, 14 16, 20, 24,,,,,threads over an inch instead of 1 or 2 per mm or 2 in 3mm or 5 in 4mm. I will take metric any day, it is a far better system.
Having used metric for most of my working career I can easily identify the thread and size (and if it is metric or std.) from 3 feet away. I use a 6" scale to measure metric threads as posted above if I am not sure. A thread gauge is good for checking internal threads where a ruler won't fit. Thread gauges should be in every tool box.
You don't need top of the line gauges to get a good reading, Craftsman and similar will work fine at half the price.
Tinner
N.E. Wisconsin
I have a pair at home and at work. Starrett, Mititutoyo, SPI and General brands. The PEC one linked to above would be fine.
crackit
North of Java
Thanks, that's an awesome method of measuring pitch! It doesn't get any easier than that.
leg17
Kentucky
And besides, you get the added benefit of grasping the concepts of TPI and pitch. This is good info. Don't ignore it.
davethorik
Norka, Ohio
What about those boards with bolts and nuts on them?
Those would work, although i wouldnt know where to buy one.
I have a Mitutoyo gage for metric, and a General for inch. The Mitutoyo is old, id guess 70s, and is very nice. The General i have about 3 hours of deburring into, because the individual leaves all had burrs.
I would have preferred a Starrett or B&S, but i got a screaming deal on the General for $5 on ebay, and its the big triangular style that has like 50 leaves.
IdahoMan
MikeRock
Where are those made?
Why does the Inch model cost twice as much as the Metric?
$10 would be the about the max I would want to pay.
Thank you for the link. I might purchase a couple if they aren't chi-chi and are accurate.
Sincerely,
IM
Cost difference: the basic inch one has blades for 52 different threads, the metric 24. It states "Made in Germany. Model 44D .... premium USA model made by PEC Tools."
lilcraigford
Portland, ME
Those would work, although i wouldnt know where to buy one...
Lee Valley used to carry a nice looking one they called Thread ID, although it was limited to smaller (M6 and 1/4") thread sizes:
Edit: McMaster-Carr sells the larger type you usually see in the hardware isle of big box stores; #20375A27.
Ad13
BC
I don't think you converted your fractions properly when you bought the drugs you are smoking.
bonneyman
Desert SW
I found this one for a buck at a local pawn shop recently. Thing is absolutely fantastic. Wish I could figure out who made and buy some more.
