I would suggest Heli-Coil and buy the individual set/kits as you need them. Kits generally are a big waste of money and drawer space.
Thread restorer might work ok, however if the thread material was damaged, and it will be. Then trying to restore/cut new threads, further material will be lost, producing a weaker thread. Restoring a thread is cutting away material, it is NOT ironed out as mentioned. Also drilling, tapping to install a larger size bolt not going to work 90% of the time.
The Heli-Coil is a real thread repair. Using the drill bit that comes in the Heli-Coil kit. One drills out the damaged thread, re-tap the hole with the tap provided. Screw in the Heli-Coil, and you'er done. At the end you will have a stronger thread, and be able to use the original size fixture.
A correct method of thread repair/restore, Heli-Coil kits have an aprox. range 7 - 30 bucks depends on the size, the kits also give the owner 8 -10 Heli-Coil inserts, along with the drill bit, tap and coil insert tool.
